Ford Aerostar
I just bridged this block (effectively removing & bypassing this little refinement). No leaks now & the heater runs fine without it. The valve is probably there ( I'm only guessing this) to reduce flow in the heater core & prevent cavitation or un-necessary flow from gradually damaging the heater core & eventually leaking.
ATB Aeroman1 :shades:
I replaced the ABS/speed sensor in the differential. that helped for the first start engine stop engine cycle and then the problem returned after the next time I start the car and travel faster than 60 mph.
the mod must take the signal from the speed sensor and convert into MPH. It must then take that info and send it to the eec which uses it to shift the transmission and adjust inputs for the engine.
If I find something out I will post.
good luck.
Check the radiator fan clutch. It is supposed to "engage"
when the air coming from the radiator is too hot. It engages and drives the fan at the same speed as the water pump. When it is not engaged, it just spins freely. When the engine is at idle and the a/c is running, the fan clutch should engage after a few minutes. When it does, the amount of air blowing through the radiator fan shroud should greatly increase. You can even hear more of a roar as it engages. When you shut off the engine when it is really hot, the fan should be hard to turn. A bad clutch will allow the fan to spin quite freely. The clutches tend to leak the fluid out on the radiator side. I think my clutch failed about 140,000 miles. The engine temp would increase when at a stoplight with the a/c going full blast.
Not a hard job. By the way, is the fans shroud still intact? A partially clogged radiator could cause a similar problem.
Thanks in advance.
Jim
But the big problem is my slidingside door. Had to replace the latch assembly and have done this but can not get it to engage the pin so the latches will close. works when I have it off the door and have reinsatlled it 2x with no luck
any help would be appreciated.
http://www.autozone.com/servlet/UiBroker?UseCase=RG001&UserAction=processModel&P- arameters=026
It's as good a place to find free, detailed info as I've found. It includes step-by-step procedures and has more (and far better) diagrams than any of the Clymer or Haynes manuals.
Good luck, and please report back what you find.
:confuse: :confuse:
http://www.fordcds.com/
I understand that it is suspended at this moment (Run up to it quota limit) but next month.
HIH
This time after I cleaned it, It wont start up just by turning the ignition switch. I would have to step down on the pedal and then turn the ignition switch. After that it starts up and idles fine like nothing has happened. But thats not all. I noticed the it wont go into overdrive unless I floor it and it will stay in overdrive as long as I keep climbing speed. And while all of this is going on the Check Engine light keeps turning on and off.
I unhooked the battery to maybe reset the computer but I don't think it will do any good. I have it unhooked now and haven't tried it yet.
Anybody knows what could be the problem? Thanks.
Jason
Had the dealer check it and they did the same.
On the return to the dealership they found that the top track had cracked and required replacment. After replacement it works fine.
www.AutoZone.com
Click on the year and follow the directions to the place you need....ie: engine, electrical, etc.
Good luck.....
Part shows HP 1342 F29B-14A563 on inside. This hold the
electric window switches and the door lock switches.
just to add to the forum: I found a source of push-pins
for the Ford door interiors: Imperial part 37035. box
of 50 for about $19. www.imperialsupplies.com
thanks for any help.
Fred E Wahl
Question: Can I remove the Shaft from the rack and pinion and move it aside and simply replace the seal and re-attach the shaft.
Feedback greatly appreciated.
Question put a little differently: Pwr Str Fluid leaks where the steering column and the rack and pinion are are connected by a bolt. The fluid leaks out from between the Shaft and the seal.
Big Question: Do I replace the seal or do I have to replace the Rack & Pinion Unit itself. I'm sure I can do the project I just need a little guidance.
Thanks in Advance for any advice of any kind.
Spud7
Charles Ogle
There you can log in and find almost everything about ALL
vehicles.
The heat sucks too. The temp gauge never raises above "C" except for on hills.
The van is great you can pack in lots of crap in the back and still fit the wife, kids, dog cat etc.
30/70 torque split F/R normally and then 50/50 torque split once (rear, most likely) wheelslip/spin occurs. Will revert back to 30/70 within several seconds provided there is no wheelspin/slip in 50/50 mode.
My guess is that some one has removed your thermostat, or it has failed "open", it happens.
There is a recall for most Aerostars, check your VIN with the dealer.
I was sort of considering a manual transmission since some of the early Aerostars came that way. Was there ever an Aerostar AWD with the manual tranny?
My basic point here is, since this van has passed 120K miles, should I be worried about the transmission? How would I know when it would be signs for a overhaul? Can it fail at any time? :sick:
