Jeep Owners: Accessories & Modifications
Hey all
Anyone have safari doors? I want to know if they have a place to put the rear-view mirror, or if I'll need mirror movers also.
Mike
Mike
1
the Mopar tubular bumpers? I am interested
in the aluminum versions and the only place
I have found them is the Mopar Jeep Accessories
catalog. -tjray
So i chose the warn rock crawler bumper. like the way it looks and it already came with attachment points for rings, hooks, and lights. Now i just gotta figure out a way to get my insurance to pay for a lift.
Bob
Bookitty
Splice the ignition wire at the starter with a HEAVY DUTY toggle switch and fairly heavy gauge wire leads. This will cut off the power source to the starter. If you have a console mount the toggle switch in there. Remeber to paint the switch black so it doesn't stand out.
If you have an electric fuel pump you can do the same to that. Just remember to splice the power feed and not the fuel gauge wire.
You can also buy the stuff to conceal the wires under the Jeep. Its that plastic tubing that the factory uses to protect the wire harnesses. Tape the ends well so that the wire doesn't show. This makes the job look professional in case the crook has time to look for the reason why "his/her brand-new Jeep" won't start!
http://www.quadratec.com
Bookitty
Jayorion
Oops... from the date of your post, I'm sure you've found this out by now! ;0)
-ajjjjjjjjjjj
It is too much work to try to find a safe mounting location for anything larger.
I'm considering swapping out my 6 disc CD changer in my 2002 Jeep Liberty Limited in favor of a Sony 10 disc DVD changer. And then, installing monitors in the back of the seats for viewing. It looks like it has the same overall dimensions as the one in there now. Has anyone out there done anything like this to their Jeep(Liberty)? Do I need to change the stereo as well or, can the OEM stereo handle the feed from the DVD player?
Bookitty
Am planning on trying Yakima Drydock unit in rear trailer hitch.
Any suggestions on where I might find Front rack only?????
gdh.
You'll see the fuse box behind it. The bottom row, farthest right fuse is what you want. Pull it carefully with needle-nose pliers. You can tape it inside the glove box or put it somewhere you'll remember. Pop it back in when you put doors and top on for the winter or whatever...
oman4x4.com
I initially thought that maybe Jeep dealers have a higher mark up on their parts than Chrysler so I called two other Jeep dealers in the Twin Cities area. They both quoted the same price as Suburban Chrysler! So evidently dealer prices aren't high enough - Stillwater Motors even doubles that! Needless to say I am trying to spread the word. Watch out for price gouging out there!
Bookitty
First, yes, you will have to do both differentials. You won't find a reputable transmission or ring and pinion shop that will only do one. The chances of a catastrophic failure are simply too great not to do them.
Second, make sure to go to a reputable shop. Changing out the ring and pinion is one of the jobs in a driveline that's very subject to experience. Getting things just a little wrong will result in plenty of noise and premature failure.
Here's a great link that talks about doing EXACTLY what you want to do. I agree with this page at 4.88's to be about right. link 4w4c gearing article
Also, realize that your speedometer is now off, and your braking distances are going to increase. This is more a function of the new weight of the wheels and tires over the stockers than anything else. Rotating mass and all. Be nice to the terrified Kia's and Scion's in front of you and brake early :P
Keep your speeds down until you're sure the lift kit is operating correctly as items like the track bar can cause "death wobble" if they're loose or worn, especially in lifted vehicles. This will cause a loss of steering to the point of a bad rollover on pavement. Your YJ handles completely new now, so you'll need to get used to it all over again.
Lastly, you didn't mention if you have new wheels. You probably do, as the stock offset should not allow clearance while running a 33/12.5. Since the offset is now greater, you might check on some flares, as people are actually getting tickets for tires outside the body (I know, I know, but it's a real law in some states. Seriously).
I've been through three different jeeps (YJ, XJ, and TJ), so I've sort of done this before. Hit the "Wrangler" message board for more technical questions, as many of the members are total Jeep-geeks and can argue points like the above for days, all while providing great advice or even pics if you need 'em.
