Mercedes-Benz E-Class Sedans
Jean
Thanks for the words of wisdom -- I am on the phone as I type this response. I hope this is my problem because they called and hour ago and said all the systems read OK.
Rob
I took delivery of my E430 AWD, Brilliant Silver/Charcoal, E1, E2, COMAND, K2a, in April after a 5 month wait, and am delighted with it. Only regret is that I did not get the multicontour seats. The Xenon’s are terrific, and the headlight system actually adjusts itself adaptively when you accelerate or brake! (Really! Check it out some time). The thing is really quick and civilized all at once. A passenger (Buick Owner) once said “I feel like I’m flying” - comment on the smooth ride. I can’t wait until the first snow and experience with “freestyle driving”.
I’ve experienced some of the same problems that I’ve read about here, including the unfillable gas tank (that gains fuel as I drive!!), the maverick Right Rear Window, intermittently squeaky steering wheel (most prevalent when I make a turn to the lock in either direction) and a few other poltergeists. Among these last are very poor FM radio reception - which I ascribe to the in-window antenna. Also, the Remote CD player has this annoying intermittent habit of starting CD1, Track1 when I reenter and start the car despite my making no changes to the program other than shutting off the car from the last trip. Not always, but sometimes. My RR window problem only occurs when I’ve used the “all windows down” feature with the IR Key outside the car. In some cases, other windows have done this, too. While these are all annoyances to be sure, I’ve not been motivated to take the car back to the dealer for anything yet.
Here’s what I’ve learned about some of the other issues discussed here in different places. The StarTac phone is programmable with a flash-memory system, standard from Motorola. So, the firmware is MB’s and this is what allows the hands-free phone to work, but only with the MB code. I initially had some problems with my Cellular provider and they suggested that they could reprogram the phone. Had I allowed them to do this, it is probable that I would have lost the MB integrated features. If you have a non-MB phone and want it programmed to work in the car, you’d have to convince MB to do this for you - - it’s technically possible. As far as power output in the car, the interface to the car antenna is passive - there are no amplifiers in either path, and I don’t believe this is easily possible with digital cellular in general. The antenna is capacitively coupled to the car’s phone antenna in the cradle in the armrest. At least, this is my understanding.
As far as COMAND is concerned, I disagree with the Edmunds conclusion to not recommend the system. Their trouble with it has to do with “user friendly” interface issues. While this might be a problem learning a system “on the fly” in a rental car, if you take the time to learn its programming methods and other quirks, it works just fine. And unlike aftermarket systems, COMAND not only uses GPS signals, but it also dead-reckons!! (You pilots and sailors know what I mean). I got my car before DOD shut off GPS Selective Availablity (the deliberate contamination of GPS signals which made the solution both inaccurate and unstable). COMAND could tell when I emerged from the Boston Callahan Tunnel (no GPS coverage in the tube!), and also detected my direction change (with the map arrow on the screen) with the tightest turn I could make in the driveway! On the calibration page, it asks for tire size and wear - a giveaway that it’s counting wheel revolutions and steering direction (or Earth's magnetic field vectors) to dead-reckon. And, in fact, such a dead-reckoning system doesn’t have to be that accurate because usually the GPS signal is reacquired before the DR calculations begin to experience serious errors. You can be sure that when your in a tunnel, under a thick canopy of trees, or down among the skyscrapers in a big city, that the GPS coverage is nothing to depend on for sole-means navigation. I now depend on COMAND when I have no clear idea how to get to a destination. And, quite frankly, the distractions of an unfolded map on the steering wheel and trying to find where you are is far worse than the map display the little turning directions screen in the speedometer display, and that woman who talks to you (I'd like a date if I weren't married) - an example of a dashboard distraction that actually can improve safety and attention to the road.
It's easy to knock the W/S switch for the transmission into the position you did not select. I've already done this, and the car's performance sure changed when the switch is in the right position. Particularly if you've owned the car for only a season or two, you haven't "trained" the adaptive transmission to your driving habits, and this may account for some weird shifting patterns that have elicited comments on this message board.
By the way, have you noticed the talent that the Germans seem to have to make real wood look like plastic?? That IS real wood in the interior!
Someone commented that the MPG computer is very good on fuel mileage but the Avg. Speed reads too low. In this case, it appears that “time” MB uses in the D=RT computation is the time that the ignition is on until it is shut off. Sit in your driveway after a short trip and watch the average speed drop if the car isn’t moving. Also the fuel mileage!
There has been some speculation (and concern about dealer reticence) about when the redesigned E-Class will come. My understanding is Model Year 2002. But, you can see pictures of the redesigned E-class and a list of its features on the web right now! Today! The place to go for these juicy tidbits is the MB Enthusiast’s Pages, which, I think, originates in England. There they have numerous spy photos and translations of German Car Magazine atricles, etc. The place to start is - -
http://www.geocities.com/MotorCity/Downs/9323/index2.html
All of what is here is mostly focused on the European versions of the car. The E-Class, for example, is actually sold in three trim levels in the old world, and there is no exact correspondence to the U.S. model. Also, E-Class in Europe is typically sold with much smaller engines. An E200 is popular there. There are a number of other MB models described on these pages that aren’t sold in the U.S.
What would I want to see in a new U.S. E-Class? Well, first of all, it needs a ski-bag in the rear armrest like an Audi. Since this is the best “go skiing” car I can imagine, it’s annoying to be unable to carry my expensive skis inside the car. Second, I can’t understand why a $60,000 car doesn’t have passenger footwell lights! My Taurus SHO had ‘em! The lenses are there, MB certainly knows how to implement this but they leave the feature out in USA-destined cars! Third, ship the car here with the same RV mirrors that come with the car in Germany. The U.S. variants of RV mirrors are too small and offer insufficent coverage. I’d like to see an instantaneous MPG display. I’d also like to see which gear the tranny has selected when I’m in Drive and not using the “touch select” transmission feature. Some of the other ideas are already shipping in the 2001 model, e.g. one-touch moonroof.
This is an expensive car, but I actually think it is worth it.
Jean
Jean
No charge for Flex Service A since it's part of the Free Scheduled Maintenance feature. No, they did not replace my wiper blade; I forgot to mention it, though. They give you a long stem rose, though, when you pick up your car.
BTW, they provide loaners--anything from a C-Class to a Chevy Blazer.
Bill - This is a response to your question regarding a tiny hole at the bottom of the star on your trunk lid is a littly late for which I apologize. I have an '01 E320 and I can not find any hole of any size where you described.
Im looking for A low miles E430, like under 20k miles. 99 or 2000 model year. I understand alot of changes for 2000 took place, but are they significant. If any body has any thoughts to share I would enjoy reading them.
Drove a 99 with squeeky steering column on dealer lot, car had 20,000 miles.
Skat-mat for the cat. They make a mat that you put on the hood of your car that emits low voltage when kitty snuggles with your masterpiece.
Perhaps a SPlat-mat may be more in order. Be happy kitty does not like to sleep on the engine block. We have all heard those stories.
I believe o-60 in like 6.1 seconds should be enough run miss kitty down. IF you had a diesel, you could not do this.
Bargamon
http://www.mercedes-benz.com/e/cars/e-class/default.htm
Hope this helps!
Drew/aling
Townhall Community Leader/Vans Conference
P.S. How about stopping by the M-class topic and letting everyone know how your vehicle has been holding up?
I drove some 430's and loved it. Not having the dilema to go 320 or 430 as we did with ML because I think the CAR with the big engine is better than the TRUCK with a big one. In that, the ml320 does just fine with 320, but the 430 in the car becomes a real rush funmobile. Its gonna be hard to finda a 2000 used. I have a person charging auction price plus 1k to shop it. I went to starmark lot and could not believe what they are asking. I think a car with 5-10k on miliage should be ok with out starmark. Besides some exterior ground effects and steering weel controls, what are the major tweeks of a 2000 model year over the 99?
Any considerations I should be looking for??
I read back over the last few months on this site. a little different than ml chat. I'll head over now.
If it really bothers you, simply mention this (or better yet show it) to your service advisor the next time you're at the dealership and he/she should be able to take care of it for you.
Personally, I've used it only maybe once or twice during the winter. I enjoy punching the gas and feeling all four wheels hook up and spin (although 4ETS will control this) while leaving the FWD/RWD vehicles way behind :-)
Drew/aling
I have a '00 E320, same color and options, and I love the car. Just after delivery, I had Zaino on hand -- Z-1 Polish Lok, Z-2 Show Car Polish (the car has clear coat), Z-6 Gloss Enhancer, and Z-7 Show Car Wash Concentrate. I later added Z-16 Tire Gloss.
I'd recommend all these products. I did NOT use the Z-18 ClayBar, since the car was new and the dealer had detailed it.
First, I washed it with blue Dawn to remove all the dealer's wax. Then, Z-1 and Z-2, let dry thoroughly, and then Z-6. I use lots of Z-6 instead of a wash when the car is very clean, but first use a California Duster or 100% cotton towel LIGHTLY to remove any dust, then use Z-6 after washing the brake dust off the wheels. Final application is Z-16 on the tires.
You'll find that subsequent washes and applications of Z-2 are easy and fast. The Z-2 is merely wiped on, allowed to dry, then wiped off. No buffing or rubbing! On the light colored brilliant silver finish, I find that Z-6 after Z-2 is an overkill. The Z-2 provides a superb shine and the "wet look."
I haven't tried the Zaino leather products (Z-9 and Z-10) -- I agree with Drew (ailing) and use Lexol for cleaning and treating the leather. Works great.
Hopes this helps. Try going to Town Hall Topic #1319 under "Maintenance" for more info about Zaino. Also, strongly recommend that you visit the Zaino web site and read their "tips." The URL: www.zainobros.com
Thanks for your replies.
Dawn is just what Sal Zaino recommends because of it's high alkaline content it strips off wax and dirt really well without hurting the paint. Check out thier web site for more info: http://www.zainobros.com/ The whole story is there, Dawn, cotten towels, etc. The web site has all this info you need when starting with a car with excellent paint. I think they tend not to cover what to do with an old car very well, and I think you really need to think about a good polish/glaze like those made by Meguier first in this case.
I was a Meguier's user before I switched to Zaino. The Gold Class Clear Coat Car Wax is a great product, but I've come to prefer Zaino. I think it is more durable and has slightly better depth (at least after several coats).
Second, I find the driver's seat uncomfortable. it presses hard against my lower spine and, so far, I haven't found any aftermarket product that really helps.
Any suggestions?
Do you have the lumbar in the seats adjusted? Tried different pitches with the seat bottom and back?
YOur happiness with your avalon, er I mean es300 is irrelevent to his question, other than to agitate him and others at the expense of your attempt to elevate your self esteem at the price of others.
Yes, after 3 MBZs in a row, we opted for a Lexus this time. I love MBZs. My wife still drives one. Probably will have another somewhere in the future. But evey car has advantages and disadvantages, even MBZ.
If the current E is as quiet as you say, then dkatlanta must really be sensitivie to interior noise.
How did you manage that? We had the two MBZs but were starting to spend too much on maintanence so one of the cars needed to get swapped for a lower overall cost auto. So guess whos car got fingered? Oh well, if the wife is happy, chances are good, I'm happy too.
I agree completely with billc01776 regarding Zaino application. The blue Dawn should be used only initially to remove any wax and prepare the paint surface for the Z-1 and Z-2. After applying Zaino, don't use a dishwashing liquid (high in alkaline) to wash the car. Z-7 is chemically compatible with all other Zaino products and is probably a good choice to use for the wash.
I disagree with sddlw's advice to clay first or use a clear coat cleaner, polish or glaze. IMHO, it would be a waste of time and effort on your light colored car. (However, for a black or dark color, that advice might be valid.) I didn't do anything last April to my new brilliant silver E320 to prepare it for Zaino except wash it with blue Dawn. But I didn't lolligag after taking delivery. Since the dealer had just detailed the car, it was free of wax and whistle clean after the Dawn wash and ready for the Z-1 and Z-2.
Since then, I've applied 7 or 8 coats of Z-2, and last week I did the Z-1 and Z-2 repeat as recommended every six months or so by Sal Zaino. I use lots of Z-6 between Z-7 washes.
The results are fantastic. My MB is dazzling!! The brilliant silver finish is slick as can be -- even the dealer's service advisor asked me what I use to get the wet-look shine! And rain actually seems to help the finish; the water just slides off. I leave the wet car in the garage overnight, and the next morning it almost looks like it was washed! No water spots and almost no dirt or dust on the finish. BTW, I had mud guards installed, amd it really helps to keep the lower panels clean.
Let us know what you decide and the results.
However, just getting a high quality product on your car, let alone 7 or so coats of zaino will really make the difference. I've got 7 coats on my wifes' car, but only 3 on mine, as I am still finding the time to work on it. I think the whole process starts to max out somewhere between 5-7 coats. But even the first coat makes you stand back and say wow! And then your scratching your head wondering what it's gonna look like when you've done a few more. ..... well it looks like you poured liquid glass all over the car.
If you read all of Sal Zaino's product notes you'll come across some interesting stuff. The one that just amazes me is the effect of the direction you wipe as you apply, remove, and buff the finish. It really does make a slight difference in the depth of the shine. .......ok, so I'm a little obsessive/compulsive. The cars look great.
completely, absolutely no idle. It is a weird feeling. Is this normal? Second, I called the
800 Mercedes # two weeks ago, and requested an accessory catalog, and have not received it yet. I called my salesperson a week ago, and requested one, and still not received it. All I want is to order winter mats. Is there any other way to do this? Any help appreciated.
As for the mats, visit www.clairparts.com for discounted Internet pricing on all MB accessories. If they don't have it online, e-mail or phone them and they should be able to give you more info. FYI, Clair Motors is a MB dealership in Boston.
Drew/aling
As for your question, the transmission is smart enough to know when engine braking is needed, and it won't upshift like other cars (it will hold a lower gear). Also, the AWD does add a little extra resistance to the driveline, hence probably causing it to slow down quicker than your previous vehicle (which I assume is 2WD) rather than free-wheeling. This completely normal, and perhaps just something to get used to.
FYI, the transmission is clever enough to know when to shift into another gear. You may have noticed that after shifting out of reverse and into drive, hitting the accelerator pedal doesn't necessarily move the car immediately. There is a 1/2 second delay because the tranmission makes sure that "Drive" is engaged properly before allowing you to accelerate. You can actually test this out by placing the car into Neutral and revving the engine to perhaps 2000 rpm. At 2000 rpm, lift off the gas completely and shift into Drive before the revs drop significant. You'll notice that D will not engage until the revs have dropped down to a safe level. Pretty nifty, and useful for keeping the transmission happy over the long term!
Enjoy the ride!
Drew/aling
http://www.thecollection.mbusa.com/Accessories/catalog/Category.jhtml?CATID=420
If you go through the Zaino forum, you will see that most people feel it gives the best protection they have every experienced. Love bugs and tar come right off, water beads like crazy after 6 months or more. Nothing seems to stick to it! Some posters have used it for 2 years or more and will never switch.
Clay -
Even a brand new car with great paint will benefit from claying prior to the Zaino. You can't imagine how smooth the paint can be until you clay it. Then, the wiping on and off of the Zaino goes even easier and faster!!
Jean
