Infiniti I30/I35 Brakes
The last year or so , have had problem front end brakes where they make a weird noise when they are applied. had car back to dealership and a top notch mechanic who has replaced pads and hardware kit and rotors turned. It's a creaking sound when you apply the the brakes at slow speeds. But theres no damage to the rotors or pads. Any ideas?
Any suggestions? :confuse:
When I realize what's happening I don't know how to react. I want to slow down but am reluctant to take my foot off the brake. And I can't relocate my foot more squarely on the brake without releasing brake pressure.
Has anyone ever experienced this problem with the I35? I've driven many cars over 35 years and never experienced this befotre.
Jim
anyone else...a cheaper solution first, however I will do the same if I have to.
I have the problem too, new pads.....well 5 months now but since the new pads..
First I thought it was because they where new and it would quit. Guess again, still makes the noise as low speeds when cruising through into the neighborhood and sometime when slowing down from highway speeds into the 30's.... 5 month old now..
I had heard about brake pads glazing over but that happens when you slam on the breaks with new pads right? before they're broken in? Anyway because hearing this I took it very easy for the first couple weeks - easing into stops... avoiding quick stops. Unless the mechanic at the shop was going NASCAR style around town to test the pads he put on my car....
But still if they where glazed over you would think that over time the pad would wear down and surpass the glazed surface.
Anyway, I was hopping someone has found a brake cleaner/pad cleaner/dust remover - something
I had the rear brakes done within the last year and the fronts are at around 50% left. Plus, new front tires put on recently. Thanks!
Jeffrey
Its the front wheels too. I took the tires back off with the calipers and took the pads back out, re-greased the hell out of them ... all back together... couple days later same thing.
took the wheels and calipers back off... I greased the pistons (or whatever you call them) that the calipers move back forth on; I think those are the culprits... there was no grease and the rubber boots where not fitted on so good.
Since ...weeks have gone by and it's started again... It must be nissan/infiniti calipers- crap! but... maybe I should switch to ceramic pads before I say more...
