Have you recently tried to lease a vehicle again after your last lease ended, and found that average monthly payments have gone so far up that you decided to get a cheaper vehicle with a lower monthly payment or purchase a used car?
If so, a reporter would like to talk to you about it. Please reach out to [email protected] by Thursday, October 18, 2018 telling us a little about your experience, and the Edmunds PR team may connect you with the journalist.
Dodge/Plymouth/Chrysler Minivan Problems & Solutions
19394969899135
  • chan1chan1 Posts: 5
    I have 2001 Chrysler Voyager. Everytime I turn my steering wheel the air bag light comes on. I took it to the dealer and they could find out why. Has anyone experienced a similar problem? Please help..... :cry:
  • badgerfanbadgerfan Posts: 1,565
    I haven't had this problem, but it could be related to a failure of the "clockspring" in the steering wheel assembly, which I believe feeds power to the airbag as the wheel is rotated. There was a recall on this part for a number of model years, so you may even be covered under a recall. Check with your dealer.
    I went into the NTSB and Chrysler website and didn't see anything on the clockspring. Should I ask the dealer again? Thank you for your assistance.
    I would think your dealer would have some experience with the clockspring and what problems it causes, I know there was a recall and replacement for earlier year Caravans as our 1996 was subject to this recall, so I would talk to the service adviser specifically about your symptoms and suggest that you think it might be related to the clock spring, especially since the airbag light going on and off is related to turning the steering wheel.
    I just spoke to the dealer and they are telling me there was a recall between 1998 through 2000 vehicles. Well my van is 2001. Their attitude is it's your problem not our. I guess I have to pay for this myself. I also emailed the Chrysler Corp and explain my problem and my dissatisfaction. I hate to say this but what happens after the sale is customers problem. I probably never buy another Chrysler again. :mad: :lemon: :lemon: :lemon:
  • 97xpresso97xpresso Posts: 249
    Clockspring is not that big of a deal. Part is not expensive, and you can install it yourself if you're handy.
    Well I talked to the dearler and it's going to cost $150. I want to thank you for your help. I really appreciate it.
  • slowhandslowhand Posts: 2
    I've searched for this problem and not found it exactly, so apologies up front if I'm repeating someone else's post.
    My 1998 T&C yesterday started, ran and quit after 5 seconds. It repeated the stunt. Then, it displayed no LED display for the odometer, trip meter, transmission function, no overhead console display and will not engage the starter at all. Nothing. Depressing the two outer buttons on the overhead console displays "ccd", then a dim flashing all display grid of the display. All upper dash lights operate nominally, (alarm, airbag, ABS, etc). I've checked the obvious (battery terminals, contacts etc.) Has anyone else experienced this? Is this a know 'issue' The T&C has 175000KM (Canadian) on it - well maintained and has been operating nominally. Suggestions are most welcomed. Regards and thanks for your expertise, everyone.
  • dennisctcdennisctc Posts: 1,168
    what I rip off!!!!! My company manufactures Clocksprings, we've quoted them to DCX. We charge about $10-$15 for one!!! talk about markup!!! We don't supply this specific Clockspring to DCX, and they're all soo very different or I'd send you one for free!!!
    I think a company by the name of Methode makes them for DCX.
  • johnbenderjohnbender Posts: 17
    It could be something as serious as a blown head. If you have a lot of miles on the engine the engine may need to be replaced. Usually loss of power and popping noises in the engine signals that the engine is about to go out. I had that same thing happen on a vehicle before, not a minivan, but the vehicle had over 200,000 miles on it. It started putting out and making a popping noise in the engine. I would take it to the shop for a diagnosis asap. You may also want to check and see if you are losing oil. If you are losing oil or the oil has water in it then you may have a blown head.
  • marine2marine2 Posts: 1,155
    This is about the clockspring and what it controls. I hope it helps you. :sick:
    http://dodgeram.info/tsb/recalls/982.htm
  • ctocto Posts: 1
    I have a 2001 Grand Caravan. It appears that I have blown the fuse in the outlet that has permanent power (not the switched one above). The two outlets are located to the left of the storage area in the center console. The fuse for the switched outlet is in the relay/fuse box next to the battery but the one I am trying to locate is nowhere to be found. The Edmunds book for this year does not show the power outlets in the wiring diagram... Any suggestions?
  • :) oil levels are perfect. always have. it only does it for a few seconds. (less than five) but i will bring it to the shop to be hooked up. could it be the oxygen sensor? also it only has 100k on it. not bragging but is in showroom condition. sharp!? if you dont reply, thank you for your time.
    I don't know if it could be the oxygen sensor or not, but I think you should definitely take it into the shop for a diagnosis. A blown head can occur at any mileage, but if you only have 100,000 miles on it, chances are your engine is still o.k. Although, I did see someone on these forums that was complaining they had to replace their engine on their caravan after about 80,000. All I know is the popping sound followed by a loss of power is a symptom of a blown head or a weak engine. Like I said you may want to check to see if there is water in the oil. Just pull out the dipstick and check to see if there are any tiny water droplets sticking to the oil on the dipstick. If you do see water, then that is not a good sign. If you do not see any water, then you probably do not have a blown head. Your best bet is to take in to the shop and have them look at it, at least then you'll know for sure what the problem is.
  • My dad has an '02 Grand Caravan and has had 2 A/C compressors installed already, both under warranty. Warranty is now off and he is concerned about future failures as these are not a cheap part. Are there any TSB's or other notices out about this. His van has the 3.3l engine if that matters. Any info is appreciated.
  • hayneldanhayneldan Posts: 657
    The power for the powered outlet on the front console comes from a component named PTC7 is listed as a 13 amp fuse. I cannot locate it on my van either. PTC stands for positive temperature coefficients, and I suspect it is a circuit breaker relay type.
  • no water. taking it in on tuesday. wish me luck. thanks for everything....
    scamper225
  • daz1daz1 Posts: 1
    I have a 1998 Chrysler Voyager and recently went to start the engine and nothing no dash lights and just a clicking noise. After three attempts it started and was fine for a couple of days. My local garage said that something was probably draining the battery. Now the car will not start and I had a friend jump start it and after three pushes accelerator it just cut out. I have been told that the internal locking door switch has been touched and activiated the immobliser. Had this same problem 15 months ago and a new battery was fitted.
    Any views? :confuse:
    Sounds like the battery. I just replaced the battery on my Voyager myself. I don't know why, but it seems like these Voyagers burn through batteries faster then other vehicles. If it has only been 15 months, your battery is probably still under warranty, just take it back to the place you bought it from. As far as the internal locking door switch problem, I'm not sure how to fix that problem, but my guess is that your vehicle will reset when a new battery is installed. Once the vehicle is disconnected from the battery for more then 5 minutes, the vehicle resets everything when it is hooked back up.
  • masterpaul1masterpaul1 Posts: 421
    While in for a routine oil change, I was told that our air condition compressor is under warranty to 70,000 miles. (we have an 01 DGC EX). I'd say check with your local Daimler chrysler dealer.
    OK - so I've had a chance to dig into this *much* further and have some follow-up. According to a (well) trained Chrysler specialist. part of the problem occurred when I used the key to open the door. In doing so, I may have triggered the lock mechanism partially - opened the door and 'fooled' the alarm system into thinking I had broken into the car. The running and stopping is part of the alarm system designed to shut down the system if the car is stolen. After three tries the system is 'locked-out' of the process and will not start. Removing the battery cables from the terminals and leaving it overnight allowed the system to reset and it was completely operable by morning. A scan of the BCM (body control module) shows no errors.
    So... my question is has anyone else *ever* heard of this problem/feature and if so, is there any longer term problems relating to it? Any further problems with the BCM? Thanks.
  • atucker1atucker1 Posts: 1
    Was advised by a friend on this site, that I may find some assitance on a issue that I currently have. I got a 2000 Dodge GC with approx 55k miles on it. I've just moved from Michigan to Arizona due to a work. While changing the oil, I noticed that I have Rust surrounding the housing unit on my front left strut, viewed from the engine. When viewing this underneanth the car, i observe no rust. Looking in the warranty book, there is a note on Rust covering outside pannels up to 100,000 miles (I believe). Am I screwed due to being out of the basic warrantly or is this considered a outside pannel. I can allready guess what the dealership has to say on this manner.
    Any assistance would be appreciated
  • I have a 2001 Dodge Caravan with a front end "thudding" noise, I have been to my mechanic and he said he does not know what the problem is without just starting to replace parts in hope that will fix it, he has looked it over and does not see anything wrong, all parts apprear to be in good working order, has anyone had this same problem and been able to get it fixed??
    Any information would be appreciated.....Thank You
  • rktechrktech Posts: 25
    I had an 01 Chrysler T&C which made an odd creaking, thudding noise from the left front shock area...had about 16,500 miles at the time. Anyway, I took it into Chrysler and they replaced the front sway bar link on the left side. Solved the problem nicely.
    We have a 01 DGC EX to which we had a similar noise when going over bumps. This is wait had to be replaced back in Nov. 2004. 1) Front link, sway bar; 2) Link-sway eliminator; 3) Bushing-sway eliminator and 4) Cushion, front sway bar. Cost was $173.12 in parts. Our mileage was 52K. Hope this helps. :shades:
  • swfeatureswfeature Posts: 6
    I have a 2005 SXT and I noticed that little pieces of plastic have broken off of the seats when I have stowed them. In the 2nd row, a few tiny white pieces have broken off - although I haven't noticed any impact on their operation. The cup holder on one side no longer folds away - which means I have to hold it up with one hand while I store the seat in the floor.
    On the rear seats, a panel that covers the seat when stowed away has broken one of it's attachment pieces. This means I can no longer slide things into the bed without the risk of snapping the rear panel off altogether.
    I've only stowed the seats about fifteen times in the year I've owned the car. I am actually a pretty careful person - so I don't think these pieces broke off due to carelessness or rough treatment. I'm taking the van in for service and I'm intrigued to see how the dealership handles my complaint and whether the seats are covered by warranty.
    Anyone else have these or similar problems out there?
  • jdybberjdybber Posts: 3
    I have a 3.3L Grand Caravan with a high idle at startup and throughout the driving range.This is what I have checked and replaced so far:
    Installed brand new AIS Motor:
    the connections are good to the AIS harness:
    there are no shorts shown with ohmeter at the harness:
    throttle body has been cleaned and throttle body gasket replaced:
    I have checked for vacuum leaks and can't find any:
    Vacuum is at a steady 15, but when I open and close throttle the reading drops below 5 (which is OK), but only goes back to 18 before settling at 15. Is the 18 normal or not? I suspect I should see 22 or so, but I am guessing here.
    The car will start at 1250 rpms and quickly rise to between 1750 and 2000.
    I disconnected battery to erase trouble codes, and after replacing AIS motor and driving
    5 minutes to go at least 40-45 mph the Code 25 (AIS motor issues) pops up. What steps do you recommend from here? I realize the ECM(Computer) is still a potential issue, but want to eliminate all before that step. I know enough to be dangerous, but I welcome your expertise so I can diagnose more effectively in the future. Thanks.
  • dustykdustyk Posts: 2,926
    Fifteen is low for an idle vacuum, in my opinion. I'd continue to check for a vacuum leak. A bad PCV valve can cause this. If not vacuum related, this could also be caused by a defective Throttle Position Sensor.
    Dusty
    Dusty, The TPS reads within specs on Voltage checks ect. I did have another known good PCV and reading is the same.
  • jjtjjjtj Posts: 103
    Has anyone had any luck finding a good service manual for the latest generation of vans (01 and up)? The newest I've seen is a Haynes manual, which is for 96-2002, which I don't fully understand as the last gen. ended in 2000. There are some Chrysler factory manuals on ebay, but I'm not sure how friendly these would be to a driveway mechanic.
    Jason
