As for I, well I spent my day yesterday sunday taking the train to Oshawa where the elderly owner of a pristine Geo Metro hatchback 94 with 40 000 miles on was waiting for me. Not greedy at all this gentleman had put it on ebay at a low buy it now price. It was on the site a mere hours and he was bombarded by 42 emails. I had to act fast and did. I am not disappointed one bit, no rust, everything dead stock! I will do the regular: cap, spark plugs, wire change AND change the brake fluid. Details. I drove it back a little further north than Montreal. It was purring at 110 km an hour the whole trip. The finest part is that Mastercard Citibank (Driver's Edge) is paying for it in totality, just like they did for Vanilla Latte, my convertible. You see they give you 2% on everything that you buy, up to $5000, towards the purchase of a car, new or used, from any country. I am not ashamed to put EVERYTHING on my card, it pays.
With but 61 000Km on the odo, that stick shift is nice and stiff, in fact I doubt that this gentleman (who won an Oscar by the way) ever used 5th gear. As he changed the muffler recently, this means that the household used it for short convenience store trips. It was a third car....I'll put Vanilla's 13 inchers to replace those nervous 12 inch tires and look for a sway bar. Toodle dee doo.
To time the motor but they give no clue as to which pins are D & E . Does any one know which of these pins are D & E?
pin 1 pin 2 pin 3
pin 4 pin 5 pin 6
pin 1 purple, pin 2 purple/green, pin 3 black, pin 4 no wire, pin 5 blue/white, pin 6 no wire.
Does any one have a good source for oxygen sensors were one does not have to mortgage the home stead To buy one? Dan
only registered car so I need it working. I ordered
the manual and clutch plate from partsamerica.com and
its taking forever for them to get here. Eta is like
11 oct...
I finally got the engine all back in there and the starter wont work for some reason. There was only one bolt on connection to the starter as I recall. Seems like there
should be a few connections there but I couldnt find any
thing else to hook up to it.
Any info on timing it would be good too. This engine didnt have the head off so I think it might not need to be timed.
Then i had no spark, i guess the dist from the new engine(from a 95) doesnt work the same as the my old one. i popped the old one on and got a spark. Always something.
I dont get any hits so I guess its prob just a
timing issue at this point. Unless I got a crap engine :0
I might test the compression tomorrow along with trying to time it. As for timing, seems like there is a setting for the injection pump and the distributor.
I do have a 30 day return guarantee on this junkyard engine, not that i want to take it back out.
Looks like the problem is with the fuel. I dumped some gas down its gullet and it fired pretty good.
Trying to look underneath for stuff,I saw a leak coming from the rear of the vehicle.
I then had to pull the gas tank out to get to the leaking lines. Also, it appears the fuel filter is ancient and may have been clogged. One more ride to town and I might have it going
I replaced the fuel lines by dropping the tank and now the pump doesnt come on.
I tried swapping in the inj relay to the fuel pump relay so i dont think its the relay. unless both relays went bad.
It seems to have voltage at the relay so i dont think its the computer. I think I have to drop the fuel tank again to directly apply voltage to the fuel pump. I hooked up a inline fuel pump I had lying around and it didnt get the car to start. Prob doesnt generate enough pressure, but It did bring the fuel to the front of the vehicle though.
I thought for sure i would be driving by nowwwwwwwwwwwwwwwwww
By the way, for all you convertible owners, Good news! It's a go, I am going to make a hard top for those little cabriolets. The design objectives are: easily removable by one person, use of existing componants if possible,lightweight, and fair price. I will keep you posted. Any comments or suggestions are more than welcome.Thank you, Vanilla Latte.
pipesbac@aol.com
Design objectives: lightweight, easily removable and install by one person,
use of existing components and low cost.
This eliminates curved rear window.
Options could be: heated rear glass though.
On another site, Teamswift, many suggestions have been made, including farming the project out of America. This I will not do.
I would like purchase 2 tops. Let me know.
Send email to : pipesbac@aol.com
It is simple and easy. Remove the srew on the top, jack the car up and remove the lower 2 bolts from plastic cover, remove the long bolt and remove the alternator. New belt will be nice. If you drink beer, will take you longer and few scratches on the hand. Do not drink when you work. Danger. Pipeman
Please accept my apology for making joke about the beer and working on cars, but how you will pay respect to the car, the car will pay you back this same way.
Do not use bondo, better some fiberglass or fiber filler. More work, but better effect for longer time. Bondo hold water.
Good luck. Any questions, let men know.
Mark the pipeman
I also have a 94 2 door hatch back.
Start by changing plugs, wire and distributor cap. Check the air in the tires. Change the fuel and air filters. Verify that the idle is at 950RPM when it's warmed up...... Empty all the accumulated stuff in the rear.... Stuff like that.
Let me know. Maybe we can help you. I have two geo's and I put 2 brand new engines - completly balances. My everage is aroung 48 mpg. Most is hway - 85%.
Did you buy the engines already together or did you do the rebuild? My Geo has 213K Miles on it and it is starting to run a bit rough. I don't know if yours is the 3 or 4 cyl. Mine is the 3 cylinder one. Just trying to figure out if I should sell it or maybe just do a ring and valve job. Let me know what you did and at what cost (if you don't mind me asking).
208, 204, 199 psi. The first engine I assembled with very close tolerances on rings ( 1 compr, + 2 oil rings.
The pistons and the conrods/wristpin where registered at 675 gramms (3). The second engine was assembled with more open tolerances on rings with pistons and conrods/wristpin 670 gramms.
Both cyl. heads intake ports and exhaust ports where polished and where also opened in the inlet and the exhaust manif. was opened in the inlets.
If you need more info, please let me know. I checked the compression on one engine 1991 after 10000 miles. The second has only 4000 miles.
The 1994 with 143.000 miles lost oil pressure and I replaced the oil pump, pressure valve, but didn't help. I found later the camshaft bearings was gone. The second engine was low on compression #2 with 145 psi. I decide rebuild the engine completly. The 1991 Covert, has only 36000 miles, when I change the engine.
If uyour engine run poorly,please check the compression. IF is aroung 160-190 psi, you have a problem with the EGR. Remove the exhasut manifold, intake manifold and clean the
opening in the cyl. head and also in the exhaust manifold, check also the intake flow. Remove the bolts from the exhaust site and replaced with studs. Works much better when you will assembled the engine.
I always play with my cars and my work. Usually my engines afyter rebuilding registered over 180.000 miles, with proper maintenance.
If the body is good, first check the front suspension, the lower control arm attached to the unitbody ( lower frame) is not rust, I will redo the engine or cyl. head.
Do not make any short cuts. If you think do valve job, rings , you can redo all engine at ones. More easy.
I'm planning use my Geo's next 20 years. I drive daily over 120 miles to work.
Also in good weather I drive my BMW 524 TD with 230.000 miles at 35 MPG.
Any questions, let me know. I like help people. American people help me here 25 years ago, when I escaped Poland.
God bless USA and Americans.
With the timing marks - watch out for set up. Is different before 1992 and after 1993 up.
What yer is your car?
YOu shuold't pump more than 28 psi in the tires. You will shake to much the car, if you have more pressure. All car will vibrate on higher tire pressure. I use 13" tires.
Before 1992 the sepc are 10 BTDC, but after 1993 July up, the timing is only 5 BTDC, but you must lock the timing on plastic plug ( bridge two outlets with wire).
I have a 91 Geo metro, Car runs great but has hesitant acceleration at speed. If it were a carburated car I'd say the accelerator pump was not working. But since this is EFI I'm lost. Anyone have this same problem or know what is wrong?
Many Thanks
Ron
Thanks for the ideas and recommendations, I'll have to check the compression when I get a chance and take it from there.
Thanks again!!
What I did - remove the Catal. Converter, cut of the front pipe and I cleaned the converter inside. Removed all "honey nest". Installed back and never have any problem. My OX. sensor work better, no more back pressure, better mpg.
Passed emission - easy. Just do not mention about that.
Pipeman
Didn't damage the World.
GeoMetro91
Second. Remove the exhaust manifold. After the exhaust manifold is out - clean very well the opening ( 1/2" dia.) accross the cyl.head. From the exhaust to the egr.
Look at the exhuast minifold and you will see small hole running between the "exhaust collectors" 1 - 2 -3.
The opening is less than 1/8" dia. Use the transmission fluis to clean the passages. Put the one site of the pipe cleaner to the transm. fliud and insert in every small hole. Must go thru. If is plugged, put more transm. fliud in the openong in leave for 15 min. and try push thru. If will not open the hole, use some sharp wire and push. By gental to nor brake the wire. Also you can use high pressure air to clean the passages.
Replace all bolts with studs. Easy to work. Use grade 9 or 10 studs. Open the ehaust manifold inlets abut 45 degree angle , the flow will be easier. Before instaling the studs, retap the thread in the cyl. head with greas.
Use copper grease to install the studs in the cyl. head.
Pipeman - visit my web www.bacartpipes.com
No sure what you mean by opening up the inlets on the exhaust manifold. Are you talking about taking a die grinder to the manifold itself? If so how far back should the 45 degree bevel go?
geometro91
Also you can do 45 on cyl. head.
How about those small holes in the EGR , you located that?
If yo will look inside the exh. ports you will see small "pipe" on the bottom of the runners.
Let me know.
I live in the state of NY. The weather has been rainy. I cannot start my car. I did get it started (finally)and let it run for about 5 minutes. I gave it some gas (while sitting)and it stalled. My check engine light did come on the other day but has shut off. Help!
Thank you so much. I still have yet to fix my problem. I will try this. Actually, my car has been sitting in the carport. Afraid to drive. Everything is very old on my car. Never changed spark plugs. Or wires. Never had enough cash to do so. Now I have a problem. I believe my gas tank probably needs to be replaced and whatever is inside it. I have a leak (gas)on the right side in the back of my car. My brother says my car is junk. Never had any problems. Always started for me. I bought it used. Have had it for, I don't know, maybe six years. Anything else you can tell me would be wonderful.
Thanks...Deborah.
I am now trying to figure out how to replace a leaking heater core. Near as I can tell, it must be the first thing installed on the dash ! So, I flushed the system, added radiator sealer and new anti-freeze...maybe I can get away with that temporary fix another year.
I think your problems are much less- and the fixes alot cheaper. If in fact the gas tank is leaking, a junkyard visit maybe in order... anew one will be around $99.oo + labor to install it. I never repair gas tanks.
Is your car 3cyl, or 4 cyl, automatic, stnadard, does it have ac? 2 dr, 4 door?
Good luck
OK THAT ALL SAID: anyone got a tip of how to replace it easier? Other than a dealer?
:confuse:
My 94 Geo is a 3cyl, 2dr, standard, hatchback. No AC. Nothing fancy about it. Just your basic car. I have crawled under the rear of the car and there is (gas) slowly dripping out. I have a little puddle on the floor of my carport. Live in Rochester, NY.
Thanks. I am new to this site.
I live in TX, so I guess it depends on why your gas tank is leaking. Rust is not a problem here, but backing over a rock was. I was able to have the hole in my gas tank repaired by a local shop that specializes in repairing gas tanks (and the repair was much cheaper than finding a gas tank for my '92 Metro convertible).
If you have lots of rust on your tank, though, it wouldn't make sense to try to have it fixed - simply replace it with a rust-free one from a junk yard, as p1leadman suggested.
Best,
Stan
There is one thing that annoys me. On startup in the mornings, the one darn belt it has squeals like crazy. I've replaced the belt, tightened the belt, over tightened the belt, loostened the belt, sprayed the belt with belt stuff, it seems to come back every time. (??) I can stop it by turning of & re-starting the engine a few times until it starts quietly. Anybody else have this??? Thanks DangerDude
