Subaru Impreza Outback Sport & TS
1212224262762
    By the way, I test drove a Protoge5 yesterday, since I was at the Mazda dealer buying a new gas cap for my Miata ($25, ouch).
    Well, nice little wagon. Very cute. 16" wheels, 4 wheel disc brakes, white gauges, generally inoffensive. Handling pretty solid, no torque steer, but then again no torque either.
    It needs more engine, badly. It could not hold a candle to the OBS I test drove recently, which was far more relaxed accelerating. I prefer the Subaru shifter and seats, but the Mazda's brakes.
    Nice car. I wouldn't stop anyone from buying it, but I'd pick the Outback Sport myself.
    -juice
  • brekkebrekke Member Posts: 304
    Oh, I asked because subaruparts has a rear stabilizer bar/bushing kit and they said the difference between that and just the rear anti sway bar is there are eight more bushings which they didn't recommend for the OBS. So I thought there might be a benefit if I got two extra bushings. Or not. BTW would Ramon's rubber washer trick keep the urethane from squeaking?
    I think the P5 looks great, if only someone asked us we could tell them it needs AWD and more power!
    Well, bushings are just the rubber gasket that hold the bar at the mounting points. More bushings won't do anything unless there are additional mounting points on your car.
    Usually there are only two bushings, plus the bar attaches at the two ends links (with no bushings).
    -juice
    thanks juice
    sorry I seem to be asking so many stupid questions, but it is much appreciated when it is time to order...
    *sigh*
    Not a stupid question at all, unless you've spent as much time under your car as I have doing mods and maintenance.
    -juice
  • ramonramon Member Posts: 825
    like what juicemon said. If you want better transition b/t the car and the reaction of your sway bar, you need urethane. I've even seen metal bushings for miata! Now talk about harsh ride! Anyways to get those combos going, u should then install the end links too.
    I'd even so the end links first, then the urethane bushings. There is a lot of play in the standard rubber end links. You can move it by hand.
    -juice
    arg you guys! So you're saying I should get urethane bushings and urethane end links, or the metal end links? I don't autox so I didn't think the metal end links were necessary. And then the rubber washers from home depot will take care of the squeaks?
    I'd do the mods incrementally.
    First, put in the fatter sway bar. See how you like it.
    If you want even better control, do the bushings, because they are very cheap.
    Then, consider the end links, which are a bit expensive.
    -juice
    you don't autoX, then the end links are a bit of an overkill. You would benefit more by getting a new set of good tires, shocks and springs then do these "minor mods". Just my 2 cents. OK everybody wish me luck! If all goes well, my car will have a new pair of Bridgestone S-03PP.
    i meant a new set...
    While you cannot rewrite history, you have 30 minutes to make any changes or fixes after you post a message. Just click on the Edit button that follows your message after you post it.
    Steve
  • rachelukracheluk Member Posts: 12
    Engine's starting to settle in, and I'm enjoying the ride in my Ruby Subie.
    A few more quibbles, however, if anyone has the time for a comment!
    1. Arial is not as good as the external Forester 00 and no one at the Soob dealer knew anything about improving it. Any ideas for improving my reception w/out buying a whole new receiver unit?
    2. Already got a tiny chip where the hood meets the bumper, probably from a bit of gravel on the road. What do you all think about the small and large mask/bra thingies that cover some/all of that area? A friend discouraged me, saying the vibrations from that can actually damage the paint more than the occasional rock chip.
    3. When turning headlights off there's a distinct sound which I don't care for. Could this be intentional or is it just an el cheapo factor?
    4. First oil change at 1500 miles or so, I'm planning. Should it be 5-30 the first time? And what grade gas do you all use? My dealer told me 89 octane but all i ever used in my Forester was regular 87.
    Again - many thanks to you all for the opportunity to ask these questions and garner such fine responses.
    Best wishes,
    Rachel
    Keep in mind the OBS is a little lower, so leave a little more room in front of you to avoid those rocks and pebbles that get kicked up by trucks. IMO I don't like the way those car bras look.
    IIRC the recommended viscosity is 10w30. You could go with lower numbers if you're in a very cold climate.
    87 octane is fine, that's actually what they recommend in the owner's manual. Car & Driver had an interesting article on fuels, and found that in the cars meant for regular gas, premium was of no benefit. It actually slowed 2 out of the 3 cars on their test track.
    On cars meant for premium gas, it's a different story. So the rule of thumb is to stick to what is recommended by the manufacturer.
    -juice
  • bluesubiebluesubie Member Posts: 3,497
    Actually, the "preferred" weight in the owner's manual is 5W30 for temps up to 100 or 104F (previous gen. anyway). A 10W30 will give your engine better protection though in high temps and more aggressive or severe driving.
    Dennis
    I have a big, fat grin on my face right now.
    -juice
    :D
    Dennis
    OK, so I meant for my style of driving...
    -juice
    Dennis
    Yes, I have that loud headlight click too. I think it's normal.
    Anyways, juice, could you give a mini-comparo of your Miata, a BMW 330, and the WRX? i.e. which is most fun/handles best? I hope that's not asking too much...I think I might want to get a Miata in a coupl'a years.
    Also, does the WRX handle much better than the OBS, or is it similar taking into account suspension differences?
    sheesh! I don't have the money for those kinda mods. Ganzflow, someday. But do you know where I can get those urethane bushings? Liberty Subaru didn't have them.
    Check out Edmunds' review of the BMW 325xi wagon.
    http://www.edmunds.com/reviews/roadtests/spin/46587/article.html
    They refer to the WRX a lot.
    I've driven a WRX and a new OBS. I was paying more attention to the surge of power in the WRX rather than the handling. :-)
    Flemington Subaru usually gets 2-3 used Miata's every summer to sell. The owner there loves them.
    Dennis
    Wow, what a comparison. Going across a few segments, there, but I'll take a shot at each.
    Miata: all about fun. Impractical, cold, and cramped, but light and agile, with telepathic steering and go-kart handling. RWD is fun and you can get the tail out. A toy, but a great toy if it meets your needs.
    BMW 330xi: I drove the AWD version. By far the nicest accomodations, but you expect that for $40 grand. Quick and smooth inline 6, steering a bit light, good automatic tranny. It understeers, which surprised me. Great brakes. Tight inside. I prefered the 5 series for its more practical size, and for $40 grand I want a 5 series, thanks.
    WRX: only got a quick drive, but I guess all drives in a WRX are quick. Cheap sun visor, carpeting, and headliner, but that's about it. Great seats, by far the best. Cozy, but generally tight structure. Docile at low revs, like a refined small sedan, but becomes wild above 3000rpm, with power building linearly with revs. Biggest push into the seat, no question.
    So, which is the weapon of choice? Depends on the job. Pick the Miata for a sunny day cruise on curvy roads with the significant other and pack light.
    To impress the friends at the 10 year high school reunion, take the Bimmer, which will also hold its own at the track. It may be the easiest to drive fast, with all the electronic babysitters and the flexible engine. Most at home at the country club I don't belong to.
    The WRX is a car you buy for yourself, not to impress anyone else. Get a wagon and you could even take the family along, but I think it would excel at providing the most bang for the buck.
    -juice
  • barresa62barresa62 Member Posts: 1,379
    I think you should start you own auto review site and I'll be one of your test driving reviewers on staff. :-)
    Stephen
  • celeste2celeste2 Member Posts: 362
    racheluk: you are sure the antenna is pulled all the WAY out? Not being funny, as it happened to me. Thought the reception was terrible and realized whoops, the antenna was not out. It doesn't go straight up but kind of at a 45 degree angle toward the back of the car when extended. In fact, sitting in the driver's seat with the window down you can reach up and pull the antenna out while in situ.
    Juice: liked that glowing review of the new Mazda whatever wagon vs. the OBS.
    By the way, I test drove a Miata this summer and loved the clutch and shifter. Very fun to drive. But was kind of rough because you are so close to the pavement. Wouldn't want to make a distance drive in it. Can see why people say it's fun, though. That new aqua blue color is pretty awesome and I like the look of the hardtop.
  • stratmoenstratmoen Member Posts: 1
    Does anyone know if the 2.5L engine uses chain driven cams or is a belt?
    OK, Stephen, you're hired. The position doesn't pay much, though, just a few smiles per hour. ;-)
    Oh yeah, sport-package-equipped Miatae have really stiff rides, so it's for AutoXers only. The base package is a little more tolerant of rough roads, though. It revs high on the highway and generally would prefer that you take the long, twisty roads home.
    On the highway, any Subaru or Bimmer would be more at home.
    The 2.5l boxer uses a belt. Service interval is 90k miles for an inspection, 105k miles for replacement. The 3.0l H6 is chain-driven.
    Drew: yep, I was just surprised that coming into a turn a little too hot in the 330xi, it almost understeered off the course. I recovered and didn't knock down any cones, but I'm sure it hurt my lap time.
    -juice
    A BMW is on the wish list, but I doubt I'll ever be able to afford one. I thought they "corrected" the light steering in the later 2001s.
    So I thought a miata would be the most fun for the least money, I'd just keep my OBS instead of trading up. I still don't know if I want a turbocharged car...
    But I'd never driven any of these, and short of going to a dealer I won't have the opportunity, so I was just curious because I knew you'd driven 'em all.
    Anyway, this is all pointless speculation, in a few years I'll probably want something else.
    I'm not sure which ones they had for the Ultimate Driving Experience, but they may have been in the fleet for a while. I don't recall their mileage.
    Do what I did - keep the Subie as a practical year-round car, and get a Miata as a sunny day 3rd car.
    -juice
    we are definitely on the same page! What do you think of the MR2 Spyder?
    A used Miata seems a lot more affordable, and I know yours has been reliable.
    Have not driven one. I don't like the styling, looks too bug-eyed. It somehow manages to be even less practical.
    Mid engine sounds good, though. And it's feather light, too. But it does have struts and a transverse mounted engine, while the Miata uses double wishbones and a longitudinal layout, the latter not unlike Subaru.
    The catch is you can't find plentiful, cheap used ones, like you can with the Miata. They only started selling last year, and with a markup, too.
    -juice
    Brekke: I read a review in either a magazine or the Sunday paper on the Toyota Spyder vs. Honda S2000. The Toyota lost. Can't remember the specifics but he was waaay more impressed with the Honda.
    It costs a lot more, too, maybe $5 grand.
    -juice
    My neighbor bought an s2000 and I pretty much slobbered over it for five minutes. Beeyootiful!
    Why don't these car companies make more RWD cars?
    Dodge:
    Next generation of Intrepid and 300M will be RWD
    GM:
    Next Generation of Impala will be RWD (hopefully it will be the non-us Holden Commodore SS)
    All Caddys will be RWD within a few years
    Ford:
    LS, towncar
    Toyota:
    IS300, IS300 wagon, LS430
    Nissan:
    Q45, next gen Maxima
    -mike
  • revkarevka Member Posts: 1,750
    An occasional off-topic post or two is certainly okay, but let's please not get too carried away. Don't want to confuse the tourists. Okay? ;-)
    Btw, if you just feel like chatting with your friends on any subject..., feel free to do that in our Roadside Cafe. Another good place to hang out and talk about some of the cars mentioned recently (i.e. Miata, S2000) would be in the Women's Auto Center discussion Talk about Sports Cars. Hope this is helpful.
    And now back to the discussion of the Subaru Impreza Outback Sport. Thanks for your participation.
    Revka
    Hatchbacks / Station Wagons / Women's Auto Center Boards
    The Maxima will be based on the Altima, so it should stay FWD. At least the upcoming one.
    Nissan will offer a RWD G35 based on the skyline, and of course the upcoming Z car.
    But the Outback Sport offers both FWD and RWD, AWD rules! :-)
    -juice
    is a big mistake IMO. They should be moving to AWD, not RWD. I think it (RWD) will be a hard sell in the snow belt. The car manufacturers have spent years convincing the public that FWD is better in the snow than RWD—and now they're switching back! The average car buyer could care less is RWD has an edge over FWD in terms of performance. They want to move about in snow. RWD, even with traction control is not the answer. DUMB!
    I guess the state troopers will be happy...
    Bob
    Another argument is that they could add AWD to the existing platforms, so it's cheaper than going to RWD on new ones.
    I think things like traction control and more importantly, stability control, have given automakers the courage to go back to RWD.
    -juice
    add AWD to existing FWD platforms. That's the ticket...
    Bob
    My thoughts on the RWD shift is that they are getting hammered on the back-end of the warranty on repairs to FWD. RWD can take poorly maintained roads much better than FWD can, as well as are more durable. Also they are planning on equipping them with more grippier tires for the RWD platforms. TC, SC, etc combined with more agressive tires should do the trick for traction.
    -mike
    Perhaps, but it doesn't seem to be problem for Honda, Toyota and others.
    I know the Acuru RL is rumored to be switching too. (it's also rumored to get an AWD version too), and the that larger Lexus models are RWD. My thought here is that RWD is "perceived" to be better in those segments because both BMW and Mercedes use RWD. Well, the latest I've heard from Mercedes is that they will be offering AWD in all their model lines within the near future. It wouldn't surprise me one bit if at some point all Mercedes and BMWs become AWD.
    Sorry, I just don't buy it. To me it's a step backwards, not forward. Yeah, the performance crowd may be happy; I'm not so sure about Harry and Harriet homeowner.
    Bob
  • ak47thak47th Member Posts: 5
    does instaling this mod void any dealer/factory warranties?
    If you blow something up in the engine and it canbe traced back to that. If you suck in water, and hydrolock your engine, they could blame it on the intake. Or if you suck in excessive dust and it blows up due to the contaminents. Or if your ECU doesn't compensate for the higher flow, and you run lean, and blow up a cylinder.
    -mike
    Hey, don't let all that scare you! Tons of people have had these and unless you are into off-road abusing your car (ask Juice about that, heh, heh) you shouldn't have any problems.
    The instructions that come with the GansFlow tell you how to reset your ECU and I've had mine on since April. It sucks up air thru the fender well on the passenger side, up high under the hood, so I don't know how on earth you could suck up water unless you're crossing a very severely flooded road, and then you'd probably float away. Yikes!
    If you want to do more research on it go to i-club.com, and there is a search function there. Or ask in the Newbie and FAQ forum. They are a very nice addition to the OBS.
    A lot of it has to do with power. After the OPEC crisis, people ran to FWD for efficiency.
    By now, though, horsepower figures are back up, gas is cheap and plentiful (despite a short-term price scare early this summer). 200hp used to be big news, now it's common, even kind of low in some niches. FWD just doesn't put that kind of power down effectively.
    It depends on the size of the vehicle and a lot of other things, but generally FWD applies best in vehicles with no more than about 150hp, maybe a little more. Above 200hp should be RWD or AWD, though.
    If you off-road, just custom make a cover (snorkel) for your intake, no matter who supplies it. The trick isn't necessarily the depth of the water, but the size of the splash you create. he he he...
    -juice
    RWD will be tough sell to those in the snow belt, and to those who like FWD. It took years to convert RWD advocates over to FWD. It's going to take the same amount of time to convince them to go back to RWD, even if that's possible. Sorry I don't believe RWD with traction control is as good as FWD. Now even FWD is available with traction control. It's available on the Honda Odyssey.
    My daughter's Prelude (160 hp?) doesn't have any torque steer that I've found. I don't like the steering at very slow speeds (under 5 mph), it just feels strange. It feels great, at speed, on a curvy road however.
    One of the other advantages of FWD is better packaging. You can make a small car much roomier with FWD than with RWD. I know, this is less of an issue with larger cars.
    Bob
    Are there people that actually like FWD? I thought it was kind of something you had to settle for when you bought an econobox. ;-)
    Honda's trick is that it's engines, at least its 4 bangers, don't produce much torque. HP, yes, but not torque. Gearing and light weight meant there could be quick.
    FWD does have better passenger space packaging, but it makes a mess of weight distribution, with much of it ahead of the front axle, even. True, most owners don't have a clue.
    RWD will be common on luxury cars and sports cars/sedans, but I still think most of the mainstream sedans will remain FWD.
    -juice
    There are loads of VW GTI owners, and Integra owners who swear by FWD.
    Bob
    GTIs are fun, but how effective is an inside rear wheel if it's not even on the ground? They look like a dog relieving himself. ;-) Proof of the limitations of FWD, at least with that rear suspension setup.
    The 'teg is a better setup, as is the Prelude. Still, look at all the effort Honda put forth - 4WS and ATTS, that failed in the market place. Also, nice as it was, the Prelude was dropped, too.
    -juice
