Toyota Solara
Mr_Shiftright
Member Posts: 64,481
in Toyota
This is a continuation of the popular Toyota Solara--Part 5 Topic, which has once again topped 1,000 posts!
For newcomers, you may review previous posts on the Solara by linking here:
Toyota Solara--Parts 5 and Earlier
For "regulars", please continue your discussion here!
Thank you for your participation in Town Hall!
Mr Shiftright Your Host
I have michelins on my Solara and still have the left steering problem. Mine does not pull however (at least I don't think it does). I was told initially that it is because all roads tilt to the right (which is true, but why then don't I notice having to turn the wheel to keep the car straight on an other vehicle?), then I was told it is likely that the steering bracket was slightly off when they built my car and can't do anything about it now. I have a 1999, are people experiencing the same problem with 2000's? I wonder if we could catch some attention by getting everyone here who has the problem to sign a letter of complaint and going public, or sending a copy to Toyota and "threatening" to go public. They likely wouldn't care, but at least we could try. I have to admit, I look at my steering wheel a lot while driving to see just how far left I have to keep the wheel, and it's really not that far left by any means, but it is noticeable. I actually had someone comment that I may need an alignment!
Who else has been having CD player problems?
2000 SLE Diamond White Pearl
Anyone know if you can use Dex-cool or what type/brand, of coolent to top off the coolent reservoir. I was going to top mine off with Halvoline Dex-cool, like I had used in my last GM car, but noticed my Solaras coolent is pink, not orange like the extened life coolent I purchased. Any suggestions on coolent???
I seems I had gotten used to it, but drove a friend's M-B around Europe in July, and when I came back, I noticed the pull and fighting of the wheel immediately. MUST get it fixed - somehow! I guess it's time to become the squeaky wheel over at Toyota!
ALSO -
I saw a brand new SE on the freeway here in L.A. yesterday with no DRLs. Why? Aren't all Solaras equipped that way?
Next, a recent post asked if others were having problems with road noise, especially when going over bumps. I'm now at almost 5,000 miles and took the car in today to be looked at because I was getting a rumbling, rattly noise and a fair amount of vibration when going over bumps. It has actually been more or less noticeable for a while now, and it's definitely a switch from when I first got the car. The technician took it for a ride and thinks it may be the shocks. I'll find out later this week when it goes into the shop, and let you know.
Sept 6, 2000 I received a phone call from Toyota Regional office apologizing and asking me if I would except the Alloy wheel and settle my claim out of court. This was 1 week after Toyota was served papers that I planned on taking them to small claims court for substituting a Steel rim for the Alloy Rim. I agreed even though I spent about $60.00 filing and serving papers. I went to my local dealer and they mounted my spare onto the alloy wheel on Sept.8th. I then signed a paper releasing Toyota of any further obligations thus settling the suit. I love my car, but Toyota’s handling of this? Well you be the judge.
I'm getting the impression that my snail-mail letter and my e-mails are being ignored. If I ask a general question via e-mail, I get a response. If I have a problem, then I do not receive a response.
Based on jhope1's last post, it seems like he was not receiving good service either.
My SLE also makes some funny noises from time to time over particular types of bumps. The service tech found leaky struts, and will replace them this week. Perhaps this will cure the problem. Good luck with yours.
Neil
'99 SLE
Red\Gray
Does anyone know any way that I can remove the mess? It was an oil based stain. I have two coats of Z2 on both vehicles, but it has been a couple of months since I applied the last coat. I figured with my vehicles being about 45 feet away I'd be ok, but I guess not. Will a buffer work?
Solara11,
The antifreeze used by Toyota is pink. My dad was a master tech. with Toyota for over 13 years and has had his own shop for 4+. He still uses the Toyota brand antifreeze and says (based on his experience) it's better than any of the store bought stuff. If you are just topping the reservior, you can just add water unless you live somewhere where it gets ungodly cold during the winter.
What I noticed mostly was certain types of bumps where the wheel dropped suddenly - there was a metallic "clunk" or "thunk" where I would not have expected any noise at all. I'll let you know.
I know Chicago's potholes very well, having worked there for several months years ago. I still enjoy visiting!
Pulling --
I'm hoping the pull to the left story about Lexus driver's was a joke!! When people are complaining that they're car pulls to the left do you mean you have to keep the steering wheel slightly turned to the left (like mine) to keep the car from going right if you kept the steering wheel straight? The problem with my car is not that it "pulls" to the left but that I have to keep the steering wheel slightly turned left to go straight. If I straighten the wheel the car starts to go off to the right (but it doesn't actually pull, pulling means that if you put your steering wheel in the position that your car normally goes straight in -- in my case the steering wheel must be kept ever so slightly to the left -- that the car actually "pulls" itself back and goes left anyway). If I leave the wheel alone the car does not pull (it does eventually but I'm sure with any car if you left the steering wheel alone you would eventually move left or more likely right -- although I wouldn't recommend trying that for too long!!). Another way of telling if your car pulls is to go on an empty street go around 30m/h and come to a fairly quick stop. If your car pulls to one side then there is a problem (more so if it pulls left since all roads are tilted towards the curb for drainage reasons).
Odd, when I complained many months ago about this the sales man told me it was normal and let me test drive a new corrolla to prove his point (any one of my choice). I had to keep the steering wheel turned slightly to the right instead!!! Maybe it's just a Toyota problem for 1999 in general, they can't get they're damn steering wheels straight. I guess they've fixed it on the 2000's though.
I bought a 2000 Solara and the manufacturers sticker shows it comes with 15in tires. Also on that sticker was upgrade package #5. This includes 16in tires. The dealer added 17in tires and there own dealer invoice sticker next to the manufacturers for 2999.95. Since I paid for the upgrade #5 AND the 17in tires, should't I be able to get the 16in also? 3k is a lot to spend on 17in tires, obviously they did not back out the cost of the 16in. They left the 16in spare in the trunk. Should I ask for the other 4? Thanks for any input.
On the SLE, is it just the perforated part of the seat upholstery that is leather? Or are the side bolsters too; or the whole seat? I want to treat the leather but I'm not sure how much of the seat is leather. Oh, I'm getting a consistent 23 miles to the 89 octane gallon in commuter driving. This seam to be about the norm from what I have seen in this post. Really not that bad for what you get in performance and refinement.
You can get brief descriptions of the Sienna steering problem from the 14 Sienna owners that
filed a Vehicle Owners Questionnaire with the NHTSA.....the NHTSA website is at "www.nhtsa.com"......click under "Problems and Issues", then click on "Consumer Complaints", in the drop down menus choose: 1999,... toyota truck,... Sienna,... Steering & column...Check out, their descriptions of the Steering Defect and you will conclude it is almost identical as the 1999 Solara Steering Defect many of us keep complaining about.. .
Remember that the Solara is built on the same platform and Powertrain as the Sienna,
Does it share identical steering mechanisms with the Sienna ?. .
My Solara steering continues to LOCK INTO A LEFT TURN, after 6 alignments, tire rotations,
and recently installing B.F.Goodrich tires to no avail (check message #1024 in prior topic #1813
Solara V ). If you dont pay attention, the Solara will turn left into the other lane in 5 seconds,without any driver intervention whatsoever.. I would dread the thought of having my teenage kids or someone elses end up crashing into a center divider or another vehicle for being innattentive for 5 seconds and that isnt very hard to do. . .
ENOUGH !! I'M FILING A SAFETY COMPLAINT WITH NHTSA TODAY.. HOPE YOU JOIN ME.
Good luck!
Has any Solara owner come up with a work around to allow the lights to be turned off for certain occasions without defeating the entire system?
Turn the car off, put the parking brake on and then restart the car. The lights will not go on.
I have a silver SLEV6 and I put on some very nice PIAS Super Plasma headlights in my car. the car looks great but no visibility. You trade look for illumination.
I was considering installing real HID's in my car but its a lot of $$$$$$ (around $1500). But the car looks incredible with them on and the light up the moon!
See ya'll when I get back on the 26th.
Oh, and gpolt, I don't know if it was this topic or not, but I have addressed the advertising fee before. It is real and we can't escape paying it on the invoice. Edmund's even has a disclaimer about it in the invoice section.
Was there a subsequent chance in production? Does everyone have 1 or 2 boxes?
Neil
'99 SLE
Red\Gray
25,350 miles
Please tell me what to do anyone! Thank you
