Chrysler Town and Country EX/LX/LXi/Limited
1) Check Engine Light (Transmission Control Module replaced)
2) hard starting (TCM replaced)
3) After starting, dahsboard out, headlights flash, dashboard comes back on in 20 seconds (ignition switch replaced, wasn't returning to 'on' position fully after start)
4) When engine running, no power windows, radio, or AC (wiring harness replacement)
5) sliding and rear hatch power doors intermittantly do not operate (wiring harness replacement)
Scary, that this thing could run out to 16K miles with no problems and then suddenly develop all this. Only time will tell if it continues. I'm mentally preparing myself to dump this vehicle at about 28K miles if any other repairs of this nature are required. That would be a shame, since it's the nicest looking and driving mini-van we've ever owned.
--Bert
1. Avg mileage during the first 704 miles is a calculated 19.09 mpg on combined highway/city driving which I am very happy with. Can anyone tell me how much the mileage will improve after the engine is broken in?
2. The leather seats felt dry I assume because the car had been setting on the dealers lot for 5 months during the summer with the windows closed.. I used some MOPAR leather/vinyl cleaner conditioner and the feel impoved a little bit. This is the first car I have owned with leather seats and I would like to know if they are supposed to feel dry or is there something I can put on the seats to make them feel soft and smooth?
3. I have noticed that the AC symbol comes on and cold air blows out the upper vents when the car is cold and ATC is set to AUTO LO. After the car warms up the AC symbol goes out. Is this normal and does it mean the AC compressor is running when the car is started?
4. In looking at 03 T&C's on the lot I noticed the EPA highway mileage on the window stickers increased from 24 to 25 mpg. Does anyone know what changes have been made?
This van drives very smooth and quiet and I love the ATC, Leather Seats, Steering Wheel Audio Controls, Power Doors and Power Tailgate. Never had a center Console before but starting to like it and find it very useful. Van has the tire pressure monitoring display which only tells if the tire pressure is below 28 lbs or above 48 lbs and how many tires are out of that range. The Chrysler 300M which we also test drove displays the actual pressure on each tire which I think is a better system but probably cost a lot more. I have previously owned a 95 Grand Voyager LE with 87,000 miles and a 98 T&C LX with 50,000 miles which I still have. No problems have been experienced with the engine or transmission on either car but I do have them serviced regularly at a Chrysler dealer to insure the proper transmission fluid is used. Thanks for any answers you can give me.
Many people find their mpg increases bit by bit for the first 10,000 miles or more. Sounds like you are off to a good start there too.
Lee B.
Also installed an interior auto-dimming mirror (ala the Limited model). All the wiring was there in the headliner by the overhead console. Just plugged it in and it works.
Want to install the auto headlight switch now (ala the Limited model). Waiting to get my Service manual first to check on the wiring.
Re: 1037 & 1095. I broke 24.5 once but normally see 23.5 on the highway.(over 65 mph )
If your are checking your gas milage try using a name brand such as Mobil or Sunco. These other brands have givin me poor molage.
If you cant see 23 to 24 onthe highway, pull the spark plugs and check that the gap is at spec.
Had my Volvo S-80,T-6 in for 30,000mile service and $459 latter they had cut my gas milage from 29.5 to less than 26. I pulled the plugs and they were set 6 to 10 thousands to closed. After
adjusting them and reinstalling them walla 29.5
Re 1079 sticky steering wheel. Check your wife if she is like mine she uses hand lotion. The steering wheel in her car is allways tacky.
griffman
ditto. My 2002 AWD T&C performed brillantly. NO problem going or stopping.I got a good laugh watching the new BMWs with stability control spinning their wheels helplessly.
Ed
Hope you get a perfect repair job and no further incidents.
Lee B.
Lee B.
My second minivan is a 98 T&C LX which I still have. This van currently has 51,000 miles with no brake problems. When it was new there was a slight vibration in the steering wheel when braking from 70 mph on a downhill interstate exit ramp but that appears to be gone now. My driving has been about 50% highway 50 % city. Maybe I have been lucky but I have not experienced the brake problems others have reported. My new 02 T&C LXI brakes are the best I have ever had on any car I have ever driven. They are very smooth and quite and stop on a dime.
Now my lift gate only works part of the time. It will make the beeping sound, start to open (maybe ¼"), then close. ~~ Also while driving all the dash lights (seatbelt, check eng., etc.)will come on for about 20 seconds, then go off again.
I'm due for an oil change in about 1,500 miles so will have it checked out then... but wanted to know if anyone else has had simular problems.
Needs to be scanned with a diagnostic scan tool - DRB III to identify the problem component.
A good reason for the original or extended warranty for sure. The power sliding doors are even more complex!
Lee B.
Thanx
Lee B.
I am sure the information from the board is more accurate than the dealer.
Polk Automotive Loyalty Awards
We have noticed the right-side sliding door is not closing completely sometimes (1/4 inch bump out at the rear) which results in the door not operating via the remote or control panel. We are trying to isolate the problem this week before we take it in to the dealer to make sure we are not doing something wrong. Any ideas out there? Anyone experience something similar with the sliding doors?
Also, are there any other sites out there for T&C owners? This one is great but I crave info for my new T&C. Thanks, Jay
I'm guessing your slider is out of alignment somewhere - probably the latch. Should be an easy fix (touch wood, LOL).
So heads up with belt noises. That's how mine started and that's all I thought it was.
I think I have finally decided on which minivan is best for my family. I want to get the following:
Make/Model: 2001 T&C Limited
Miles : less than 30K
Color : Gold
Options : Split rear bench, TV/DVD system
Now all I need to do is find one. I had an idea and thus am posting here for advise. Does anyone know how to get information on leases that will be returned this year? I would love to talk to someone that is planning on returning the van I am interested in and buy it from them at a fair price (more than what the dealer says the residual is but less than what it will be marked up to in the retail market). I would be willing to pay between the trade-in and private party price as described by Edmunds TMV. I hope this turns into an easy win/win for both parties.
If anyone has any leads for me, please let me know.
Bo
and one most people don't know about (pick one up, drive it see if any problems show up, and then buy it?):
Lease Trading
Since lease returns often wind up at auction, you may be able to get a broker to pick one up for you.
Also try the Lease Questions - Ask Here discussion. Good luck!
-Adam
Keep 'em shinin'
Lee B.
Just an insurance policy but......Problems with the complicated power side doors, power rear door, A/C systems will cost you a bundle after your 36/36,000 mile warranty is up.
I've never used either of mine yet but I have another 3 years to go on my vehicles.
I live in a hilly area.
I replaced my brake bads with Bendex ceramic pads
and it took care of dust problem and it lasts almost forever.
Besides ceramic pads are quiet and comes with a lifetime guarantee.
I had to take my 97 with 140k to the glue factory and just picked up a 03 T&C Limited last week.
700 under invoice with 0% for 60 months.
Good luck with the new T&C and thanks for the info on the brake pads. One thought - do they squeal? I'll keep the Bendix ceramic pads in mind but hopefully with less than 4000 miles on both my T&C Limited and my Sebring convertible Limited, I won't have to use them for awhile.
Lee B.
