and dont open them till you complete this process put the key in the ignition and start the car when the car dies leave the key in the same position that would be the run position for at least 10 minuate then cut the key to the off position this procedure should reset your theft system then try to restart the vehicle if the car still dies and the theft light is still on then the tumbler my be bad thats where the theft module is located that what i was told at GM service but you needs to call GM service just to make sure of the location you can get a tumbler with key at a salvage yard for about 30 to 40 dollars hope the first procedure works for you and if you get a tumbler with key you will probably have to do the procedure to reset the theft security system with the new tumbler
michael knox tn
Problem: Engine light came on about a week ago,( i have been worikng on it this long),
I took the car to an auto parts store to have the code read. it said that # 2 had a misfire, ok fine what could this be, i said to myself, also asked the tech at the store. "It could be many things" lets start with the easiest and cheapest. I replaced the sparkplugs, same thing, replaced both of the coils, (one tested bad), it drove for about 20 mles and the light came on again. back to the store, had it read, this time it was multi cylinder misfire asked this tech who did the the test, (different guy this time) he was dumber than a box of rocks and could not tell me jack, absolutley no help whats so ever. :mad: ok back to the problem, so i go home and look through the repair manual and did the all test like it said and came up with the idi ignition modual bad.
So i went to the auto parts store and had it tested, it ran through 6 test and failed it twice, bought a modual, installed it, drove less than 10 miles, and it is now misfireing again. every time I replace a part it will run like this: starts good, sounds good, drives good for a short distance and repeats this vicious cycle. what i have not replaced yet, coil cover, and the what would be called plugwires, and cranksensor. so far I have sunk about $250.00 in to this ill fated atemp to repair this, hit and miss and test and replace cat and mouse game.
Oh yeah, everytime i replace something i remove the negitive battery cable first and it is the last thing i put back on before i start the car. what do you think i need to do now? :confuse:
thanks in advance,
Vern.
You might want to try the Got a Quick, Technical Question? discussion also ... good luck!
Mike
Hope this gives you some hope, look around cause I know I saw the anti thief article on this site somewhere.
I have 2000 Pontiac Grand Am SE 3.4L V6 with 71K miles. When i'm driving for a long period of time the car will cut off. When it cuts off the battery light comes on along with the oil light (i think this is natural because the car has cut off) It then has to coast over to the side of the road. I try restarting the car and it doesn't turn over. I have to wait about 10 minutes and then it turns over fine. My Battery charge is fine, my friend is a GM mechanic and listened to the alternator (by putting a screwdriver with his ear to it) and said it was fine.
The symptoms before cutting off is that about a minute before the car cuts off it stops responding, i step on the gas and it gives me little if any power to the engine. Also, recently my A/C and Heat won't work unless i turn the knob to 3, it doesn't work on 1 or 2 but works on settings 3-5 fine. I'm thinking it may be my fuel filter but i just had that replaced 6 months ago.
If i drive the car steady for about 40 minutes it cuts off, it seems to not cut off as much if I drive at a slow pace, accelerating slowly and barely going the speed limit.
I don't know what to do?! I'm trying to get some advice, I don't want to take it to the dealership without some advice, because they will try alot of everything and fix a lot of nothing, then charge me for it.
Recently while driving the radio, windshield wipers, and other accessories will stop working. After researching I found that turning the gray surround (around the keyhole) will restore everything. I though it could be the ignition switch going bad but none of the accessiores will come back on if only jiggling the ignition switch (with car running). I must turn the gray surround around the switch in either direction for things to work properly.
Don't want to tear into steering column to replace ignition switch if that isn't the true problem.
Any ideas will be appreciated.
~*Taryn*~
