Also, #595, the 2001 Celicas had a recall on the shifter, that may have been related to your experience in the test drive.
Anyone have replaced tires on GT? I got 25K on them and they are almost gone, have to prepare for snow. The Dunlops which it has now does not seem to be general type, are they easy to find? Or better replace with something?
1st: 3.17
2nd: 2.05
3rd: 1.48
4th: 1.17
5th: 0.92
6th: 0.73
Final drive ratio: 4.53
You asked for _any_ suggestion...
Most cloth seats look good for a LONG time nowadays. Take care not to let combs, keys, etc., in your pocket tear the seat when you sit down. Otherwise, they should last a long time.
Has anybody installed the TRD exhaust??? It says it adds 10hp at the wheels on a GT, which seems awful high for a car with 140 hp.
-cho7819
** Proud owner of a Mitsubishi Galant ES-V6**
Thanks for any ideas or thoughts.
And of course you also have the option to start up a new Toyata Celica Problems discussion on that board. Good luck, and please keep us posted on your situation.
Revka
Hatchbacks & Station Wagons Boards
Revka
Dinu
As for pricing, have you had a chance to check out Edmunds' Used Vehicle Appraiser? Others here may have more to add. Since pricing varies from region to region, you may also want to let people know what area you'll be making your purchase in. Good luck.
Revka
Thanx again,
Dinu
The cars done 109k starts fine, clean enginge with no knocking or smoke and sounds lovely!!!
Much obliged.
Tim
I'm also looking at the Integra and MX-3.
Dinu
THe usual suspects:
Timing belt, sparks plugs, distributor cap, etc.
Distributor O-rings typically leak on those engines.
Check gear oil or ATF, coolant, air filter, etc..
Get it checked out by an independent mechanic also.
Brenda
Revka
Any more money spent (on a cat-back, for instance) would accomplish little and cost you more.
Brenda
Revka
I was trying to find more info about the car. Like how many were built, or who converted them the drop tops? Another thing is, will the 3SGE engine drop in (without major mods, or what has to change?). I'd like to replace the 3SFE, as it's got 145k miles, and kind'a under powered. Anybody know of a good site for these cars (86-89)?
Hi lesterinindy- "2000 GT starting problems". Sorry to hear about your vehicle problem. You can also check in Edmunds' Maintenance Guide to see if there are any related TSBs. Good luck and please keep us posted on your situation.
Revka
