2000 Impala Popping Noise in Front End
we hav 12,000 mi on our ls it has been to the
dealer 5 times to be repaired no luck.when you take
off it pops when you hit the brakes it pops.the
dealer first said insf. grease we got it back it
still did it.they replaced the struts when we leave
the dealer it does not pop the next day it always
comes back.they called gm and they sent
4smallteflon washers to put on top of the strut
towers.next day came back along with the check
engine lite which we havent gone back to the dealer
yet to tell them.we are tired of all the trips
back and forth. we are looking into the lemon law
in arkansas to get some help any advice onhow to
correct the problem would be app. bob
arbluedog@cyberback.com
I see that you have been the victim of a bad dealership with very incompetent mechanics. Your engine light probably was caused by the dealer messing around were they where not supposed to. Anyhow, seek going to another Chevy dealer and get a second opinion about your issues.
If problems continue and you lose faith in the car, then persue GM to initiate a buy back of your car. To be honest with you a lemon law proceeding is a costly uphill battle. If you choose that venue of action, make sure about the legal costs and implications of applying your state's lemon law to your case. Again, it might be better and more cost effective to get a hold of your dealer's general manager (Get a GM regional representative involved as well) and express your dissatisfaction with the car. Insist on a buy back. In the Montecarlo forum an owner with the same problems as yourself persued a GM buyback and he was successful at it thanks to his dealer's involvement and genuine sense of customer service.
Weigh your legal options carefully before you opt for the costly and not so efficient lemon law. Seek legal counsel if you must.
If you want to talk to other fellow impala owners, we invite you to join us in the "Chevrolet Impala X" topic under the "Sedans" forum right here at Edmund's Town Hall.
Good luck and let me know hat you decide.
Found cradle mounts loose, insulators allowing exessive movement :
Correction: Replace insulators, ( 8 all together )
Qty Part # Description
2 10402880 Insulator 9.023
2 10402881 Insulator 9.023
2 10402882 Insulator 9.023
2 10402883 Insulator 9.023
One other thing that I have heard people complain about that I had also was the blower making a high pitched noise when set on lower speeds. I took mine out, turned upside down and put WD40 on the bottom off the motor shaft and let it sit for a few hours. Put back in car and 6 months later, no high pitched noise yet,
The first thing that the dealer needs to look for is for 'engine trouble codes' which are stored in the car's computer. As far as fuel consumption, it is not normal that a car's fuel consumption starts to increase as you rack up miles. I have an Impala LS (3800 V-6) and I am currently getting 31MPG with 13,000 troublefree miles. There are several factors that can influence gas mileage such as quality of gas, octanes (Use mid grade 89 gas for better mileage and performance), driving habits, tire air pressure and condition, car load, etc.
I have stopped using 87 Octane gas as I find that the engine runs rougher and the mileage is not that great. When I switched over to 89 Octane, the engine runs much, much more smoother and the fuel economy improved significantly. Now I am using Premium 93 octane gas since I can get at my nearby Exxon station cheaper than 89 mid grade gas on certain days of the week.
As far as the transmission is concerned, I haven't had any tranny related problems. My Transmission shifts smoothly and at precise points. Have your dealer go over your tranny to see exactly what's causing the slips when shifting.
Good luck!
By the way, you are cordially invited to join your fellow Impala owners at the "Impala XI" topic located under the Sedans forum right here in Town Hall at Edmunds.
Also, my car also experienced long cranked starts. It still does at times and it seems as if it is flooding out. I would look at your fuel pressure regulator. Mine had a leak by the hose and it needed to be fixed. I hope this helps out.
