Alland (02 LL Bean)
On 4 cyl cars, the auto tranny is filled thru the dipstick tube. I don't know about the H6.
The rear diffy plugs are sized for the 1/2" drive socket head at the end of the wrench handle (I had to ask too)! Remove the FILL plug first. Mine was so tight that I did the following: Taped thin brass shim to the socket head to reduce free play, positioned the wrench and added a cheater bar, used a jack to turn the wrench. I may have bounced on the car too when the jack seemed to raise the whole car instead of loosening the plug. Once it breaks loose, it's easy. Then you repeat the whole process with the drain plug.
HTH,
Jim
You will find a drain plug for the ATF on the transmission pan, but refill is thru the dipstick tube. I used a funnel with a section of flexible plastic hose attached to refill it.
The rear diffy has two plugs, both use a 1/2" square drive. If you happen to own an impact gun, set it on low torque and increase as required. If not, a standard 1/2" socket wrench set will do fine, but you will have to work harder! Problem is that the plugs are in very tight. Place a length of pipe on the ratchet handle for more leverage. You might try placing a small sissor jack or pump jack under the pipe to use the weight of the car to help break them free.
Steve
Steve
Steve
Thanks for the reply. I only have a 3/8 square drive, so I need to invest in either 3/8 to 1/2 adapter or a new 1/2 square driver. I remebered from earlier Juice's post that the filler plug should be loosen up first before the drain plug on the rear differential just in case you drain the fluid and can't fill it up.
Alland (02 LL Bean)
-mike
Craig
Steve
Jim
-mike
Jim
-mike
Steve
The reason I ask is because when I was lookin at the fluid coming out from the rediator hose new ATF came out a lot sooner than I expected which indicates that the ATF oil is coming from the pan rather than directly from the torque converter. In this case, I don't think I achieve complete flushing. May be as soon as you start the engine, the new ATF fluid is routed to the rediator, and I am draining the fluid that I just filled in. What do you think?
When I did the flushing on my 2000 Honda Odyssey, it took a while for the new fluid to show up at the rediator ATF hose. That is why I am a bit puzzle and doubtful that I did the flushing on my 02 LL Bean.
Alland
-juice
I just don't see how much of the fluid in the converter can get out though without the pump running. It is pretty well trapped in there. Removing the hose from the radiator might drain some of the low hanging fluid in the case, plus whatever is in the internal radiator cooler and lines, but not much else.
I have heard of a two man operation in which one pours in fresh fluid while running the engine and cycling the shifter, with the cooler line dumping into a 5 gal jug. That would probably work quite well. But you better be careful, as they don't run happy for too long if they run dry!
Steve
For the next ATF change, I will stick with drain and refill.
Alland
For the diffy I use a regular ratchet or breaker bar, but I do have air tools and electric impact if need be
-mike
So you were running the engine. I thought from your initial post that it was off - why I answered it in the way I did.... Sorry.
Subi say to just drain and refill the pan 1x time. So you change around 50% of the fluid. I also have an '02 Ody. Honda says, IIRC, to do the drain and refill 3x in a day, or something like that. This would remove about 90% total. I guess that the current thinking is that unless you abuse the unit, changing part will be good enough.
Steve
Get a Subaru Chase credit card, earn Subaru bucks, then let your dealer do the service and pay for it with that credit.
Free service!
-juice
http://www.amsoil.com/faqs/faq8.htm
Hey Juice, I do enjoy reading your post. The amount of bill that I put on my credit card, I probably have to wait about ten year before I can get a free service. By then, I will move on to a different car. Humm.., I think I should start paying my mortgage with the credit card. This way, it will speed up the free service. One of my friends puts all the bills including mortgage on the credit card and write a huge check to credit card company every month.
Alland
( 02 LL Bean, Mobil 1 5W30 every 7500 miles with pure one filter, Redline ATF, next step 75W90 Redline on front and rear diffy)
-mike
The really nice thing about the program is you don't have to buy a car like you do with the GM card. Being able to use it for service means no matter what happens they won't just go to waste.
-juice
Looking to trade in my Saab for a Subaru legacy outback wagon.
Are their any particular mechanical issues to look for? Reliability? Durability? Etc?
Rick
They will be bringing a MazdaSpeed6 to the States. Turbo and AWD.
-Brian
-mike
Owen
2001/2002 models, let's see.
The 2.5l was standard on all models except the VDC and the LL Bean, which had the H6. By the the 2.5l was the Phase II EJ25.
When you shop, look for head gaskets leaks and check the front and rear main seals. An oil leak should be obvious, check for stains on the bottom of the block.
Subaru is covering the gaskets for 8 years, 100k miles, so you'd be covered anyway. But still, check.
My dad has a 2001 OB Ltd, my wife a 2002 Legacy L. Both have been perfectly reliable so far. Overall I'd say my dad is a bit more satisfied. We prefer our Forester over our Legacy.
Just my 2 cents' worth.
-juice
-juice
Am curious if any of you own one and any comments would be appreciated. I have a 04 XT now and know the step-down to a 2.2 eng. would be a shock.
But,if I can pick this one up for 4-5K I just might add it as a 2nd Subie ..
With that age maintenance and condition is everything, so check those out.
-juice
I barely noticed the difference in performance between the 2.2 in the wagon and the 2.5 in the 00 Sedan.
- Jim
-juice
Had the clutch replaced in my 99 Outback the other day after 135,000 km (about 85,000 miles).
A subsequent glitch was the failure of the clutch slave cylinder when it was suddenly asked to actuate the new clutch. Back to the dealer where I had a lengthy chat to the workshop foreman who persuaded me it was bad luck, not their fault.
Once I indictaed that I knew what I was talking about he got very chatty. The Service Adviser had mentioned that this guy was lead on the Subaru Rally Team cars, all of which were in the workshop at the time, including the Cody Crocker car which was in the dyno booth running hard. This is a fully set up unit with glass wall so clients (and a fair few of the staff) can peer in as the engineer tunes it electronically). Always amusing as the guys tuning WRXs always have that intense mechanical engineer look of real seriousness.
The converation with the foreman was interesting. He commented that he thought the 99-03 2.5 litre (might be 2000-004 in the USA) SOHC engine was the pick. Apparently whenever they get a 95-98 DOHC engine in, they insist on a head gasket change if not already done. Also mentioned the cost of a broken timing belt, which runs AUD4,000 to AUD8,000.
Oddest thing about the clutch change i that the removal of the accumulated clutch dust from the bell housing has suddenly made the starter motor very noisy. Gave me a heck of surprise the first few starts as I wondered if it was my car.
Cheers
Graham
What's the symptom of a failed clutch cylinder? Does the pedal stay down when depressed? Is it intermittent or constant?
Is it apparent I'm beginning to have a problem here???
Jim
The symptoms were the clutch sticking half way down and feeling very dead. Onset occurred in heavy traffic. Apparently this is fairly common.
Once slave cylinder replaced, feel returned to normal and no further problems
Cheers
Graham
Speaking of transmissions, my 2000 Legacy started grinding slightly going into 5th gear and 5th gear only, mainly going uphill. I had drained the MT fluid out and replaced with Mobil 1 recently. Apparently I had overfilled the transmission by about one pint. I had filled it to the full line, but the car was on ramps at the time so on level ground it was too much. Filling it to specs fixed the problem. No metal in the fluid, which is a good sign.
A lot of WRX owners switched to Mobil 1 only to find that it was worse. So many people were playing around with various oils, trying to find an optimum. In most cases, I think plain old dino 75W-90 worked out the best (which is what the car came with).
Craig
Jim
My take on it is, 5th gear is located at the back of the transmission case and going uphill(over a mile, 6% grade)caused an already overfilled transmisssion to flood the syncro blocker rings with more fluid than they could remove before I shifted.
It causes less stress on an engine to rev than to lug, so I use 4th gear most of the way up the mountain and then shift into 5th a few hundred yards from the summit. That is where the gear clash happened.
Symptoms included a wild, varying idle. The pedal was soft and inconsistent, and the clutch fluid (brake fluid) was low.
It's a pretty simple device, basically a rubber washer in a little metal cylinder. I agree that it could have happened independently of the new clutch. It is self-contained, so I believe that story.
Good news for me was it was a $10.74 part, and I did the work myself. I used a turkey baster and less than a quart of brake fluid, plus my wife helped.
Cheap repairs, gotta love 'em!
-juice
That is now ancient history. The Brighton model went away after MY2000.
Jim
Anyone in the forum has problems with the power ?
What are your symptoms?? Slow in general, or does it seem like the engine has a problem.
Craig
Yours might be down on power. Might be a good time for a tune-up, I'd change the plugs, plug wires, fuel filter, air filter, oil and filter, etc.
-juice
The 2000-2004 Legacy/OB did gain some weight, but not enough to make them "slow" vehicles. Not sports-car fast either, but plenty for most uses.
Did you always have this issue or is it recent?
Ken
