GMC Safari/Chevy Astro
1181921232435
    billszcarbillszcar Member Posts: 3
    I am having the same problem with my 94 safari awd. I have replaced the fuel pump, fuel filter, spark pluges and wires, cap and rotor, air cleaner, IAC valve (idel air control) and still having problems. It seems to run fine when it is cold. But as soon as it warms up it starts to try to kill and then it will rev up to keep it from stalling. Then it gets even worse! When I try to excelorate or the van is under load like (Going up hill) I have to feather the throttle to keep it from stalling! And believe me it stalls all the time! so if any one out their knows what could be the proublem, PLEAS LET ME KNOW!!!!! Very frusterated! Thanks From billszcar@hotmail
    my 94 safari awd. I have replaced the fuel pump, fuel filter, spark pluges and wires, cap and rotor, air cleaner, IAC valve (idel air control) and still having problems. It seems to run fine when it is cold. But as soon as it warms up it starts to try to kill and then it will rev up to keep it from stalling. Then it gets even worse! When I try to excelorate or the van is under load like (Going up hill)it will chug! I have to feather the throttle to keep it from stalling! And believe me it stalls all the time! I ran the diognostics and the codes are 32(EGR), 35(IAC VALVE)and 85 and have know idia what that is. So if any one out their knows what could be the proublem, PLEAS LET ME KNOW!!!!! Very frusterated! Thanks From billszcarhotmail
    nashdnashd Member Posts: 5
    From what I've read here I assume my problem is a bad thermostat- Is it inside a hose? can anyone please tell me where to find it on the engine so I can replace it? Thanks
    gmeerschaertgmeerschaert Member Posts: 7
    I need to replace the drivers side exterior door handle. It's been awhile (and a body version) since I've had to do this. I have a '98 Safari. Any ideas on how to best get access to the nuts inside the door. I looked and they are barely visable, much less accessable. Will removing the doow latch help any?
    momneedshelpmomneedshelp Member Posts: 6
    hey thank you guys so much with the heater problems. now i have another heater related problem. i have a rear heater in my 90 Safari. it was disconected prior to me buying the van. now the hoss going to it are leaking in the front (by the blower motor under the hood). is there a quick fix to this or do i need to replace the inlets that they are connected to. i thought i blew a brake line from the amount of liquid on my driveway. but i looked at the brake fluid and it is fine.
    also my van is hard to start for the first time in the day (morning or afternoon) and when it does finally start after i pump some gas into the lines it blows smoke BAD. any ideas would be greatly appreciated. or is this normal for an older Safari?
    P.S. I LOVE this site thanks again for the help
    cobcob Member Posts: 210
    The thermostat is under the gooseneck that the upper radiator hose goes into on the front of the intake manifold. It is right in front when you open the hood. Only have to remove the air cleaner assembly and MAF sensor to gain access. Remove the hose and I believe there are only 2 bolts holding down the gooseneck. The thermostat has a rubber seal around it so there is no gasket to scrap off and replace under the gooseneck.
    unspun01unspun01 Member Posts: 2
    I had the same problem as you did. I was driving when all of the lights in my vehicle started to flash (like signal lights), and my voltmeter was pulsing too. It didn't look like the alternator was charging the battery either.......
    The problem is an easy fix. At first, I thought it was my alternator or battery, but they were both ok. When I went to re-install the battery, I noticed that the connection terminals behind my battery at the firewall were corroded/rusted. I loosened all of them and cleaned them. I had to replace one of the fusible links because the wire was so badly corroded (the fusible link was actually still good, but the wire was damaged right up to the link)
    After cleaning the connections and replacing the fusible link, everything works great.... BE CAREFUL NOT TO SNAP OFF THE RUSTED STUD. I would use WD40 on a stubborn rusted stud.
    Good Luck. Hope this helps.
    yak54yak54 Member Posts: 72
    I have a problem with my 1999 safari that i hope someone can help me with. The van will start & run great but when you accelerate down the road ther is no power at all. If you stop & put it in park & try to rev up the engine it will not rev up. The van has 170,000 on it & has been fine . I have replaced the fuel pump @ 100,000 & 2 ignition coils & 1 transmission. Also the gas guage goes around in circles like the second hand on a clock. I think it needs anouther fuel pump im not sure.
    Sound like the EGR valve to me. Had one go bad ages ago in a different vehicle, but the exact same symptoms.
    Thanks to cob for the INFO! I got the thermostat and will attempt to install it after work tonight. Its has been a very cold commute lately! But now there is a new problem, fellow Safari people- My driver and passenger doors will not latch! Just out of the blue- I'm bewildered- any ideas?
    As per message #1171 I have an update! Be for I mentioned that the van ran like total "[non-permissible content removed]!" Now it dont run at all! I have gotten it to start with Ether, but as soon as the Ether wares off, it dies. So.... That tells me I at least have spark. The Fuel pump seams to be working and like I said be for, I replaced the fuel filter. Fuel Pump, Plugs, Wires, Cap, Rotor, IAC Valve, And Filled the Tank to the brim. Is their some kind of sensor that would cause this Nightmare!? Or is their some kind of fuel injector that would cause this or what?
    Thanks Billszcar.
    rigsbyrigsby Member Posts: 1
    Rotate Armrest to upright position, push inward and rotate to back of seat and pull out.
    billtr45billtr45 Member Posts: 2
    My drivers side power window which only goes down about an inch at a time. Did you find out what the cause was?
    My drivers side power window which only goes down or up about an inch at a time after waiting five minutes. Does anyone know what the cause maybe?
    geoffexcaliburgeoffexcalibur Member Posts: 2
    Hi, can anyone point me to where I can find the engine number?it`s a 95-96 v6 vortec in a safari,is it on a plate,part of the vin number or on the engine if so where.
    Thanks geoff
    Hi,I had the same problem had to renew the motor $35 on ebay
    bendeckbendeck Member Posts: 1
    Reply to sluggish window,Your Power window motor must be replaced i have had this happen to me at least 10 times with astro vans & safari"s. aloha, charlie.
    md333md333 Member Posts: 2
    I think the wiper board was a recall. I have a 97 and got a letter so you may want to check it out.
    dannyg40dannyg40 Member Posts: 3
    Hi Everyone. I been looking for a Astro/Safari for a few months now without any luck. Everyone wants a fortune for these things even for a vehicle with 150,000 + miles.Im not looking to spend a fortune casue its mainly for a second vehicle, just for an ocasional pleasure cruise. The nearest thing I found to a good deal is a 1995 for $2000. There is no rust anywhere, it is a kinda dark blue ext. conversion van with a dark blue interior. The interior is not to dark, but the dash is and the res is kinda med. to light blue. Everything works on the van, the interior is pretty clean except for the wear on the original seats. They do have nice custom covers on them though. Its from a dealer who I kinda trust. I looked up the vehicle on carfax and it was an original 1 owner van. The dealer told me everything about it. The only thing wrong is it needs a set of tires really bad. I can get them for about $280 installed new. The master cylinder has a small leak, not sure how the setup is cause Im not familiar ith the power steering/ power brake combination setup. The van has originally 138,000 miles and the dealer bought it from the original owner last month in the middle of January. The dealer changed the instrument cluster cause the speedometer needle broke. The odometer worked, but not the speedometer. The van runs really strong and there is no rust anywhere on it. The dealer had the title issued to them with the odometer exempt note on the new title, so I think I can trust knowing it wasnt intentionally tampered with. Any input on what you guys would do ? I cant find anything around here even close to what Im looking for. I found 1994's and 5's with 150,000+ miles and they still want like $4000 for the van. Oh, one small thing to.... the spring return in the shift selector is broke or something. It shifts perfect, the handle just dont have that "spring" back action when you let it go.
    machicjmachicj Member Posts: 2
    i bought a '99 astro a few months ago, NOTHING BUT PROBLEMS SINCE!!! FIND SOMETHING ELSE... :mad:
    schhiiischhiii Member Posts: 1
    Have a rattle in the dash, sounds like a loose defroster/AC duct,or, body shop dropped a screwdriver etc in there.
    Puled cover/defroster grille - all tight there.
    Car was in minor accident, left fender replaced, so warranty work not an option.
    Any one have a manual/drawing on how dash is removed or how you get access to this area?
    Thanks, Roger e-mail: avtrdinc@aol.com
    mib4ukmib4uk Member Posts: 5
    I have an '02 Astro AWD that jerks when turning. Feels like something is hanging up or getting in a bind. Feels to be coming from rear of vehicle. Does it turning left or right. The tighter the turn, the worse it is. Only does it in forward, not in reverse. Only does it after about 15 minutes of driving, not when cold. Rear end was completely rebuilt in August '05. Problem started December '05. Shop says there's nothing wrong, just drive it. They do recommend replacing shocks which are weak. Any help is appreciated.
    Dannyg40,
    I am on my 4th Astro/Safari. Had a great time with three previous used vans. ('91 Safari, '94 Safari, '98 Astro AWD, and now an '02 Astro AWD) We have had the '02 since August and have replaced coil, distributor and rotor, had rearend rebuilt, and a new battery. Aside from the rearend, the others were probably overdue for replacement. Still having probs with drivetrain jerking. We purchased a warranty with this van, and I'm glad we did. If my wife hadn't wrecked the other three, I wouldn't be on my fourth one now. We love them, and I recommend them, but do your homework before you buy, and consider an extended warranty if possible. One major problem and it will pay for itself. See if the lot will let you have the van checked out by a mechanic you trust. Best Wishes.
    robbytrobbyt Member Posts: 1
    i have a 2001 astro with 70,000 i would like to put a sway bar on it and a bigger exuast and cat is there any advice on this matter and what should i look for to start having to replace in the near futer thank you for any advice i get
    anitlocanitloc Member Posts: 1
    I have a 2000 AWD Astro that was doing the same thing at about 80,000 miles. I thought it was the rear end locking up. It was a chattering feeling including tire chirping in sharp parking lot turns. Turns out that it was the fluid in the transfer case.
    Change the fluid in the transfer case.
    Use only the GM fluid. The dealer where I got mine called it "Smurf Juice", because it is blue. The change is easy to do. Pull the drain plug on the back of the transfer case at the bottom edge, drain fluid, put plug back in. Remove fill plug above the drain plug, (make sure the van is level), then fill the transfer case until the fluid drips out of the hole. Reinstall plug. No more chattering and it will cost less than $20.
    hansiennahansienna Member Posts: 2,312
    Has any Astro or Safari owner had a door handle replaced lately?
    My daughter's 1991 Astro RS has a broken driver's door handle. I have heard it costs about $100 for the handle and labor to replace the handle at a dealership. The handle itself costs about $48. Is this correct?
    With 213,000 miles on the odometer, a person can expect a few minor repairs. The transmission performs flawlessly even with all these miles.
    Dear hansienna- with current shop rates- that's really not that bad of a deal. The cheapest way is to get the part at a junk yard and install it yourself- I thinks its just 3 bolts on the side- is it broken or siezed? - Nashd
    THANKS....The bottom part of the handle has cracked and the outer frame of the handle has a crack. It will still open and close but is getting more difficult.
    She loves the HUGE interior space of the Astro with the large 27 gallon fuel tank and decent gas mileage. The Astro is not as long as my 2002 T&C LX but has much greater interior space.
    I would have considered an Astro/Safari if GM had done something to modernize them after they were introduced as 1985 models in late 1984.
    Although the Explorer is an SUV, Ford has continually made improvements. The Explorer is a very nice, quiet, comfortable truck based vehicle. The Astro/Safari would still sell in large numbers had GM been as smart as Ford was with the Explorer.
    antiloc,
    Thanks for your reply. Your symptoms of "chirp" and "chattering" sound familiar. Before I had the rear end rebuilt, I added fluid to the differential. GM told me to use Synthetic Axle Lubricant 75-W90. I did. Later when the rear end was rebuilt, if I remember correctly, the guy told me that any lubricant was sufficient, therefore leading me to believe that just "any" lubricant was used and that just "any" lubricant is NOT sufficient. I will investigate this issue. Thanks again for your help.
    mib4uk
    stan7stan7 Member Posts: 7
    Local dealer can't. Astro with 150K. Hard to start, cold, takes a couple of pedal pumps. While hot or cold, car stutters like it running outta gas for a couple of seconds. Then it's fine. Little later stutters again. Especially going up a grade. Ignition coil, d cap, rotor, and fuel filter have all been changed. Note - the fuel filter was 99.9% clogged! Computer doesn't know, Chevy mechanics don't know! I had a new fuel pump installed 40K ago. Dumped some f injection cleaner a tankful ago. Any ideas before they take me to the cleaners trying this and trying that?? New c converter? New spark plug wires? Hmmm....
    bsmoodhabsmoodha Member Posts: 17
    This might or might not get to technical but here we go. All my info is out of the Service Manual. The fuel gage system works on the variable resistance principle. The VCM ie: computer sends out voltage to the variable resistor in the tank ie: sending unit, the voltage goes through the "float" then to ground. First disconnect the 6 or 8 pin connector that is just forward of the fuel tank. It is the one that also powers the pump. Go to radio Shack and buy 3 resistors, 1 a 40 ohms another 100 ohms and finally a 200 or 250 ohms. Then on the "chassis half" of the previously disconnected connector put the 40 Ohms resistor in series with pin "B", it should be the purple and white wire, then to a good chassis ground. Then turn the key to the on position. The 40 ohmn res. simulates "Empty" then sub. the 100 ohmn res. for the 40, the reading should go up to about 1/2 full indication. Then sub. in the 250 ohmn res. that one will simulate full. If you can't find the exact ohmn res. just figure that 40 will give you empty and 250 will giuve you full and interperate what reading you do get with what resistors you were able to find. They make a special box that you can dial in any resistance you want insteard of buying individual resistors...If the reading are all good using the resistors but when you reconnect the connector the gauge goes wacky it is the sending unit ie: float assy. in the tank..if not it could be the gauge or the bigger bummer it could be the circuitry in the VCM ie: computer, front left under the hood.....there is a way to chech out the VCM unit....
    Hi guys, I been away for a while. I did buy the 1995 Astro I was looking at. I got it for $1800 and it is clean. I looked at a bunch of other ones that were in rough and abused shape, and they wanted like $3500 + for them. Im pretty happy with this one so far. I just been a little busy going through everything as I get time. I purchased new tires for $240, new front pads and I repacked the wheel bearings for $25, new left side Idler arm for $40, new stereo and speakers for $240, changed the oil and other minor things that have been neglected. The 1995 2 volume shop manuals I won on Ebay for $20 should be here by Friday to. Other than that she rides nice, looks good and Im pretty satisfied with it. My poor 2000 Ford Ranger been sitting in the garage getting lonely lately.........
    fixitrodfixitrod Member Posts: 67
    After upgrading the shocks(front and rear) and lubricating the front end this 1995 Safari with 250K is displaying nonresponsive steering, i.e. not smooth , won't return to center without some active assist, Its turning but it is like the ratio is not 1:1. Fluid level in power steering resovoir is OK however I tried topping up and it improved for a while. Could be coincedental to the front end shocks and lube. I did notice that the grease I used was a different color than what was in the parts. Best way to describe this feeling is the steering wheel is "sticky" while turning. Any advice would be helpful. I've heard suggestions of Steering rack?
    jackbakjackbak Member Posts: 1
    Hi all have 89 v6 astro 140000 mi was running great
    changed oil now white smoke pours out of the exhaust
    not sure what to check. any ideas Thanks
    White smoke is usually water in the exhaust. Probably blown head gasket. Check compression on each cylinder and coolent level.
    musclecarguymusclecarguy Member Posts: 2
    mbcabbie - I'm having the same problem with a 97 GMC Safari AWD - occasional headlights flickering, airbag light, and speedometer wavering. I haven't found the solution yet so I would appreciate any ideas too.
    I also have a remote start unit that recently started acting up. It starts and runs the vehicle fine, but occasionally it doesn't turn on the accessories (heat or a/c) and at the same time the airbag light is lit. Once I disable the remote start unit (hit the brake) the airbag light goes off. May or may not be related? Appreciate anyone's help!
    (van has 65K orig miles, on transmission #2, #1 went at 37K, on fuel pump #4)
    baldwin4baldwin4 Member Posts: 3
    I have a 1997 Astro with the Gladiator conversion. The rear 3rd seat has electric to fold the backrest down into a bed. It quit working the other day. When I push the button to recline it, I get a clicking sound from a small electrical box/relay box. Can anyone help me on this or tell me where I can get parts to fix this?
    Thanx
    baldwin4
    yamyyamy Member Posts: 3
    I have a 97 Astro that the ignition coils only seem to be lasting about 2-3 months. It starts off with random misfires now and then and then random misfires all the time until I change the coil then it goes away for awhile. The scanner shows that # 3 cylinder usually has the most misfires but not all the time?
    I just happen to have a similar conversion van 1997 by Glaval. My back seat did the same thing. If you go to this web site link title they have a parts catalog that will have the power couch controller you need to replace. It is inside the plastic black box on the back of the couch frame. It runs about $80 and takes 5 minutes to replace. Just a couple of wires and screws. In the meantime you can reverse the 2 plugs on that box and the button to raise the couch will now lower it. You then have to reverse the wires to raise the couch again. Unfortunately I bought the new controller 2 years ago and now it has gone out again losing the down function. It looks like there is something electrical in the van that is causing the circuit board to go out. As a side note, do you have the rear air/heater that is installed by the conversion company? If you do, does yours blow cold and hot air when the fan is on? Does your temperature control for the main dash air/heat control the rear temperature? Just wondering since mine has never seemed to work. It blows warm air all the time.
    My 95 Safari(259K) started steering "funny" after replacing the shocks...this may be unrelated. PS fluid was not low but I topped anyway and it seemed to improve but was temporary. Steering seems to stick , won't return and van response is scary actually. Could this be anything other than a PS pump going bad. All suspension and steering are tight. One comment was about the rack and pinion??
    tmcdougalltmcdougall Member Posts: 3
    I have a 96 safari van with 120 kms on it it has a misfire at hiway speeds comes up with a code 341 camshaft position sensor anyone with any suggestions or has had this prob can you email me cyberheed@hotmail.com many thanks
    It's past time to replace the plugs on my van. I remember the last time I did this. I just went in from he top. Lots of cuts on my hand, nasty position, etc.
    Any tips on a better way to change the plugs? I really don't want to go through what I did last time, and I don't feel like paying a mechanic to just change plugs.
    On my 1997 I took off the front tires and removed the plastic mud flap from the inner wheel well. Be sure to get new xmas tree clips to replace the ones you cut off on the flaps. This allows you straight access to the plugs on the passenger side. On the drivers side the brake lines run along the frame rail so you have to work around them but it is alot easier than going in from the top. The back plug on the drivers side is the most difficult but, job only takes about an hour.
    The red light on the PRNDL pattern only works in R,N,3,1 and flashes sometimes in D. Sometimes when I put it into D the red light shows up on the 3 then goes out after a minute. Has anyone else had this problem? If so what does it take to fix?
    I have a 1996 gmc safari it has a misfire at hiway speed comes up with a code 341 camshaft position sensor anyone with ideas
    iteachbditeachbd Member Posts: 1
    Hi everyone,
    I am at my wits end. Lately in the morning if I do not warm my 98 safari, it will not accelerate when i hit the gas. Naturally, I allow it to warm up. Today, driving long distance it happened several times almost causing me to get run off the road and rear ended. The car was not cold. When attempting to accelerate to enter the expressway it took an excruciating amount of time for the van to get to 60 causing a semi to run me onto the next entry ramp. It would also occasionally lose speed down to 60 and take about 30-60 sec to get back up to over 70 again. During this time the security light was on. I have NO IDEA what this light is for.
    Apart from this whole problem, my electric locks are going nuts and I had to take the fuse out to make them stop locking/unlocking constantly.
    ANY HELP WOULD BE WONDERFUL!!!!!
    The catalytic converter has already been replaced.
    thank you thank you thank you thank you thank you
    Kerrie
    It sounds like the electrical problem you are having with the door locks may also be effecting the security system. The security light coming on usually means that the computer is not recognizing that the key you are using is the correct one for the vehicle. I believe that it causes the ignition system to shut down. In your case it appears to be intermittant so the van is running but, not correctly. You will probably need the help of the dealership for this problem.
    themouasthemouas Member Posts: 1
    What you have is a timing component wear, from the timing chain to the camshaft gear and distributor gear. You will need a scanner to check for this condition, you need to check the camshaft position sensor data. I believe the sensor has an operating window of +18 degrees to -18 degrees, when the sensor is out of this range it will flash a code for the cam sensor. To correct this problem depends on the mileage of your vehicle, I do not know what the manufacturer recommends but I recommend removing the distributor and advance the distributor a notch and check the data on the scanner to see where the sensor data is. If it is not more than +18 degrees, I'd leave it there and clear the code and it should be OK, and if not I've cut notch on the distributor hold down on mine so I can rotate the distributor like you're adjusting the timing to bring the sensor to zero degrees, mine ran great after that. About the misfires, if you remember several years ago Chrysler built a car that had a bad rotor design in their four cylinders that caused a lot of head aches. This time I believe GM ate it, there is a vibration in the Chevy Astro Van distributor shaft that is enough to cause a wear between the rotor screw heads and rotor. Given it time, the rotor will wear and come lose and start to oscillate and cause a random misfire on all cylinders, but one or two cylinders will usually miss the most. Coil will sometimes go bad, I recommend tightening up the distributor rotor screws down a little bit tighter than normal to reduce this propensity.
    Hope this helps,
    Chris
    garyvolgaryvol Member Posts: 15
    I’ve got my 98 Safari almost electrically hooked up for towing my pop coleman camper. This camper has electric brakes so it has the 7 pin bumper round plug. I’ve towed this camper before with my 91 Safari, but had to replace it with the ’98. I never looked to see where the brake wire on the ’91 attached to. The camper place did it for me. I’ve got a new brake controller installed on the lower part of the dash, ran the power wires ready for hookup to the battery. Also ran a wire from the brake controller area to the back bumper 7 pin plug for the brakes to the camper.
    Now I’m searching for the brake lite switch on the brake peddle so that I can splice into the cold side of the switch for eventual connection to the brake controller.
    All I see is a multi color row of wires (about 6 of them). Any one know where the switch is located on the brake peddle.
    -gary
    gebby1gebby1 Member Posts: 1
    I have a 95 Astro with approximately 100,000 miles on it. The van runs great but recently after an oil change I began to hear what I believed to be lifter noise. I have been running Mobil 1 10w30 oil. It was recently changed with 5w30 instead when the noise began. I thought that it might be the oil so I changed the oil and out in Mobil 1 10w30 with Lucas oil treatment. It did not seem to solve the problem. The noise seemed to change about 4 days later and sounded worse. I pulled the valve covers and cannot find any loose rockers even while running. Also the motor carries great oil pressure and does not flucuate. The oil pressure seems to indicate that it is not a rod, or is it? It sounds like it is in the top of the motor but I have not yet found it. Anyone have any ideas?
