Wow! and thanks for the key info as well .... Maybe I'll attach a brick to the spare set to keep it from getting lost ... it'll look like a gas station restroom key.
Has the dealer given you any indication that this is something they've seen before?
What problem are you having with rear visibility? Both my wife and I have absolutely no visibility complaints (and there is over a foot height difference between us, so physical limitations can't be the culprit - but it does make that memory seat a well-loved option by us).
I drive a '93 850 that has given us absolutely no problems since the day we got it six years ago. Knock on wood, it's as reliable as our last Nissan they just traded in on the new Volvo.
If so, how is that car on power? There are many times I suggest to people to look for a used S70 since I think its such a great bargain, but the biggest bargain is the non-turbo'd. I just never drove one to see if its got any get-up-and-go.
If you have a $6K car, I can only imagine you have a stripped version (base engine and cloth seats perhaps?). That is death for any luxury car. Yeah, this model has low resale from new compared to other luxury imports. Its a shame, but its just how things go sometimes. Now you know how all those American luxury new car buyers feel.
as far as your repairs go, how much did it cost you? Headlight bulbs certainly aren't expensive. Timing belt is a repair cost associated with ALL cars with a timing belt. Did the abs sensor failure happen under warranty? What did that run (just so I have an idea if it ever happens to me)?
Anyway, I understand basic maintenance, but the prices were nuts. Headlight bulbs - in 72k we've replaced 7 at $20 each. Timing belt $700. Abs sensor $1600 (not available a la carte...). Front door panels both replaced under warranty, now need replacement again.
We're just discouraged. Our next european car (should there be one) will be used, so as to let someone else take the depreciation hit.
Checked the Carfax and it looks clean, one owner, Florida lease. It did mention a police report of an accident in 2000, but doesn't mention the severity of the accident. Should I be worried about this? What is a decent price for this car?
Would current S70 owners recommend it? I'm the mom of a 19-month-old, so safety and longterm reliability are most important to me. Should I consider purchasing an extended warranty? Thanks in advance for any advice...
Now, just to point out a small detail, I purchased Phillips high-intensity bulbs for my '98 for $7 each. So you really got hosed at $20 a pop. I can see how that would be aggravating when you have to pay that much each time.
Edmunds says the TMV for a private party sale is $16, 800.
Kelly Blue Book says the car is only worth $15,500 even at this ultra low mileage.
What kind of offer should I make him?
Is this a problematic car? I'm used to driving only Japanese cars.
As far as it being problematic, you will get varying opinions, as is the case with all cars. Personally, I've put over 30K miles on my used T5 and haven't had as many issues as I've had with cars like my Toyota 4Runner and Subaru Forester (both of which score much higher on any published reliability scale). I think the benefits of driving this wonderful car far outweigh the little nagging blown lightbulbs issue or the occasional check engine light (which always turns out to be a gas-cap leak issue and goes away after a week or so). Oh, I did have an oil leak, but it was fixed under warranty.
But I would check with him and make sure the maintenance bulletin concerning the lights has been fixed by the dealer (if not, i'm pretty sure the dealer is still required to fix it).
The miles on the car are too low, in other words there's no market mechanism designed to calculate a fair price for that car.
Private party I think $17,000 is probably right on.
$18,000 is all the money and then some.
$15500 for a private sale is too low.
And I'm just using Edmunds numbers here.... shopping around has proven to me that the real world commands even more of a difference between the T5 and its lesser counterparts.
Anyway, the guys over on the real-world values board hit this as a $16K RETAIL vehicle. Pretty brutal. So seems like something more around $15K private party is more than fair.
you mean when the car is running, but in park, you can't turn the lights on?? That is extremely odd. I have absolutely no clue what that could be. Sorry.
next time it locks up and you have some various electrical components not working, try jiggling the key inside the lock cylinder and see if it comes to life. if it does you've most definitely got a faulty ignition switch, the electrical part on the backside of the lock cylinder would need to be replaced, and no its not that difficult to replace. Also, for you folks still experiencing the constant headlight bulb replacement, check to see if recall 101B has been performed on it. It affected all S/V 70's 98'-00'. It seemed to have cured most premature headlight bulb failures. Basically its a resistor kit between the connector and the headlight itself. Just my 2 cents worth!
Just wondering if anybody out there has other suggestions (such as gbrozen's timing belt suggestion) regarding what we should be anticipating in terms of maintenance, upkeep, etc.
Actually, the bulbs mine originally came with are still good. But I did replace them with Phillips blue bulbs. Those blew out within a year and I put the original ones back in. They are still fine. Go figure.
Don't remind me of the timing belt. I'm up to 66K miles now and the timing belt replacement cost is looming. I might end up doing it myself. Yikes!
so you're pretty sure that all the S70s had the same rotors? Well, I guess I could always suffer reselling the ebay ones if they are wrong. Or maybe I could talk a parts supplier into taking them in on exchange (doubt that one).
I hate to ask, but could you possibly check with a tech in your shop if you're not positive? I'd appreciate it. I know that rotors have to get replaced often on these cars, so I'm sure someone knows off-hand.
on this same topic, any real advantage to going with cross-drilled rotors? Same seller has these up and still says these are only for S70s with 15" wheels. I know they are supposed to help with brake fade, and that's really not a concern for me. I would, however, like firmer brakes. Mine seem to take quite a bit of pressure to get them biting.
I checked this car out in CARFAX and it looks okay.
I checked the bluebook and based on mileage and option it rates the retail value at $18000.
Am I missing something? Why would a retail dealer sell this at this low price?
I read in various places about how this car has some electronical problems and repair can be costly. Would this be the reason why dealer is trying to sell so low? I have never bought a used car in my life so I would like to know if I am missing something. I am ready to spend cash to buy this car just based on its bluebook value and CARFAX that verified that car only had one owner with no major accidents reported.
Any advice would be helpful as I am without a car (due to total loss) and I need to buy a car soon.
Should I be worried about that engine vibration (it lasts maybe one second)? Anyone has any idea what that could be. One of my friends suggested it could be the engine mount, but the car idles perfectly, and rides even better.
Please, if you can help, let me know. YOu can also email me at jaymoka1@yahoo.com. Thank you, very much for your help.
Thanks in advance.
Theresa
I never heard of an evaporator cone. But, then again, it seems that my Volvo service center is always saying things to me I don't understand. I have to get a translation to the real-world term. Wish I could remember some of the things they've said. For instance, I needed a new coolant temperature sender, but they called it something completely different and I thought they were making something up. Anyway, good luck.
Theresa
Just got the news on my 1998 S70 with 71k miles.
It needs new calipers, roters and pads on both front brakes. $850 total for the job at the dealer.
Just wondering, is it unusual to get the calipers replaced? The car has always been dealer-serviced.
And I know the dealer is expensive, but is this a complete ripoff?
Will
What did you bring the car in for? Just low brakes or did you have a problem? I'd be suspicious if you just brought it in for a routine brake inspection and they are telling you that you need new rotors.
On the other hand, I had Midas quote me almost $700 to do the job without the calipers, so another $150 to get those replaced would normally be a good deal from my POV. (although I did not let Midas do it and will always do my own brakes on this car from now on. I usually find its not worth it to do it myself because brake jobs are cheap on many cars. This is an exception, obviously.)
