Shaun
This is only my second post to this site over 6 months. I am mostly a casual observer, noting problems other people have had other than my own. However, there are a few problems with my S80 that have been nagging me ever since I got it.
I will list them and explain them as best I can:
Problem 1: A sucking noise eminating from behind the dash console. This has been a problem ever since I had the car. What happens is that while driving, a sucking noise will eminate from behind the dash. It almost sounds like the air being let out from a basketball or something similar. It will last anywhere from 2 to 5 seconds, and can occur every 30 seconds to every couple minutes. The dealer I go to said that it is not a problem. However, a car of this caliber should not be making that noise. Any clues as to what it may be?
Problem 2: Very low range on the remote door opener. I have read several comments on here that the way to do it is hold it at an angle when pointing it at the car. When I do this, I am able to open the car doors from about 150 feet away (only facing the front end though). If I try to open the doors from the back end or hold the remote differently, I have to be within 2-5 feet of the car before it works. Is this due to a low battery or is this just what happens?
Problem 3: When at idle in traffic, the tachometer jumps anywhere from 1 to 3 notches. I also mentioned this problem to my dealer, who said it is simply due to the A/C cylcing on and off. However, the car does this even when the A/C is off and has not been on for several hours. Any clues?
Problem 4: Car rolling back severely on hills. The car will roll back anywhere from 2 to 5 feet on a hill, making driving anywhere annoying. As I mentioned above, a car of this caliber/price should not roll back on hills. What should I do.
Those are my 4 gripes with my car. Besides that, this is one of the best cars I have ever driven. In addition, with winter fast approaching here in Boston, I am looking at getting snow tires. Has anyone had good/bad experiences with the Nordfrost II tires.
Thanks for the feedback.
Mike
The "sucking" noise may be reated to the ventilation. I get something similar too but have not yet said anything to the dealer. I used to have a Saab 9000 that was REAL noisy as servo-mechanisms in the ventilation system adjusted to all the measured parameters.
I think the key-fob thing may be a security issue, or just bad placement of the sensor in the auto. I have experienced the same problems. It is not a fob battery problem. I have somethimes found that if I hold the button down a little longer, it helps.
Tach jumping? Who knows?
overcash, you should expect some normal wear and disappearance of dye of the outside bolster edge over time. In my case it happens because I insist on keeping a brick for a wallet in my back pocket and it rubs the bolster pretty hard each time I get in or out of the car. I've had it happen on Volvos but it isn't usually noticeable at all for at least the first 15k miles or so. I just recently noticed it on my S80 T6 which has just over 28,000 miles. I asked my local dealership about it and they mentioned that they could dye it for me and I wouldn't be able to tell the difference. However, they wanted to charge me. I ended up buying some Meltonian #137 charcoal gray leather polish which seems to do the job for now but at some point I'll have to buy actual dye I suppose (and maybe think about another location for my wallet - along with loosing some weight!)
-rdo
rdollie@home.com
Better range is also had from pointing the right edge of the fob at the car. The transmitter antenna must be on that side, not along the top where you might normally point the top edge of the fob at the car.
In regards to the air 'sucking' noise behind the dash, my 99 S80 2.9 has exactly the same problem. Sometimes it happens for a few days then stops for a while before happening again. I must say that this is very annoying indeed, I've brought it to the dealer couple of times but they could not find any problems, they blame it on the ventilation system. As far as I can remember, I didn't have this sucking noise for the first 15k(I am at 22k now) and I have no idea how this suddenly happens. If anyone has knowledge of any fix to the problem, I'd appreciate if you can let me know!
j2k1, to follow up on mkrich's reply, the Volvo system performs just the way you described and includes the same points of interest information. All navigation systems in the U.S. use mapping information supplied by Navigation Technologies (www.navtech.com). The latest systems are DVD-based so a single disc can hold more info that a standard CD ROM but in the Volvo the system uses a 6-disc changer so it's not an issue in general. Eventually I believe all systems will be DVD-based. Also, the Volvo system is the only one I know of where the drivers eyes stay on the horizon and the hands on the steering wheel to operate the unit (Infiniti has a dash mounted screen for the I30 but the buttons are not convenient from what I've seen.)
If I can answer any questions let me know.
-rdo
rdollie@home.com
Ben
Tex
Today when I started the car the "low coolant" warning msg displayed saying stop engine immediately. I did and checked the coolant.
It was at the MIN level. I had checked it about a week ago and it was at level its been ever since July 1 (just below MAX level).
The only change I find significant at this point is that the car has 5400 miles on it and the winter temperatures are setting in. This morning it was around 40 deg F.
I topped the expansion tank up to the MAX level and went about my business.
Comments?
I understand this issue might be related to a water pump seal -- any thoughts on this ?
Regards... Barry
'00 T6, Build 2/00, Metalic Moondust
Turbos always drive different. I've intuitively changed my driving style in this car to a moderate double-pump of the accelerator to effect a smoother acceleration curve. I guess the first "pump" gets the turbo started so it's there for you on the second pump.
In the interim, if you don't get this technique down, just tap, don't hold, the accelerator through the power curve, and coast into the next car (rather than accelerate into it).
Cheers!
Only a week or two after our last unscheduled maintenance for the coolant, I went to the garage and found that I could not get the car out of park. The tow truck had to drag the car along the garage floor then up the flat bed with the front tires locked. I hope that did not hurt anything else. I have not heard the explanation yet, but I will post when we get the car back. It's been at the dealer for almost 2 weeks now.
We are about ready to get rid of this car because of all the problems: clunk sound, recall, 4-CD changer died, car would stall in traffic (fix was computer program was redownloaded), radiator, now the transmission lever is locked. We love the car. We may get a 2001 just to see if some problems have been corrected. The other option is trying an Audi A6 2.7T to see if they are any better. We just don't have time to take the car to the dealer all the time, and pretty soon, it will come out of our pockets.
"Problem 3: When at idle in traffic, the
and has not been on for several hours. Any clues?"
Javasea
This post is a continution of a previous post I made with a laundry list of problems my 2000 S80 2.9 was having.
I took my car into my dealer (Boston Volvo Village - Brighton, MA) and gave them my list of problems to look at. They fixed the clunk in the steering wheel by replacing a centershaft (that's what they told me), they put on a new door seal, and they reinstalled the door lock program into the car. They told me that they did not notice any of the other problems my car seems to be having.
A couple of days after having the car out of the shop, I was driving around town with my roommate. All the doors were locked and had been for some time. Suddenly, the right rear door lock unlocked while all others remained locked. This scared the shi* out of me to suddenly hear such a noise while driving. I have made another appointment to visit the repair shop for this problem. They do not know why it is happening again, nor do they know why it happened in the first place. I have a feeling my car may be in the shop every weekend to simply redownload this door lock problem. Does anyone out there have any suggestions to this?
Second, after gettning my car back, the brakes now seem OVERLY sensitive (as if they weren't sensitive enough to begin with...). This nearly got me into a few fender-benders on the Mass Pike this past weekend.
Third, although my dealer says that this behavior on my car is normal, I refuse to believe them. I am talking about the excessive rollback my car does on hills. It has done this since day one. My dealer says that it is normal and nothing can be done about it. However, I refuse to believe that rolling back 4-8 feet on a hill is "normal" behavior for a $38,000 luxury car. I may end up taking my car to an independent repair shop if Volvo does not do anything about this.
Fourth, I saw a post on here about someone having similar tachometer jumping problems. He said that his dealer replaced the Air Mass Meter under warranty and that he has not had the problem since. Should I mention to my dealer what I read and to see if they could look at this part?
I don't want to give the impression that I hate this car. I really love it. I love its style, its handling, and its overall performance. However, when problems like these happen on a $38,000 car, one begins to wonder...
Mike
BHT
I am ordering an S80 shortly, and was told to get a 2001 (the 3rd model yr of production) as the 2000 had a number of problems that appear to have been fixed with 2001.
I have decided on everything, except whether to go T6 or 2.9. Any thoughts on turbo vs no turbo would be appreciated. Cheaper is good. Less potential mechanical problem is also good. But the 2.9 feels a little sluggish compared to the lighter car I currently drive (I am not a lead foot either). But since my son will begin driving in a few years (and will likely drive this car some), not getting a turbo may be the smartest safety decision I could make.
My response to your 2.9 or T-6 decision is, as I mentioned, the 2.9 engine. Unless you're the guy who blasts past me from traffic lights only to look at me sitting behind/beside him at the next light, then the 2.9 is plenty--especially with your son now driving. The roads are too dangerous.
Incidentally, my wife's final vote was the 2.9 S80, but even though Al Gore might not understand this, my vote counted more!!!
Would you like to have a place where you can talk about your 80-series Volvo? This message is for all Volvo owners, Volvo enthusiasts, prospective Volvo owners, or car enthusiasts in general. The best Volvo enthusiast site has just opened up on the internet, and we need your participation. Building a great Volvo community is what this site is all about. This site includes the 40 series, 60 series, 70 series, 80 series, 200 series, 700 series, 800 series, 900/90 series, and all other Volvo models throughout the years. This new site will only be great if it has a lot of people using and visiting it. Please register and become one of the first to be a part of the newest, best Volvo enthusiast site on the internet. This new site is called SwedeSpeed! I hope to see you there! Please visit us at:
www.SwedeSpeed.com
-Ian Rosdale
For what it's worth, reponding to item #512... safety is what also won out for my wife and I. Volvo's quality track-record has traditionally been strong. The problems facing the '99 and '00 S80 were an issue for us, but we felt that our safety was more of a priority. Luckily I haven't experienced the issues that some have already written in their comments above. For us, we'll continue to enjoy the comfort, performance and utility of our V70 T5 as it safely transports us around the US.
I also came across a safety story the other day that I thought might be of interest re: the '01 S80. While the story is from the (Australian) Sydney Morning Herald, the information still appears applicable here...
"Volvo's S80 has romped crash tests on both sides
of the Atlantic, prompting the Swedish car builder
to boast that its sexier new cars are among the
safest in the world. According to Volvo, the S80 the first car in the world to get top results in
both European and American independent crash tests carried out by the three independent test institutes, Euro-NCAP, US-NCAP and IIHS (Insurance
Institute of Highway Safety).
The ongoing NCAP tests are part of the consumer
information provided by NHTSA, the American traffic safety authority. The cars tested are evaluated in both a frontal crash test and in a side impact test.
The S80 last year became the first car in the
world to score full points for both the driver and
passengers in side-impact tests. Further frontal impact tests last month saw the S80 again
score the five-star top rating.
The car previously had been awarded the highest
possible ranking in the American Insurance
Institute for Highway Safety (IIHS) frontal impact
test, "Best Pick", and top marks in the European
NCAP tests which involves both a frontal offset
crash and side-impact tests against both a dummy
car and a lamp post.
Understandably, Volvo is pleased. And it is
especially pleased that it has maintained its
safety mantle despite its much-vaunted trend
towards building sexier-looking cars.
"Here we have a number of different tests, carried
out by three mutually independent organisations,
all coming to the very same conclusion, says
Christer Gustafsson, safety expert at Volvo Car
Corporation. "As a company policy, we do not
generally draw attention to top results in
individual tests since we do not feel that a single test is sufficient to assess a car model's overall safety level, but this clearly shows that the Volvo S80 has a safety level of absolute world
class.
Mr Gustafsson said the S80 was in fact safer than
the tests suggested. "The tests only cover some of
the situations that the Volvo S80 is designed to
withstand," he said. "Nor do the tests rate the
multitude of advanced systems found in the car, for example the WHIPS whiplash-protection system."
Volvo also is crowing about the fact that its new
S60 sedan has been awarded the the Golden Steering
Wheel 2000 in a ceremony in Berlin. The S60 is the
25th winner of the award, made by an international
jury of motorsport representatives and car experts, who test each entrants for two days and evaluate them for road performance, fuel consumption and environmental aspects, design, interior, engine, driving comfort, space and cost effectiveness."
To the folks examining quality ratings: I too have had minimal problems with my 2000 S80 T6 and would HIGHLY recommend it, even with a bug here or there. I like it more every day.
Also, I've read posts regarding the wood/leather steering wheel option. The dealer I visited advised that such an option does not exist. Can anyone enlighten me on this?
In any case, my real question is about the "Finishing Touch" protectant, which next to the LoJack I know almost nothing about. The dealer's flyer has this to say on it: The coating is on sale for $325 during December. Now, on the surface, this stuff certainly smacks of the stereotypical "undercoating" (as seen in "Fargo") whose only real purpose is to increase the dealer's profits. The fact that they refund your money if you trade the car in, though (which I'm told includes bringing a lease vehicle back and getting a new one) kind of makes it sound like the dealer really wants the stuff on your car. Also, my sales advisor said he had it on his two Volvos, for whatever that's worth.
Anyway, does anyone know anything about this stuff? Does it really work? I sometimes get so busy that I don't get a chance to get bird droppings off the paint right away, so if this stuff really protects the paint from being damaged in that situation, it'd be valuable to me (though I dunno if it's worth $325). The stuff is either a product of or is distributed by Southwest Dealer Services, Inc., but there's no additional info on their website.
The only information I was able to find on the web or on Usenet was a thread entitled "Question: Finishing Touch Coating" on alt.autos.corvette. The four respondents all recommended against it, but it was clear that most or all of them didn't know anything about this particular product and were just making a knee-jerk reaction. Also, they said that instead, you should apply a wax-based product yourself every couple of months or so. I have neither time nor desire to wash and wax my car myself, so their advice may not be of any use from my perspective.
Anyway, anyone have any suggestions?
Don't fall for it. Dealer is looking for high-profit add-on's and they're usually worth about 1/10th of what was paid, if there's any value at all. Lojack is an exception and you'll have to make a judgement call on that yourself for value vs. expense, but if you're not sure about pricing games, get a 2nd price! I'm in Dallas and it's available, but I don't know a lot of people with it here and car theft, at least in my little corner of DFW, isn't a huge problem.
Anyway, it's been widely recounted here to DO NOT APPLY ANY WAX OR SEALANTS FOR FIRST SIX MONTHS OF OWNERSHIP for unspecific reasons having to do with curing of paint. Personal recommendation is to (a) find a hand-wash near you that does $99 detailing or a mobile detailer and do that once every 3 months for a wax or every 6 months with a poly seal, or (b) find an hour or two every six months to do it yourself. I do the poly seal myself, recommend Meguiar's, order on the web, I have purchased from Autopia.
Try to get the bird poop off ASAP always. There are spray misters out there that you can keep in the trunk that will do the trick if you can't get to a garden hose fast enough. If you're driving a dark color, you probably can't get it off fast enough anyway.
Best of luck to you!
Also, what about lease deals?
Thanks!!!
I have now owned my S80 T6 for over a year; the car has 6,500 gently driven miles on it. I still adore it but it has experienced many of the relatively minor problems mentioned by other owners when I began reading the posts over a year ago.
Before I bring my car in for service, can someone please tell me what the problem might be since I know some of you have experienced the same thing: Usually when turning, I feel a "clunk" coming from the driver's side front wheel area.
(I think my service department tends to smirk when a woman describes a problem this way, and they claim never to have heard of the static problem experienced on my stereo system's Dolby setting either. I was apoplectic when the owner of the dealership patiently explained to me in the most condescending way possible that Dolby systems are supposed to lessen noise, not increase it. DUH! He also claimed not to hear anything!) Please help before I give up and switch to another dealership for service.
flowerpots, are you kidding? I would switch dealerships in a heartbeat if I were in your position!
The clunk noise you referred to is well documented and is related to some front-end suspension issue(s). I'm not 100% sure if it is a need for a bushing fix (there's a Tech Service Bulletin for it - actually several successive ones) or the ball joint replacement which is an actual recall item. The ball joint recall occurred after Volvo went through a couple of iterations on improved bushings to eliminate the noise but I don't know if both are required to eliminate the noise or just the ball joint replacement. Either way, ANY competent dealership will well aware of this issue.
Regarding the Dolby static that occurs only when you play a CD with the Dolby Prologic engaged - it is hard to catch. It tends to happen very sporadically but it is usually consistent about where it happens with a particular CD track. It seems that those who have encountered this issue have been issued factory refreshed head units that have eliminated the issue. I had this problem about a year ago but couldn't duplicate it consistently for a dealer. As it happens, I (or someone) broke a button on my radio earlier this year and ever since the head unit was replaced the static problem disappeared as well.
Back, to my first thought: you experience with your dealer will make or break your satisfaction with your car. Given what you have experienced already I would run, not walk, to another dealer if it is an option. Call them ahead of time and tell them of the customer disservice you were given at the other dealer and they should welcome you with open arms since service is how dealers make most of their money.
-rdo
rdollie@home.com
As for the maddening CD-Dolby static experience, I agree that it happens only sporadically and usually during the same CD tracks, which nearly had me convinced that it was a CD defect and not my stereo system. But it was happening loud and clear when I was playing my CD for the owner of my dealership, and he claimed he couldn't hear it! And to add insult to injury, both he and the Service Manager promised to investigate other reports of this problem with "Headquarters", but neither of them called me back. Definitely time to switch!
I did not experience the clunk until after the ball joint replacement was performed either. Apparently the area that they work on for the ball joint involves the same mechanical items as the clunking issue. The service technician indicated that the ball joint service (a couple of months ago) likely brought on the clunk. I've since had the clunk fix incorporated, and not heard the clunk since. Neil
Very cold in Atlanta for 2 weeks. I have noticed some suspension squeaking (front end) when car is slowing (on and off the brakes - like a rocking motion). Doesn't appear to from the shocks. Anybody experience this in cold climates? A bit of WD40, perhaps, in the right location?
Thanks in advance.
I would also like to mention how very helpful this site and your comments have been. I began thinking about a Volvo or Saab more than a year ago, but wanted to wait until I could get out from owing more than the worth of my 97 LeSabre. The 99 reviews scared me away from the Volvo at first. Saab wouldn't negotiate on trade in. Autobytel hooked me up with a Volvo dealership and the 01's, based upon what I am reading, have had the problems cleared up. I was prepared to purchase the 2.9, primarily based upon the reviews posted here. I test drove the 2.9 first, then the T6, and the difference was extraordinary when passing cars on the freeway. Additionally, my wife won't drive a manual transmission, and the Geartronic gives me at least of sense of more involvement in driving the car. On the whole, I didn't feel that the handling was compromised. After purchasing the car and driving it home, I can say that it handles as well as and is as comfortable as my father's Lexus 400. All this and the epitome of safety to boot!
Thanks for your help in all of this.
