1989 Dodge Shadow
                    After $600 and no further ahead I am desperate for
a solution, can anyone help, all suggestions would
be appreciated. The TPS ( throttle position
sensor), Oxygen sensor and the EGR valve have been
replaced, no fix as of yet. The syptom:
Jerking when engine has warmed up at highway
speeds, normally takes about 15 minutes to occur,
once it starts I can pull over for about 20 seconds
and go again for about 20 minutes, it does
eventually clear up and run like a charm. If I
floor the accelerator pedal it picks up after a
short time, say about 1-2 seconds, this normally is
predominant in light throttle in 4 or 5th gear. It
is a standard 2.5 ltr engine. Gas mileage
deteriorates, probably due to the heavy foot that
attempts to correct the jerking. Please help, very
frustrated with the so called authorized dealers.
carlady/host
