oldsmobile cutlass ciera timing chain
dan1975
Member Posts: 5
I have a 1989 Olds cutlass ciera with 96000 miles on it. It has the 2.5 L, 4-cylinder engine. My brother keeps telling me that I should get the timing chain replaced because he believes it will break soon based on the car's age. I'd like to find out what experiences other Olds owners have had with their timing chains, and at what milage it broke at, if at all.
Your engine is an overhead valve engine. We've had 3 GM vehicles with that identical engine. They do NOT have to have their chain replaced at 96,000 miles and you'll find no recommendation to do so anywhere in your owner's manual.
The engine stalls when I either slow down or stop at red lights. Curiously, it does not hesitate or sputter before stalling. I replaced the starter and alternator so I have ruled these out as problems. My question is, how does the brakes affect the transmission?
The transmission did not shift properly (it would remain in a low gear for a long time) but after my novice mechanic changed the transmission fluid the transmission started working the way it should.
Should I replace the transmission? (I like the car otherwise) or give it to one of those charities and get get a $1,500 tax writeoff?
Doesn't let the lockup in the trans disengage, so you're not shifted down into a lower gear.
My 84 Citation,got the trans changed when all it was doing was exactly what I've described above. You can also disconnect it as my folks did with the 86 Calais I gave them.It was doing the same thing. Costs a little in mileage, but seems to give it more "pep".No more problem. It's located somewhere on the outside. Would have cost about 500 for a new one at the dealer for the olds, but it really depends on where it's located.It works as a sort of electronically guided semi over drive. It kicks in when you are going at steady speeds and kicks out when you accelerate. Hope this helps.But it's not your brakes.
The cam gear is a fibre gear with a steel hub, that is pressed onto the cam.
Usually the cam gear comes apart around 100-120K miles. It is a major bear to replace.
If it is attempted to replace the cam gear without pulling the cam (usually have to pull the engine), most times when the new cam gear is driven on, it pushes the rear cam cap gasket and causes a leak. Not good.
bwia, your problem is the Torque Converter Control (TCC) solenoid.
125C solenoid with converter $64.95
3 quarts transmission fluid 9.00
2 hours labor.............. 120.00
I got estimates as high as $1,500 from AMMO, but the most common estimate was $500.
According to Batco and some Internet sites, this is a very common problem with GM automatic transmission engines, but once the TCC solenoid converter is replaced the car should run just fine.
Thanks guys all for your help. Now I have a dependable second car that I can use for dirty and unpleasant tasks.
Phillip
Thanks for the info anyways.
