My Audi stalls at every stop sign
That's my guess. Look at the items which are connected to the throttle linkage near the carb/throttle body (whichever you have). One of these will be designed to change the position of the throttle plates (usually to open them a little, I think). This item is the choke and is supposed to stop doing so when it gets warmed up. Yours is messed up to not move fast enough, so it takes 30 minutes change to off when it should take 3. Basically, it probably is worn out. Get a new one. Bingo!
You might just want to spray the outside of the carb/throttle body liberally with a gumout type cleaner first to see if that does it.
There is one other possibility. Watch your engine temp gauge, is it up to full temp well before 30 mins? It is possible your thermostat is broken and giving your car full water flow and keeping it from warming up in cold weather. This is unlikely though.
If you are having problems with the choke, and you take the car to a shop, they'll probably want to do a full carb/throttle body rebuild. This probably isn't necessary, but isn't all that bad a thing, as your car will run smoother. Your choice. Do not let them sell you a new throttle body/carb, if they want to swap it, be sure to get a rebuilt one, as they work fine and are much cheaper.
If it's gone bad, it could cause sporadic
idle, and stalling. It's usually located
in a little box on the tube between the air
cleaner and your intake. Take a screwdriver,
and tap on the top of the box with the handle
while the car is running, if it stalls when
you hit it, it's bad. You may need someone
to push on the gas and keep the car running
while you test it.
hope that helps.
