Thanks in advance for the help.
JD
So, as long as your van is running properly, starts fine, doesn't miss, and mileage and acceleration is good, I would run them up to at least 80,000.
They definitely are buried in there. I likely will pay to have someone else change them on this van. "Cab forward", or as I call it "windshield forward" styling overcame serviceability of the back of the engine on these vans.
What could be causing this besides the need for a general tune-up (which I will have done ASAP if that would help).
You might try running some fuel injector cleaner through since you just bought the van and may not know the service history.
Has anyone else experienced this problem? We have taken four long trips this summer in this van and have over 5000 miles on it and really like the van.
Secondly, thanks to everyone who chimed in on the serpentine belt. I will be attempting that fix one of these beautiful fall weekends. Fortunately my next door neighbor is a former Ford dealer mechanic so if I get into trouble I have someone to fall back on (don't like to make a habit of it).
Third, is it a big deal to replace coolant on the van? I took the van in for an oil change recently and the quickie oil change guys showed me that a) our coolant will only be good down to about 5-10 degrees; they pointed out that that's not nearly good enough in our Michigan winters and b) there were "rust chips" in the coolant. He said the rust chips need to be flushed out or they'll cause damage. Of course they wanted $50 to replace the coolant and I told them "no" (I always feel like I'm getting ripped off at these places). I'll check the manual to do this, just curious if anyone had any thoughts on how easy/hard it is and any tips involved.
Thanks again!
- Rob
Also, be sure to not mix and match coolant types which is supposed to be a no-no.
There is TSB on this problem, but I can't details on the TSB.
Anyone else have a similar problem? All advice will be appreciated.
They installed pre-packed calipars with disks and new rotors for the front.
Just this past w/e, we have brake fade.
Touch the brakes, good pressure, stay on the brakes, the pedal almost has to go to the floor to stop. Some action on rolling stops, initally plenty of stopping power, then it fades.
Is this something Mavis should fix for free or do we have some sort of booster problem or pressure leak?
If something wrong that Mavis didn't cause with their recent maintenance, what sort of money am I looking at, for a fix?
BTW, we have plenty of brake fluid, is there something else I can check/fix as a quick resolution?
Thanks in advance!
Then on July 4th I tried to open the back hatch with the key fob & the door made a buzzing sound but wouldn't open. I repeated this several times with the same result, so I tried the overhead console switch and got the same result. Then I unlocked the hatch with the key & tried opening it manually using the door release above the license plate & it still wouldn't open. Finally after a unlocking it & trying again with no luck, I put the key in the lock & while holding the key "turned" in the unlock position, I hit the manual release & it opened. I then put something in the back, which was the whole reason to start with & closed it manually. I then drove a few blocks & tried the overhead console again but it still didn't work. I got out & the hatched opened manually. I closed it manually, then went home & tried the console & the fob & the door worked just fine & has ever since. I thought it might have been the 95 deg temps that day but it has worked ever since including days around 100 deg.
Oh, & for the record, It has 18000 miles on it , runs great, plenty of power, great ride & very quiet even on the highway.
Last January while visiting relatives we were on the highway in Virginia wher the speed limit is 70 mph. I was keeping up with a small group of cars, happened to glance a the speedometer & found I was doing 98 mph. From the sound & feel, I thoght I was going the speed limit. I checked my mileage ( from New Jersey To Atlanta Georgia, about 850 miles total) and averaging 70 + mph I got 24 mpg. So far my wife & I love this van. Hope I can still claim that 100000+ miles from now.
It wouldn't be so bad if the owner's manual at least gave you a hint as to what is going on. I know there are some type of sensors along the vertical pillars for the liftgate that prevent closing on objects but the failure to be able to open the thing is truly baffling.
Leaks, loose connections, etc?
Any quick fixes or will this require another visit to Mavis?
Also, with the car running, put push down on the pedal til it stops, then pump the brakes a few times ( 3-6 times) & then hold pressure again. The pedal should gain some height. continue to hold pressure, If the pedal fades to the original low height then it's most likely the master cylinder. If it stay significantly higher (maybe fading slightly) then you may just have air in the lines & the brakes need to be bled, which Mavis should do for free because changing any part of the hydraulic system requires bleeding the air out & if not done correctly, will cause fade. The reason pumping helps is that fluid does not compress but air will & pushing the brake down causes any air in the lines to compress causing a lower pedal. pumping the brakes draws more fluid from the master cylinder resivoir which takes up the space the compressed air made. once you let off the brake, the air forces the fluid back into the resivoir so the next time you hit the brakes, they fade unless pumped.
If after pumping, the brakes fade to the same spot, what happening is the fluid is leaking past the seals in the master cylinder allowing the fluid to go back to the resivoir. master cylinders are dual systems, meaning there are two seals on the piston in the master cylinder, one controls the front brakes the other the back. so if you are losing pressure on the front, you will still have back brakes & vise versa. This unequal pressure should cause the brake light to come on.
Should I just torque the heck out of these two pieces with a screwdriver until they come apart? Am I even looking in the right spot (I'm 99% sure I am)? I feel like I'm missing something obvious, can someone educate this Plymouth dunce?
Rob
1. Remove the two bolts that hold the resonator (black box) to the radiator support. 2.Loosen the screw that holds the large rubber tube that goes to the throttle body. the one closest to the firewall. 3.Loosen the screw that holds the large lower rubber tube under the black box, the one just in front of the second black box that is almost under the radiator. 4. Remove both large rubber tubes and the small hose that leads to the valve cover. The top black box should then be free to be removed. 5.The second black box under the battery contains the air filter mounted vertically. Unsnap 2 steel clips (on one side)that hold the front of the second black box to the back. There are two tabs on the front part of the front part opposite of the steel clips. Once the steel clips are removed and the front part is rotated slightly from the clip side out, the front can be removed. You should now see the air filter. Pleats on the air filter go on the inside, screen on the outside. Sounds more complicated than it is. Post how it went.
Here goes:
* I get in to the van
* It's in Park and the foot brake is engaged
* I turn the key, and ----- the van starts rolling backwards (both times we were parked on an incline)
* I press the brakes ----- the van keeps rolling backwards.
* I try shifting to Drive or Reverese ------ doesn't shift and the van continues to roll backwards.
* Both occasions, the van comes to a stop because it comes to rest against something
Has this happened to any one else with a Dodge Grand Caravan ?
I hope that helps but I would have a competent mechanic check this vehicle and test it on a safe incline to figure out what the problem is for sure.
Thanks for the feedback on this.
I was finally able to get the van away from my wife long enough to try your test.
There is still the same level of brake fluid and there are no oil/fluid leaks showing up under the van.
After stepping on the brake pedal till it stopped, I then pumped the pedal and kept pressure on it.
Every time, it kept pressure or faded just a little bit.
Seems like air in the system.
Is Mavis suppose to bleed the brakes after installing loaded calipers and rotors?
Thanks in advance.
I've now got the following planned for my van and Taurus: front brake pads, sway bar links, radiator flush and air filter. I can't wait to tackle this stuff over the coming few weekends.
Thanks for the help guys,
Rob
good luck.
I do need some input on the brakes. I replaced them just fine. In fact my neighbor - the Ford mechanic - replaced the first set for me and I did the second one on my own. I then started the van up, pumped the brakes and took it for a test drive. Everything seemed fine. But today I noticed that when I applied the brakes the wheel wobbled/shaked quite a bit - and this only happened when I hit the brakes. If we were going less than 20-25 it wouldn't be so bad. But when we stopped from 45+ it was very noticeable. They didn't make any sound and the van didn't pull - and the brakes WORK great...they just shake the wheel. Any thoughts on what I might have screwed up?
Rob
Steve
They claim they don't bleed the brake system when changing out rotors and installing packed calipers.
Now the brakes are smoking after heavy to moderate use...I believe this does not indicate air in the system or does it: having to stand harder on the brakes to get them to work, hence the pads are scorching the rotors?
I did notice that the new brake pads had noticeable wavy ridges on them. Almost like something imprinted on them from the casting or mold. But I'm assuming this is standard on most pads and it wears off quickly? And if that's the case I'm assuming (again) that millions of people who get their brakes replaced aren't driving around for the first several months with shaky wheels.
Any other thoughts from the peanut gallery?
Thanks in advance,
Rob
Some people with known warped rotors will go ahead and put new brake pads on their car figuring the new pads will wear in to match the warp. I think these people plan to sell their cars in a month or two too :-)
Do a search on "brake" in the box on the left sidebar if you want to read the other brake discussions while waiting for responses from folks who are mechanics (many are archived but may help anyway).
That's my .02 peanuts.
Steve
The called and said they are getting no pressure at all...no air, no fluid, unless they pump the brakes for 10 minutes or something like that.
(BTW, now they claim they do bleed the brakes when replacing calipers and that it doesn't show up as a charge because it is part of the service)
They claim the fluid looks to be contaminated based on the fact that the ruber seal on the cap of the fluid container is swollen and the fluid is over filled (I didn't do it)
When they bleed the brakes, fluid comes out right? Which has to go back in?
Is it possible when they put the fluid in, it somehow got contaminated?
What they are now doing (and they claim at no cost to me) is to swap in a 'test' master cylinder and see if they still have no pressure.
Does this also involve using new brake fluid or adding more fluid?
Surely if they think the existing fluid is bad, they shouldn't but it back in.
Re: cost, they site $228 for a NEW master cylinder
(seems high, probably more like $190) and $60 a hour for labor, with maybe 1 to 1 1/2 hours of labor, so we are talking $288 for a 1 hour job (not to mention fluid)
At this point, pending the master cylinder swap and what they say, I have two issues:
1)their first claim of not bleeding the brakes, and now they say they do, though it is not a line item charged on the invoice
2)The possibility they contaminated the fluid if they did indeed bleed the brakes.
I'm thinking of having them install the old cylinder back and take it someplace else. Thoughts on how or if I can do this without being charged anything for the diagnose/work already performed? (they did tell me swapping in a test MC would be no charge)
BTW, local garage will do the same work for $270 (folks I trust). I only went back to Mavis thinking the problem would be covered under warranty from previous work.
Thanks...
Questions / comments:
1. If the fluid is contaminated, why didn't they note the swollen master cylinder cap gasket when they did the initial work?
2. If the contamination ruined the master cylinder, then the NEW calipers & the rear wheel cylinders / calipers (depending on whether you have rear disc or drum brakes) are damaged too since they have the same type rubber in them.
3. The low pedal & smoking problem didn't happen until after these Einsteins worked on your van, so if no-one else added fluid, it MUST have been them.
4. You said the brakes were smoking, how long after they gave it back did it do that?
one of the characteristics of brake fluid is a very high boiling point so as the brakes get hot (very hot, if you ever touched the rotor just after driving for a while) the fluid doesn't boil to a vapor causing the same problem as air in the lines. If it swelled the lid seal on the master cylinder, it probably swelled the seal on the calipers or wheel cylinders causing them to seep fluid onto the brakes causing the smoke.
5. Did the brakes fade down right after they initially did the first work or did it take a day or so?
6. what was the original reason for taking it to them, faded pedal, brake squealing, or just general maintainance?
It wouldn't take long for contaminated fluid to cause a problem, so if it wasn't them you would have had problems long before you initially went to them.
Even if they seem to correct the problem, take it to your other mechanic & let him check the entire system. And yes, if they try to get you for a master cylinder, make them put your old one on & let the REAL mechanic do the work. Tell him everything they did & said and make sure he checks both front & rear brakes (all four wheels too not just 1 front & 1 back) for leaking or any other seepage.
Print this out & show it to him, I'm sure he'll agree with my assessment. Good luck.
To answer your questions indept:
1)If the fluid is contaminated, why didn't they note the swollen master cylinder cap gasket when they did the initial work?
***at first they claimed they didn't bleed the brakes, so they probably didn't look at the cap gasket, or did bleed the breaks and now realize they may have contaminated the brake fluid somehow
***We have rear drums and this is a point I will have to bring up with them. This morning they initally claimed the front calipers they installed are still good, but now I could have problems down the road
***I'd have to agree
***This is my wife's van but she thought it started to happen within 1 week after Mavis worked on it. I noticed it slightly the next day plus a burning smell, but Mavis said I should expect that...why?
***My wife says within 1 week
***Brake squealing. According to Mavis the calipers were shot and schorched the rotors
I'm still waiting for Mavis to callback.
Sounds like I should tell them to put the original Master Cylinder back on and do nothing else unless they want to do the work under warranty...if not, wonder how much they will try to charge me for this morning's diagnose and Master Cylinder swap?
Will provide a update.
Thanks for your help and advice.
Bottom line, after talking to the Service Mgr and Store Owner, they agree about our point that the problem didn't start till after their first service. (and were quite amicable about the whole issue and dealing with me)
The fix was replacing the Master Cylinder that had internal leaks. They still point to contaminated fluid as the most likely cause and possibly a pre-existing condition in the Master Cylinder that wasn't fully explored the first time when we had obvious brake pad/caliper/rotor issues.
I stressed my opinion that they somehow contaminated the fluid when they bled the brakes on the first service (they did apolgize for the confusion re: them first saying they didn't bleed the brakes) and I was shown their 'opperation' and supplies involved on replacing brake fluid.
We settled on a cost satisfactory to all parties, somwheres between warranty (free) and their cost for the Master Cylinder, no charge for the installation labor, bleeding/flushing the whole brake system, and fluid used.
Front and rear brakes were checked out, all show no further problems.
They have extended my warranty to the whole brake system should anything fail due to left over contaminated brake fluid or residue of same.
At this point, I consider the matter closed
Thanks for all your help guys!
