Dodge Caravan/Chrysler Voyager
13940414345
    shiposhipo Member Posts: 9,148
    Hmmm, that's odd. While our Gen3 1998 DGC does not have traction control, our 2003 DGC ES does, and it works perfectly fine, even from a stand-still, even if only one wheel has any traction. I think I'd get a second opinion were I in your shoes.
    Best Regards,
    Shipo
    95voyager95voyager Member Posts: 1
    I have a 95voyager, it recently dies on me and am geting rid of it. I have a full tank of gas in it and want to get it out. this is my problem, i own a syphoning pump used for putting in the filler neck and pumping the gas out. the hose will not go in the tank that way because of the "check ball" or overflow ball in the neck prevents this.
    My question is, what is another way to get the gas out of the tank besides though the filler neck which wont let me??
    lexan1965lexan1965 Member Posts: 118
    I've been told by a DCX technician (who just happens to work on vehicles after hours, including ours) that the caravans are notorious for having the window motor/regulators go out. They get a "short" in them and don't work for a while then they work all of a sudden. We just had ours replaced in our '02 GC for 180 dollars, including labor. The new replacements motor/regulators have a larger gear on them and a shorter cables. From what I was told the motor does not have to work as hard and they have not had any issues with them yet. Good luck!
    greencalgreencal Member Posts: 18
    Thanks, This Van has many Electrical problem,
    Beside regulator, We notice some time Hatch back door unable to unlock ( with remote or key) or lock and have to tie with rop!
    Some time Recycle air button stop functioning !!
    any suggestions!
    I have not had any issues with our tailgate, nor have I heard of any, sorry!
    This link shows the new Gen5 vans in the greatest detail yet:
    http://www.allpar.com/model/m/2008-minivans.html
    Very nice. ;-)
    Best Regards,
    Shipo
    mrbizness1mrbizness1 Member Posts: 93
    Here is a link for the New Town & Country
    http://www.jalopnik.com/photogallery/townandcountry/
    escort1escort1 Member Posts: 2
    I have a 1994 Dodge Caravan SE it has a bad shake in the front end I have replaced the axels, struts, driver side motor mount and tranny mount. Now the shake is still their I am trying to find a motor mount for the passenger side its bad and I am being told that will cause the shake but all the after market ones have a 7/16 through hole for a 3/8 inch bolt. Mine has a 9/16 hole for a 1/2 inch bolt and I can find one anywhere the dealer even says he cant tell me if the one I could order from them at $105.00 will have a 9/16 hole has anyone had this problem and what did you do to fix it :mad:
    jpfjpf Member Posts: 496
    Have you checked your tires? You may have a bad tire on the front. I had an 86 Chrysler Laser that I bought used. It had a bad shake in the front. I had the car checked out and the mechanic did not notice anything unusual. Rotated the tires and the shake was gone. Turns out that one tire had a bad belt in it. Try rotating the tires. It may help. Good luck.
    yes i forgot to put in i got new front tires & Wheels
    tcollietcollie Member Posts: 1
    where do I begin? My engine blew at 52,000, the automatic doors work when they feel like it, the brakes constantly need adjusting, the suspension rattles, DO NOT BUY
    So, in those 52,000 miles, how many times did you have your oil changed? What was the longest interval (in time and miles) between any two oil changes?
    Best Regards,
    Shipo
    abenitez60abenitez60 Member Posts: 1
    ">hello can someone tell me if a 1996 dodge caravan 3.0
    3speed have a v.s.s. veihcle speed sensor in the transmission.and if it does where is it located.my van runs fine but when I stop or lower the speed and give it gas again it stops and I have to re start it everytime.the map sensor was changed,and it still doing it I dont want to get ripped off so can some one help me in guiding me so I can know what the mechanic should do and dont get ripped off. thank you much. :confuse: :confuse: :confuse:
    89stang89stang Member Posts: 2
    The problem may be the catalytic converter checked. It could be that it is clogged up.
    I have a 1996 Grand Caravan and the problem that I am having is that it won't shift out of second gear. It tacks about 4000 RPM at 50 MPH. The transmission has been rebuilt but wont shift out of second gear. Would changing the shift selinoids make any difference?
    wkndwarriorwkndwarrior Member Posts: 2
    I have a 1999 Dodge Caravan. It has four engine mounts -- front, rear, left and right. I need to replace the rear and front engine mounts. Mechanic tells me the parts are dealer only, and pricey. Trying to find them online on the cheap cheap, but everyone seems to have only the left and right. FYI, the left and right mounts are sometimes referred to as "right-front" and "left-front." But these are not the true front and rear mounts. I need the rear and front. Any suggestions?
    "I need to replace the rear and front engine mounts."
    What makes you think you need to replace those engine mounts? I have a 1998 with the 3.8 liter engine with over 134,000 miles on the clock, with the factory engine mounts still in place. I just recently inspected all four mounts, two of them off the van, and they are all in excellent shape with no apparent wear.
    Best Regards,
    Shipo
    Hi Shipo,
    They are actually cracked.... which reminds me... I forgot to put in my last post ... I need the bracket that bolts between the front mount and the block. This one is real hard to find. No one seems to stock it except the wallet-biting dealership.
    Hmmm, I'm not sure what has caused your mounts to fail so early, however, I do have a suggestion that will be substantially lighter on our wallet. Have you called a bone yard? If you have either a 3.3 or a 3.8 liter engine, I'm betting that you can probably get all four, brackets and all for $100.
    Give it a try and let me know how it works out.
    Best Regards,
    Shipo
    jkbiggsjkbiggs Member Posts: 1
    I have a 05 dodge caravan 6cyl automatic 50000 mi.
    The gas pedal sticks when I first start to accelerate. Sometimes at a stop I have to stomp on it so hard that the van lurches ahead. It only sticks at the top of the pedal, its fine once I'm pass the sticking point. Anybody know the cause of this and how to resolve Thankyou
    filmmonkeyfilmmonkey Member Posts: 1
    I have a 2000 model Grand Caravan Sport AWD. It has 110,000 miles on it and is running really well. I have replaced the drive belt, AC system, battery, tires, rear brakes and exhaust system and am hoping it is now set to run for a few years without major incidents!
    Here is my problem - every time I put my foot down to the extent that revs go up to about 3000, I hear a fairly loud whistling noise. It sounds like it is coming from behind/below - ie not the engine. It is not wind noise as I can make it happen at 30mph just as easily as at 70. Does anybody have any ideas what this is? My main question is whether if it is a major problem that needs to be fixed or something I can ignore.
    aladdinsanealaddinsane Member Posts: 182
    Hi all...
    Can anyone explain the fact as to why Chrysler has omitted electronic stability/traction control from the '07 Caravan?
    Excuse my ignorance on this...but I think such an omission has hurt rather than helped the Caravan, especially the short wheelbase, 4 cylinder model. Not everyone wants or needs the Grand Caravan model, and I say this without dissing any owners of that version. My wife and I rode in the smaller model of a new Caravan yesterday, and I sat up front in the passenger seat. I was amazed at the panoramic view one has from this angle, and turned on to the Caravan thinking it a far more sane alternative to some SUVs out there, in more ways than one.
    Please inform!
    Many thanx...
    Peace! :shades:
    Correct me if I'm wrong, however, I don't believe that any DC minivan has ever had stability control.
    Regarding traction control, while I don't know about the 2007 model year, I can tell you that it has typically been reserved for only the higher end vans. Case in point, our 1998 DGC Sport 3.8 was not offered with traction control at any cost while I believe it was standard equipment (or at least an option that we selected) on our 2003 DGC ES 3.8.
    As for driving impressions both with and without traction control, personally I don't get the attraction. We live in snowy New Hampshire, and have at times needed to make our way up our driveway (a 9% grade) in some very difficult conditions. The only time the 1998 was unable to make it up in anything less than ten inches of snow (my personal limit for attempting the feat), the traction control equipped 2003 failed as well. Of course I suppose the fact that we had an inch of ice covering everything might have had something to do with that. :blush:
    In day to day winter condition driving, both vans perform wonderfully, and by virtue of their FWD layout, traction control simply doesn't make much of a difference, if any at all.
    Best Regards,
    Shipo
    Traction control is an overrated option as far as I'm concerned. I have an '06 Caravan with the 4 cylinder engine. Traction is fine. During the winter months, I use 4 snow tires. Driving with 4 snow tires during the winter gives much better traction than all season tires with traction control, in my opinion. I would not let the absence of traction control prevent you from buying the base Caravan. So far, I have 14,000 miles with no problems. Good luck.
    kap222kap222 Member Posts: 1
    I just got the same code on a 2004 Grand Caravan SXT about the same milage. What did you find the problem to be?
    I am looking at buying an extended warranty for my Caravan. The local dealer prefers CNA to Chrysler because Chrysler is tougher to deal with when there are repeated claims for the same part. Has anyone purchased a CNA warranty and had a warranty claim? Were they easy to deal with? Any response (favorable or unfavorable)is appreciated. Thanks.
    coderedcodered Member Posts: 43
    hi i have a 01 grand.....my power steering pump fluid is coming out of top of reservior....any help would be great.....thanks billy
    gary1960gary1960 Member Posts: 5
    Hi.
    i have a 1998 grand voyager 3.3, the other day the car completley died. nothing at all happened when i turned the key, under the right hand side of the steering wheel i heard one of the relays buzzing, after it stopped the car restarted, but the lights on the console for rear wiper wash and air con kept flashing, yesterday i drove the car fir about 5 miles, when i parked up the console behind th steering wheel went haywire, all dials were jumping up and down, milages numbers flashing off and on, i drove home and had to guess most of speed as speedo was jumping.
    i got home, switched off engine, restared all ok !!.
    this morning i went to start the car, it was completely dead,
    the relay was buzzing again,
    i checked the battery with an AVO, 11.8Vdc.
    i tried the car again, it started, i left the AVO connected to the battery, it was charging at 14Vdc,
    any idea what is causing this?.
    twocycle2twocycle2 Member Posts: 55
    While I'm no expert by any means, you might have the battery itself tested. When I bought my 2006 Caravan, it had been sitting on the lot for 18 months and only had 8 miles on it (so it obviously spent a lot of time just sitting there). We had to jump it to start it...it ran fine, but did exactly as you described....guages jumped around, dash lights flashed on/off randomly. It was diagnosed with a bad battery....once replaced, it has worked fine since. I now have 5k miles, with no problems whatsoever. Many auto parts stores will test your battery and alternator for free....I'd have both checked first before I started replacing any parts.
    Good Luck!
    Twocycle2
    Hi
    many thanks for your advise, the battery has checked out ok.
    the dials on the dash haven't done it again. and the car hasn't conked out again.
    but what i am left with is on the climate control panel. the orange bulbs flash on and off, with exception to the window heater,this does not illuminate when i push the button while the others are flashing. they will flash for about 30 minutes before they stop.
    when they do stop the window heater button illuminates when switched on.
    all of the buttons function ok when pressed.
    i have taken the controls apart to see if there is a dry joint ar arching on the pcb, but every thing seem ok.
    i have taken the connections off the rear window for the heater, but this makes no difference.
    i need to do the same for the front window heater,
    if its not that, looks like i'm beaten,
    hand over to chrysler.
    £80 per hour just to diagnose fault.
    again
    many thanks.
    gary.
    jjtjjjtj Member Posts: 80
    I have a 2003 GC Sport 3.3L. Recently, I have noticed the fuel pump making a noisy whistling sound, much louder than the hum that I'm used to. The van has about 75K on it, I changed the fuel filter around 40K or so. I'm wondering if the pump is about to go out. The van seems to be running OK, no skipping as I've experienced on other vehicles where the pump is going bad. I'm considering taking the pro-active measure of changing the pump before it dies completely, if this is what's going on. My wife drives our 1-yr old triplets and 3 yr old daughter in this vehicle, and I don't know how she'd ever manage if the van broke down on her. If I wait till the tank is fairly empty, I don't think it would be a huge deal to change. Any opinions or experience? Thanks..Jason
    engr2go1engr2go1 Member Posts: 10
    I have a 1998 Dodge Grand Caravan. It has 211,000 miles on it and the fuel pump went bad. I thought it would be a good idea to remove, clean and inspect the fuel tank while replacing the pump. The only problem I am having is removing the two hoses that attach to the top of the tank (not the ones that connect to the pump). Can anyone help me? There is no clamp. Only a hose pushed onto a plastic elbow that appears to be molded with the tank. Is this hose glued on? Do I need to asdd heat? Joe
    kwokmansungkwokmansung Member Posts: 1
    I have the same car as you and the same problem. I was wondering if you have found out how to fix your problem. And could you please tell me how you fixed your car?
    Hi.
    i took my car to chrysler for it 82000 service, they reset the consol, cost £25.
    they said that the blend doors behind it for the heater are noisey, and if it happens again the heater matrix will need replacing, £1500,00p.
    not what i wanted to hear either, hope this helps.
    gary.
    chazeppingchazepping Member Posts: 4
    We recently bought this minivan second-hand here in Spain, and unfortunately the owner´s manual is in French.
    Does anyone know where we could download one online? I´ll pay for it if necessary.
    Thanks in advance,
    Charlie (Eliz.) in southern Spain
    i have a 01 3.3 gcv....have put new ps pump on it 4 weeks ago....did not help anything .fluid is coming out of top of reservior...feels like air is in the line when heats up.. paid some to put a longer hose "was told they were to short"..tell me my grand is not the only one to do this.. any help would be great thanks billy
    oldsalt2oldsalt2 Member Posts: 8
    I would try ebay. Here is one that I found today for a 1999 Plymouth. There was another that expired today.
    http://cgi.ebay.com/ebaymotors/1999-PLYMOUTH-VOYAGER-OWNERS-MANUAL-99-OWNERS-MIN- IVAN_W0QQcmdZViewItemQQcategoryZ34231QQihZ020QQitemZ300029509601QQrdZ1QQsspagena- meZWD1V
    Chris
    Thanks, Chris- I'll give it a try...I was hoping I might find one I could download, mostly to save time.
    Cheers,
    Charlie
    I would imagine it's too old for a downloadable file. If you tell me what you need, I can scan and send it to you. Mine is pretty thick to send the whole thing.
    If you could send me the page(s) on the central locking system and the air conditioner controls, that would be great.
    ´Really appreciate your offer,and thanks in advance,
    E.
    I've got it scanned, send me your email address and I will try to send it. The 19 pages are pretty large file size, so it will take about 5 emails to get it to you.
    Thanks so much...I really appreciate the trouble.
    My email is chazepping@yahoo.com
    Cheers,
    E.
    P.S. If your ever make it to southern Spain, come see us - we´re in a little village a 1/2 hour from the Costa del Sol, where we have a little boat in one the marinas.
    leo38leo38 Member Posts: 2
    I have a 2002 voyager minivan the fuel pump fuse keeps blowing out,when replaced it works for about 24 hrs and blows out again.
    I checked the pump relay in fuse box and seems to be fine also replaced the 20 amp fuse with a 25 amp fuse for testing and it went out, also used lucas fuel inyector cleaner two times and problem continues.
    any ideas what may be the problem?
    leotaurleotaur Member Posts: 17
    We have been very pleased with our 2005 Grand Caravan SXT and have 80,000 km ( about 50,000 miles?) and the auto door locking which is supposed to occur at 17 mph no longer functions, so we have to remember to do this ourselves. Is this a small problem which will cost a LOT to fix? Our dealer is probably OK, though they are always flogging extra services not mentioned in the service book when we go in faithfully at the recommended intervals.
    DougW W
    hayneldanhayneldan Member Posts: 657
    Check the owners manual and reprogram the doors to lock at 17 mph.
    drewlittledrewlittle Member Posts: 2
    I replaced the heater core last year and today the heat stopped. I have hot water in the heater hose, but no heat. Do I have a bad core or is it the control module? How can I determine what is wrong?
    camkencamken Member Posts: 1
    i have a 2002 dodge caravan that had a factory cassette radio in it. My friend had a 2001 caravan that had a factory dvd system in it plus a cd / cassatte radio in it. I bought it off him and and installed it in my van. I had to get the stereo shop to convert the radio plug in my van to fit the cd radio i got. I ran all the wiring harness the same way and my radio works but i cant get the dvd system to power up does anyone know why? Or if any one has an instruction manual for that system cause im not sure why its not working or if im missing something.
    sjasja Member Posts: 11
    About 6 months ago, the wife had a flat right rear tire on our 99 GCV. So, doing the husbandly duty, I got the jack out and went to lower the spare from the undercarriage. No luck. Beat it from all different angles, no luck. Tried to pry it down from the winch, no luck. The cable was slack so I knew it was supposed to come down as it had before when it was used. Nothing worked.I unbolted the entire winch assembly, with the tire still attached. Finally, after struggling with it for another half hour, the winch assembly let the tire go. Needless to say, the whole thing ended up in the trash. The cable and mechanisms were all twisted from trying to get the tire down. The local Dodge dealer wants $150.00 for a new assembly. I've tried the local junk yards with no luck. Does anyone know where to get one of these things, cheap? Oh, and it has to work.
    In addition, I'm also looking for the right front passenger window upper seal assembly. Another pricey part from Dodge.
    Thanks in advance to anyone with info.
    Your best bet might be to try the web periodically. There were a couple listed today but I couldn't figure out how to get to the seller. Good luck!
