Mazda MX-3... any good?
I'm 18, had 3 convictions and 1 accident... I'm
not a bad driver, I was just stupid when I first
started driving. Anyways, I'm looking at a used 4
cyl MX-3, probably 93-95. I was wondering if
anyone had problems with them, or any other
constructive criticism about them. My 68 Bug isn't
fairing well during the winters, so I figured I
could use an upgrade.
Brandon
Brandon
Hopefully this will be of some help.
-Ben
Keeps going and going. Pretty good in the snow - has a slight understeer if you hit a corner too hard, easily controlled by letting off the gas and the front end whips back in line.
The car that keeps coming to mind is the 1993 Mazda MX3 GSi Hatchback. Despite it's age it for looks it can still hold it's own against most of todays more contemporary models and the same can be said for MX3 GSi's performance. What concerns me though is the mileage. Right off the mark despite it's past reliabilty it would end up being high maintence car due to the age. My late 1987 Acura Integra made it to 200,000 miles before the final bang from the transmision. With no disrespect intended to any of the owners of this little classic; I honestly can't see an MX3 making it much past 200,000 miles. In my case as the MX3 would be used as a back up and short zip run car the yearly mileage would be considerably less than normal. However it still makes me wonder just how much the maintence costs will be on plus 100,000 mile "pocket rocket" with a manual transmission. Certainly cheaper than if it had an auto trans. but even a manual trans can get expensive, this is to say nothing of the other repairs.
Your
kilometers and the car has only needed the usual stuff and one CV joint. Still, it is time to move on to something a little more comfortable - like a Millenia S!
How about swapping the engine with the 2.5 from the 626 or Mx6. It is a bolt-in job!
Check out www.mx-3.com for alot of info!
Revka
Hatchbacks & Station Wagons Boards
Thanx,Dinu
Thanx, Dinu
Revka
Hatchbacks & Wagons Boards
I heard the V-6 MX-3 was amazingly reliable and trouble-free, a really good buy, and the only slight disappointment with it was that it was nose-heavy in handling character.
Too bad they are so rare or I would have bought one a couple of years back, and probably would still have it today.
I first went to a Mazda dealer, who didn't know what the problem might be. I then went to my regular mechanic. He said he'd seen the problem before and that the injectors needed to be properly cleaned. He cleaned them, problem gone, car runs better than ever.
I just bought a brand new Accord V6. The GS was so good I didn't want to trade it, so gave it to my daughter.
I never had a major mechanical problem with mine. Parked it outside year round for the first 6-7 years, and drove it winter and summer (Maine winters). The car started without a hitch every time..even in below zero temps.
It is a rugged little car in the snow too. Put snows on the front and it had great traction as long as you start off in second gear.
The car has about 80,000 miles on it now and has a couple of problems. Would be interested in some feed back...
She is starting to burn some oil between oil changes. Usually down about a quart or quart and a half. Also, in extremely warm and muggy conditions the car idles high...at around 2500 rpm vs the usual 500. This goes away as soon as the weather cools or the car cools down. The car is not hot..at least the temp gauge doesnt indicate it is overheating.
Any information anyone can provide would be appreciated.
