Mazda Millenia
14344464849127
  • fwatsonfwatson Posts: 639
    Your questions sound slightly leading, as if you are expecting problems.
    I have owned an '01 P for six months. It now has about 4700 miles on it.
    1-The only time it seemed less than quiet was when I took it home from the dealer, about a 90 mile drive. There was quite a bit of tire noise on that trip. The next morning, after it had had a chance for the tires to cool down, I checked the tire pressure. They are supposed to be at 32lb front, 29lb rear. I found 35 to 36 lbs in all four tires. That means the rear were overinflated by 6 to seven lb. I removed the excess air. Instant relief. Absolutely no body noises at highway speeds, and only minor motion sound when crossing railroad tracks at very slow speed, something found in virtually all cars.
    2-Transmission seemed a little indecisive when new. Now it is excellent. I think it reprograms electronically as you drive it. Of course it WILL downshift on mountain roads. It has to to keep the engine in proper range. That can be easily locked out if it bothers you.
    3-Absolute no sound from the transmission, except the normal turbo whine which you hear only if you are not running the sound system. After all, it is an automatic, and my Olds 88 has more of this sound than the Millenia.
    4-I have run 87 octane gasoline since new, with absolutely no degradation in performance from the original 93 octane the dealer had put in it. The owners manual recommends premium, but says it is permissable to run as low as 87 octane. On the other hand, the S "Requires" 93 octane or higher. There also is no ping etc from the use of 87. The EEC Module automatically adjusts for the octane change.
    5-The placement of the radio, is not even close to the shift lever. Plus you have volume/station change controls on the steering wheel.
    Next post:
    Unless you are a member of the Stop Light Grand Prix Association, the car has great, and extremely quiet and smooth performance. That it does not is a figment of the imagination of those members of the racing and hot rod set. If you want a drag racer buy something else. If you want very satisfactory performance for normal street car use, buy this beautiful and great driving car for a givaway price that won't even get you a mediocre equipped CamCord.
    I have never experienced the high speed engine noise referred to by csuftitans. But on the other hand, the fastest I have driven the car, is about 105 to 110 MPH, where it was butter smooth in all respects. It is a great highway cruiser.
  • stbissstbiss Posts: 10
    I have to agree that the 2.5V6 is more than adequate for this car for normal driving...it wil not win any drag races, but has plenty of pull at higher rpm's..I have driven thie engine since 1994 (6 years in a '94 Probe GT and now my 2000 Millenia) and have had nothing but good service...very reliable engine...early versions (93/94) had some O2 sensor problems and leaky valve cover gaskets, but later versions appear to have solved these problems according to most websites on reliability...frankly, the volume of supercharged engines in Millenias makes parts and labor expensive since this is only used in this low volume car...the 2.5V6 was/is used in Probe GT's, MX6's, 626's and Millenias so parts and experience are abundant ...hope this helps...
    Please allow me to add that this is a Mazda engine. It was only used by Ford, because they own a big share of Mazda. There is a very good WebPage at
    http://www.bradbury.cwc.net/probemx/
    that tells you about this great engine.
  • csuftitanscsuftitans Posts: 215
    fwatson, dude, I said engine is a bit noisy at HIGH RPM, not at high speed. I know it's pretty quiet at high speed, I know this since I've also owned a '93 626 ES with same engine.
  • saxoniisaxonii Posts: 31
    One learns new things every day. So Ford Probe has the same V6 as Mazda Millenia. Wow now I know that Millenia is it. No wonder Asanti never materialized, with the same engine as in Ford Probe there would be no limit to where this car could go. I wonder how would owners of Lexus or Infinity feel if they were to find out that their beloved engine comes from Chevy Cavalier. Thanx for the info. I really needed something to make my day. In all seriousness I am seriously contemplating getting a Millenia now. Ciao SAxon II
    Are there any other cars that are using Millenia'a engine aside from Probe and 626?? Just wnat to know amd btw, when an engine is very loud at high rpm, what does it mean ????? Is that an indication of a inperfect consruction or other defect???? Please enlight me. Cioa Saxon II
  • It means you don't have as much sound insulation as you'd have in, say, an '86 Grand Marquis.
  • protegenicprotegenic Posts: 199
    when the sarcasm is too high? Saxonii, we know how you feel about the Millenia. Spare us your dry wit, please.
  • patpat Posts: 10,421
    Careful folks - if you have nothing helpful to say, just don't say anything, please.
    (If I were a so-called "troll" I would delight in posting on this board, because I would get *so* much attention. Think about it.)
    Pat
    Sedans Message Board
    it should be no revelation that Ford and Mazda share items among cars...Ford owns close to 1/2 of Mazda...it's all about money is the reason why engines are shared..Is a Lexus E300 less vehicle because it shares a Camry platform and V6 with the Camry, Avalon, and Sienna minivan? Absolutely not! It's because development costs are extremely high for new engines to have a unique one per vehicle...I bet SOME people would be highly disappointed to know that Nissan has used the same engine in the Maxima and InfinitiI30...if anyone has doubts about the 2.5V6, see the website mentioned in previous message - it has an excellent track record - another reason why it is used in so many models....
  • mackman1mackman1 Posts: 6
    SDA you claimed in your 2/26/02 message that you can buy an '02 Millenia for as low as $19.5K.
    Please be kind enough to share those details w/ the rest of us looking to buy a Millenia now.
    Can anyone else shed some light on this topic.
    Where can a serious MIllenia buyer get the best deal on an '02 Millenia "P"?
    mackman1, I don't know where you live, but a weeks ago, I saw an ad on Los Angeles times for 2002 Millenia P for $20.5K; this is in Mazda dealer in City of Redlands, about 60 miles east of LA
    http://www.redlandsautocenter.com/
    At other dealerships, I think the price is no less than $22K
    Before buying my "01 P for well under $22000, I went to a Clearwater Florida Mazda dealer who was running one of these ads for Millenia's under $20000. I believe his advertised price was about $19500. I looked briefly around the lot before being tackled by a high pressure salesman who informed me that particular car was long gone, but they had plenty more Millenia's in stock. When asked what their lowest out the door price would be for a Premium model, he started quoting MSRP's. I objected to the use of this fairy tale price, and was told unless I showed a commitment to buy, they would not talk price reduction.
    I then walked away with him objecting, and went to Courtesy Mazda in Tampa, where I was immediately given an out the door price of $23000 by a very courteous salesman, after he contacted the sales manager with my request. That took about ten minutes. After a test drive, and a lot of discussion, I purchased a Platinum Silver "P" with 3 miles showing on the odometer for that price, which ammounts to about $21680 plus tax, tag etc.
    In other words, those absurd low prices, under $20000, appear to be outright lies by high pressure dealers to get you onto the lot and sell you something else as close to MSRP as they can sucker you into.
    When you walk onto their lot watch out for the bear trap. Or better yet, just go to a good dealer to start with.
  • otoluvaotoluva Posts: 167
    have caught my attention lately,$21680 for a brand new 01? I'm just wondering what a used 01 with a few thousand miles would sell for,$17k+?
    Although the Millenia never made it to my top 5 sedan list,that's heck of a deal for a car that is supposed to be competing with the likes of Acura TL and BMW 3s.
    Also,having read some of the posts on this board,I noticed the P is more popular than the S model,just curious why?
    Millenia does have a high depreciation compared to the CamCords. Search "Mazda Millenia" on EBay, and there are a couple of '01 Millenias in the price range you suggest. I would guess that means you could also get that price locally with a little work.
    I personally rejected the "S" because of the added maintenance and complexity of the supercharger. Plus, I simply didn't need the extra power that provides. The "P" has very satisfactory power for normal use, and the 2.5 V-6 is much smoother than the I-4 engines in the other cars sold in the low $20000 range.
    If you plan to keep a car for several years, the depreciation becomes a moot point, and the Millenia is a very highly rated car for reliability by both Consumer Reports and Carpoint online.
    http://carpoint.msn.com/home/reliability_ratings.asp
    Do you own a Millenia? If so what are your thoughts in general?+s and -s,I think my wife likes the car and I definitely believe the price is right,she thinks it's time to replace her 93 Subaru Legacy(still rock solid at 115k miles,but you know image is important to most women!)
    Any input from Millenia owners is appreciated.
  • ddrake30ddrake30 Posts: 18
    I have a 96 millenia L with 75,000 miles that I bought almost 3 years ago. I agree with other owners that the 2.5L engine is plenty adequate for everyday driving. However, if you're a lead foot or like more spirited driving (like myself), then you might think the P is lacking a bit in power. I sometimes think the suspension could be a little tighter (too much body roll), but otherwise the car drives very nice and is exceptionally quiet. As others here have indicated, the major downfall of the millenia is its high depreciation. If you plan to keep the car for a long time, though, this is inconsequential.
  • billyperksbillyperks Posts: 449
    As you know my Millenia went back to bank but I still keep up with the post here.Just one quick question for you- From what I have been reading here, are you guys implying that a the Millenia P cannot outrun or keep up with a Toyota Camry v6 or Honda Accord V6, but it is more suited to go up against the 4cylinders Accord and Camrys?
    Fwatson when I get my new ride I will enlighten you.
    CALLING TOMEKK ARE YOU OUT THERE!!!!!!
    GET BACK ON THE BOARD PLEASE.
    Despite the fact I subscribe to Motor Trend, Car and Driver and Consumer Reports, as well as having read everything I can find on the Internet concerning the Millenia, I still do not know what the 0-60 ET is for a P Millenia. All the tests I can find report on the S. And those tests are rare.
    That puts me in the position of not being able to directly answer the question of whether the P is able to compete with the CamCords as a drag racer.
    I am old enough that I no longer personally compete in the Stop Light Grand Prix. So I also can't answer that from personal experience.
    If you have read my previous posts, you know I have repeatedly said that my P has plenty of power under all normal conditions, and I am very satisfied with it. You can also tell from those posts that I am very fond of this car in all respects. After having owned at least twenty cars in my life, I can honestly say I find my Millenia superior to any I have owned. Admittedly most were Big 3 cars, but they also included Toyota and Renault (don't ask).
    My reason for mentioning the 4 cylinder CamCords in a recent post, is not to compare acceleration, but rather that it is all you can get in them for the price I paid for the Millenia P, not that I consider them at all competitive with it. From what I have read, the Mazda 2.5 V-6 is one of the best engines ever built, capable of holding up to professional racing. If it said 3.2L 240HP on it, the Millenia detractors would melt into the woodwork. That is the only place I can see Mazda has failed to please the Boy Racer crowd.
    I test drove Camry, Maxima and others, all V-6's, before buying my new Millenia, and did not find any of them super powered. I found the Millenia more pleasant than any of the others, including the new '01 Avalon that I was offered for just $3000 more.
    What more can I say? I believe the Millenia is the best kept secret in automobiledom (is that a word?). But that worked to great advantage for me, in being able to almost steal a super fine automobile, for the price of a stripper CamCord or similar appliance.
    I might add for those who might be curious. I have no connection to Mazda or it's dealers, except for being the proud owner of a car that makes you feel special just to be seen in it, and to drive it.
    I very highly recommend the Millenia to anyone looking for the biggest bargain available in a great car. Your chance is running out fast, as they will no longer be made after the 2002's are sold out.
    Frank Watson
  • marak88marak88 Posts: 57
    Car point has the time for the 0-60 for both S and P models, check it out
    http://carpoint.msn.com/vip/Heraud/Mazda/Millenia/2002S.asp
    for the Carpoint information. I don't know why I hadn't found that with all the research I have done on the Millenia.
    According to carpoint the Millenia S 210 HP is actually faster than 225 HP Acura TL but not faster than 260 HP Type S, I Think that this is v.good that the Millenia S beats the 225 HP TL
    ( the TL also has more Torque 216 fp), but the millenia still beats it not only in 0-60 but also in the top speed and the braking distance as well, I guess the millenia S performance is not bad at all after all, :)
    http://carpoint.msn.com/vip/Heraud/Acura/TL/2002S.asp
    I always find this particular reviewer's times to be on the slow side when compared to other publications and reviews. Seems like I saw where the "P" 0-60 times were in the 9.4 to 9.5 range. Not great, but certainly acceptable for most of our driving needs.
  • jaycee4jaycee4 Posts: 1
    I read all 50 reviews on carpoint for the '01 Millenia.
    Seems like alot of Millenia owners are disappointed in the lack of engine power both on the "P" & "S" models.
    In addition, it appears that many owners complain about the sluggish,indecisive & not smooth transmission on the '01 model.
    Did Mazda correct the transmission problems for the '02 model or is it the same as in '01?
    After reading these owner reviews on CArpoint it's hard to be excited about buying an '02 Millenia.
    I'm interested in knowing what kind of experience '02 Millenia owners have had.
    I guess it's a matter of interpretation. I also read the 2001 and 2002 Millenia, as well as Camry, Accord, Acura TL and several others. Both '01 and '02 Millenia owners rated the cars 8.4 overall and 7.2 on performance, which is higher than most of the others I read.
    A sampling:
    Acura TL======8.7 overall - - 8.7 performance,
    Accord========6.8 overall - - 6.8 performance,
    Lexus ES300===7.0 overall - - 6.9 performance,
    Millenia=======8.4 overall - - 7.2 performance,
    Camry========6.4 overall - - 6.3 performance.
    I'm not a professional statistics analyzer, but either I am missing something here, or the Millenia owners as a group aren't as disgruntled as your post would indicate.
    You might try reading reviews of other similar cars. Every brand and model has it's lovers and detractors. I have read a lot of reviews, and the Millenia fares very well.
    saxonii, please check your email
  • obioha1obioha1 Posts: 27
    I actually had a chance of test driving both today because I wanted to see if the price difference was worth it and there is a noticable difference in the acceleration between the S and the P. I currently own a '99 S and I never thought that it was that fast but it feels like a vette compared to the P model. Another thing which I noticed was that the shifting from like 2nd to 3rd was extremely jerky and a little scary, because I would hit the gas and nothing would happen and then suddenly the car would jerk forward and start accelarating. This hesistation could lead to disaster merging onto the freeway. The interior layout of both cars is truly impeccable putting to shame the cheap looking interior of the '02 maxima a friend of mine has. In fact the millenia's interior is on par with higher end luxury cars. I just love those optitron gauges. The brakes on both cars were truly outstanding, and I couldn't tell which one had better stopping distances as both stopped short and surely. The radio in the P(non bose) isn't that bad, in fact it is a lot better than the bose in my '99 S. I guess the addition of a mid control helps. The bose in the S is pretty nice with good bass extension and is actually better than the bose radio in the I35 that journalist seem to love. (my mom has a I35, so I'm speaking from exprience). I just wish that mazda had contracted a different audio supplier, because bose radios seem to not have enough highs and the lows aren't as smooth sounding as in other systems. Finally the handling in the S was phenomenal to me. I was taking curves at high speeds and the car felt very planted. The addition of the rear antiroll bar makes a significant difference. The P wasn't as confidence inspiring. All this said the P is an exceptional car but wouldn't be for me because of the lack of power. It takes to long to do what my S seems to do without sweating and the transmission just plain scared me. The 2.5LV-6 was a lot smoother reving than the miller cycle but looked like it was working too hard to accelarate. In the 626 this might be adequate power but in a 3400 lb car, it just isn't enough. Other posts have said that the transmission "re-adjusts" itself after sometime, so if this is the case then you can't go wrong with either car. For me its "miller time"
    P was 23000
    S was 25500
  • juliziojulizio Posts: 18
    Has anyone experienced any problems with the front end alignment?
    I just had my oil changed and tires rotated at the local shop and it turns out the inside shoulder of both front tires is almost down to belt.
    The car is a 2000 ME with only 21,000 miles on it. As far as I know, the front end hasn't had contact with any curbs or large potholes. The rim is fine, only the tires are really worn on the shoulder. It almost looks like someone cut it with a knife.
    Is something like this covered under the warranty?
    I started shopping for new tires online and noticed www.tires.com lists the 235/45/17 as a plus zero upgrade for the car.
    I called them and asked if the tire would fit on a stock rim and the guy said yes. He also said the stock rims on the S is 17x7.5, I thought it was 17x7. The rim has 17x7jj stamped on it. Does the jj denote 1/2"?
    I may try these tires once I get the alignment issue straigtened out.
    Anybody put this size tire on the stock 17" rims?
    Any help would be greatly appreciated.
    Thanks...
  • tomekktomekk Posts: 310
    Hi Billy...
    you know, it just isn't worth my time.
    But to stay on topic: for me Millenia S was the right balance of luxury / sportiness / size (although I'm 6'3!) and PRICE. IMHO everybody should look at it that way and not take religious stands against or for; unbiased and _common sense_ based intelligent hosting would help, too.
    I think obioha1's comments are right on the money - for $26K (in my case) you get a car with great interior (yes, those optitron gauges!), great roadholding, more than decent power (and the more you drive it, the more you learn how to utilize this power - 210HP is quite enough for me). Acura TL-S for 8K more wasn't _worth_ those 8 large more....
    Now, you need to look at what is important to you - price? power? reliability? that's why there are different cars out there - Kia, Bentley, Mercury Grand Marquis... I am perfectly happy with my 01 S with two anti-roll bars and ski pass-through (BTW, what's going on with winter this year???), Frank is perfectly happy with his 01'P because it suits him just fine. End of story.
    Take it easy,
    Tomek (who wouldn't buy a car without ski pass-through, because it is important for him) :-)
    P.S. Glad to see this place somewhat de-trollized and kept free from irrational rants.
  • I traded my 1999 P in for a 2001 S in October. I absolutely love the S. I'm glad I upgraded! Besides the increased power, I have enjoyed all the other new upgrades too...gauges, lumbar support, steering wheel radio controls....
    Taking a trip on wed...driving from Atlanta to Orlando...can't wait to get out on the road...
    zoom zoom zoom
