Computer tells when oil change is due???
I have a 2002 chevy vevture. In the owners manual it says a computer will light up a change oil light when the oil needs changing after a certain amount of engine revolutions and heat ect.. have gone through the engine.
Should I go with the computer advice or change the oil at every 3000 miles as I have for 30 years??
With todays better alloys and more refined motor oils, it's probably not a big issue as far as engine life is concerned.
a.) Peace of mind. If it really makes you nervous, change it. It won't harm anything, but the environment.
b.) Time. If you have vehicles that aren't driven a whole lot, you might have to change it in certain time intervals. Most manufacturers seems to recommend 6 months to one year.
c.) Other environmental influences exist, that the service indicator doesn't pick up. Let's say, you live in a high dust area and are worried about oil contamination. Or your area experiences drastic temperature changes, so that condensation might be a concern.
d.) You just want to inspect your car in shorter intervals than the indicated service. Personally, it has worked well for me to inspect boots, seals and hoses for cracks and leaks. And the oil change is simply the best 'excuse' to get under your vehicle.
Can anybody think of something else ?
Will change again around 16,500 total or about 12,000 on the oil. The first change at 4400 was removing the OEM.
Despite that light we will change it every 3,000 miles or six months, though, as she seldom drives it. The oil that came out of it was clean, but not knowing how long it had been in it I changed it anyway.
