For the 6-cylinder XLE they said "Braking performance was excellent overall".
The 6-cylinder XLE has the 4-wheel disc brake system and the 4-cylinder LE has the front disc/rear drum system. This could certainly explain the difference.
~alpha
Yes, except that I test-drove a 4-cylinder XLE and was very unhappy with the brake feel. So either there is a problem with the 4-wheel disc brakes as well (perhaps only in the 4-cylinder and not the 6-cylinder for some reason??) or else the brakes are fine and my discomfort was a personal feeling that isn't shared by anyone else.
In the meantime I haven't had any luck yet finding a dealer who will rent me a 2002 Camry, nor a rental car agency that carries them. I really want to rent the exact car I'd be buying (a 2002 XLE 4-cylinder) and I'm pessimistic about finding one. I'll keep trying though.
"Power-assisted ventilated front, solid rear disk"
This is the same for the XLE V6 and the SE (4 and 6). Only for the LE trimline are drum brakes mentioned at all.
This same information is given out on Edmunds and by Consumer Reports; of course they probably get it from Toyota.
~alpha
I have also had problems with the paint chipping easily. I have had the car since September and already have 5 or 6 chips in the paint. Every time I wash the car I find a new chip.
When I bought my '00 Chevy Silverado the dealer gave me a bottle of touch up paint when I signed the papers. My Toyota dealer wants me to pay for a bottle of touch up paint.
Don't get me started on the other problems with my '02 Camry.
Check your driving conditions they may be responsible, and remember that that is what the dealership is probably going to throw in your face when you point it out.
I have always thought that our '96 Camry's paint was a tad too thin....compared to other vehicles we have owned.
~alpha
My 89 Cady with 105,000 miles on original paint looks like new compared to the Camry. I'm curious if the Toyota Lexus line suffers from the same paint problems or is this a case of "you get what you pay for."
Now, my friend has a 1997 ES 300. His is silver and the chips are much less noticeable due to the color of the paint.
Hope this helps.
Paint chips easily.
3 squeaks/rattles: one around the back right seat, one where the seat belt attaches to the b pillar, and an intermittent rattle around the sunroof controls.
The transmission acts like it can't find a gear when around 40 mph. I take my foot off the accelerator for a moment and the rpm's drop like the transmission is going to neutral. There is also a shudder in the trans between 20 and 40. And when the engine is cold the shift from park to drive/reverse is anything but smooth-there's a pretty big lurch.
I am also an owner of a '02 SE. One question-are you having problems with leg cramps? Every time I drive this car I am in serious pain in my right leg. I have read reviews noting a lack of thigh support in this model is a major weakness and tried everything to fix it it with no luck.
Any suggestions? I'm in a lease and just dread the next 32 months.
Mark
PS I'm 6'1" and 230-maybe the seat length just isn't long enough
Incident: No
Fire: Yes
Number of Injuries: 0
Date of Failure:
Component: ENGINE
Summary: WHILE DRIVING THERE WAS SMOKE COMING FROM VEHICLE. WHEN CONSUMER SAW SMOKE STOPPED VEHICLE, AND THEN VEHICLE CAUGHT ON FIRE IN ENGINE. CONTACTED DEALER, AND DEALER WAS NOT WILLING TO DO ANYTHING.*AK VEHICLE WAS COMPLETELY IN FLAMES AND FIRE DEPARTMENT CAME AND PUT OUT THE FIRE. *YD this was one of complaints from nhtsa site. another was starter fire, tranny failing at 2000 miles(a few of them) for various Toyota models...
the dumbest and most fraudulent complaint was"faint turn signal noise"....that was not a real problem,bit someone thought it was.
All makes have problems. I was just shocked about engine fire!
I guess my friend won't knock Suzuki's again after seeing this?
hjr2, could you post the link to where you found that bulletin? Thanks.
setup, and the car has discs all around...
As for thigh support, I noticed the lack of
it also, and I'm 6'1"...I found that having
the seat as high as possible, and no lumbar
support in the back gave me as much comfort
as I could squeeze out of it...what works best
though is cruise control...
Also, on it's first extended road trip,
the car got 38.4 mpg !!! Outstanding !!!
No complaints so far, probably 'cause the
wife is always driving it !!!
the labor. I do not want the Bridgestones, I believe the RE92's are the model supplied on the
16" tires I observed in dealers lot.
they're not M+S rated, either, so I don't
expect much traction in the snow...
I'm thinking about going to tirerack.com
and ordering a set of rims and tires for
use during the winter...
Thank you for your replies. Unfortunately I tried both suggestions today and found no difference. My leg is in pain, my wallet is lighter and I'm locked into a lease for the next 32 months. If I could only go back in time. Damn, I'm depressed. I really want to like this car.
Sorry for venting. If you have any more suggestions please keep me in mind. Thank you!
Mark
PS Any suggestions on getting out of a lease? Does begging, bribing, anything help!? Maybe I can bring a note from my doctor like I did in elementary school.
Getting out of a lease is easy. It will cost you a small fortune though. The thousands you'll lose would be better spent, even if you have a customizer completely gut the seats and install whatever you like. Anything is possible with the $$ and right people.
You said "Any suggestions on getting out of a lease?"
Getting out of a lease usually results in a derogatory credit situation. I have a suggestion, why don't you trade the Camry for an Avalon. The seats in the Avalon are excellent, in every way, and your new lease payment may not be that much higher.
On the outside an Avalon may not be as "pretty" as a Camry but on the inside the dash and console is Lexus like in quality and tactile feel. If you can show the dealer that the Camry is not right for you, I am sure they would give you a fair deal on an Avalon, and most importantly you would retain your good credit.
they might be better
floor mount holes may be the same
do not know about the elctric seat connections
I have a meeting next week with my salesman and his manager to talk about the situation. The salesman said "it doesn't look like we can do anything but come on in and we'll sit down". I love these guys.
BWIA, that's an excellent suggestion about trading in the car for an Avalon. I hope it can be done.
Any suggestions on how to best prepare for this meeting? I don't want to get screwed in paying full MSRP for an Avalon but I'm sure that's pretty close to what they will offer. Also, how much value should I take off my car? It's about 4 months old now. 3,000 miles.
Anything, anything you can think of will help! Can't believe I'm in this situation after looking around for 3 months for a new car.
Mark
we test drive our new cars 50 + miles and if possible take one home for weekend.
If you don't have the cash to pay-off the lease, they are going to want to roll it into the lease or loan for the Avalon. That's getting to be a pretty big amount to roll into anything and they may not let you. Either way you're going to be in a bad way. That's why I highly recommend finding another way out of this unless the money makes no difference to you. Costs alot to get out of a lease early, let alone this early. You may be better off advertising for someone to take over the lease (assuming your contract allows an assignment) and maybe even pay them to take it over.
Best case would be if the dealer will sell you the Avalon for cost less hold-back, but that's still not going to get rid of the buy-out cost. Make sure you drive the Avalon for a long time because even if you do get into this with no cash out of pocket, you'll never be able to get out of another one.
This is only one of the reasons I don't recommend anyone to lease anything, especially if you have to way to write the thing off on your taxes. Loan situation would be better even if you had put nothing down on the car.
Stop by an upholstery shop and see if there's anything they can do.
Doing any of this will no doubt cost hundreds of dollars, but that's better than the thousands you will lose trading in. And trading in is exactly what you will be doing no matter what euphemisms they use.
May not cost quite as much to bail if you can find someone to assume your lease.
For all of you out there that are at least 6' tall please test drive this car for a while. I can confirm the seats are a little smaller and offer absolutely no leg support. BE CAREFUL!
The dealer said that it probably involves the ISC motor (Idle-Speed-Control?) which he said was dirty and sticking. He said his mechanics cleaned the ISC motor and that should (actually, he said "may") fix the problem.
My son will be driving the car today, so let's see what happens.
Is this a common problem with Camrys?
Have any of you had this problem?
From reading posts in the town hall, and other media information regarding the V-6, I've been under the impression that "premium" fuel is recommended. However, the February, 2002 issue of Consumer Reports tests of four V-6 family sedans (Camry, Altima, Intrepid, Grand Prix) states that the Altima is the only one of the four for which premium fuel is recommended.
Also what prices are you being quoted. I recently got $1369 over invoice.
Any comments on cost of ownership of this car vs Acura TL 3.2?
Your best bet is to find a dealership willing to order one. Of those 48, all are also coming with the side air bags and heated seats.
The dealer kept pushing on me this $500 dealer rustproofing that doesn't have to be retouched or freshened for 6-8 years. Has anyone tried this? And does it work?
What do other camry owners do for rustproofing in their areas, and in particular, could I hear from camry owners with 8-10 years and 100K miles.
For my 11 year old chevrolet lumina with 250k Km on it, all I did was a local company oil spray underneath every winter or every other winter. It is driven every day in salty road conditions in winter and still has no visible rust underneath or on the body there is only a minor beginning of rust (which I promptly slapped vaseline on!).
I know that GM uses Galvanized steel (I even have a 2 year old scratch through the paint on the body which still hasn't rusted) but Toyota doesn't.
My concern is will a local oil spray eat through the rubber parts like the dealer says? It never ate through my GM parts.
rust-through protection, which is defined as
'corrosion perforation of sheet metal'...I don't
anticipate any problems with mine, and I live
in WV...just run it through one of those car
washes with the undercarriage spray once a month
or so, and you should be fine....
Has anyone else ordered woodgrain? and what finish did you go with?
We'll eventually drive both, but I'm curious what your opinion is.
Found out from several tire dealers that this car is equipped with "Summer use" tires only. We immediately replaced them with Bridgestone Blizzaks and found the traction improved by 100%!
Highly recommend a Winter tire change for anybody driving this car in snow & ice conditions. I believe that it is the ONLY Camry that does NOT come with All-Weather tires. Be careful!
