Thanks for the response. Mine is a 2005 S and as long as I don't touch the recirculate
button, A/C button works fine. If the recirculate button is turned on for any reason either by me or by pushing the MAX A/C, the A/C compressor comes on as if the A/C button was pushed and it stays on till the engine is shut down. For example, I can start the A/C by only pushing the recirculate button although the A/C button is off. Since you can start A/C by pushing the recirculate button, why do you need to have an A/C button? I hope they don't claim that is a design feature built into the A/C system. I hope to post the response I get from the Nissan Service tomorrow.
Taken from the owners manual.
Defrosting or defogging.
When the "Windshield Only symbol" is selected. The air conditioning automatically turns on (However the indicator light will not illuminate) if the outside temperature is more than 36 degrees. The air conditioning system will continue to operate until the vehicle is restarted, even if the the air flow control dial is turned to a position other than the "Windshield" position.
Heating and defogging.
When the "Windshield and Floor symbol" is selected. The air conditioning automatically turns on (However the indicator light will not illuminate) if the outside temperature is more than 36 degrees. The air conditioning system will continue to operate until the vehicle is restarted, even if the the air flow control dial is turned to a position other than the "Windshield and Floor" position.
Dehumidified defogging.
When the "Windshield Only symbol or the Windshield and Floor symbol", or positions in between are selected, the air conditioning automatically turns on (However the indicator light will not illuminate) if the outside temperature is more than 36 degrees. The air conditioning system will continue to operate until the vehicle is restarted, even if the the air flow control dial is turned to a position other than the "Windshield" position.
Someone please help me understand in a simple reply, don't need all the details, just the necessary facts about what's wrong and what y'all think about the way it should work.
Thanks all. On our '01 Alty, the a/c system was so simple and it always worked. Even our new 3 a/c works like it should.
The Sandman
Unless you go outside in the morning. Start your car and turn the defroster on to de -fog/ice your windshield. And then when your ready to leave. Restart your car with the defroster setting off and drive. But remember. If during that drive you need to use your defroster again. The AC will be on until you shut your car off.
Now I commute on the NYS Thruway 50 miles each way to work. So if I have to use my defroster during that commute. I end up running the AC thus decreasing my gas mileage.
It's a very poor design. And to me. Yes, worth the 2 or 3 grand loss.
If you live near Albany, New York. I have a heck of a deal sitting in my garage for you. $17500. takes it.
D
Checked the fuses - and they are good. I don't really think it's the motor cause it still run on 4 - but I could be wrong.
Any suggestions?
I plan on replacing it myself but would like to know of other alternatives or solutions before shelling out $80 bucks on the new motor.
D
To deactivate automatic a/c feature on 2003 Element:
1) Turn vehicle off.
2) Turn fan knob off.
3) Turn temperature knob all the way to the left (blue area).
4) Turn vent knob to panel only setting (next to max a/c).
5) Hold down both air recirculation button and a/c button while turning the key to the "run" position (one short of starting).
6) Continue holding for 7 seconds until air recirculation button stops flashing.
7) Anytime you engage the defrost or defrost/heat positions, the A/C will automatically turn on. Press the A/C button to turn the A/C compressor OFF, the light will go out.
NOTE: If the climate control computer is disconnected from battery power, it will likely revert to factory settings.
To reactivate automatic a/c feature on 2003 Element:
4) Turn vent knob all the way to the right (defrost position).
7) After the 7 seconds described in step 6, the recirculation button will start to flash. Continue to hold the button for another 7 seconds. After this, the a/c light will turn to green and it's finished!
very far off and basically all the tires are severely worn so that it is not safe to drive
the car. I was told that the reason for all that was a bent wheel. I independently have it
checked and it was confirmed that the wheel was really bent. Can a single bent wheel
cause such a severe alignment that I loose all my tires in only 13,000 miles or they are
using that as an excuse?
Any feedback is appreciated. Thanks.
ewe2 is correct, your blower motor resistor has blown. It is used to control fan speeds 1, 2, and 3. Speed 4 is the maximum blower motor speed, so no resistors are involved.
Replacing the resistor assembly is a very easy task. I'm not sure where it is located exactly in a 94 Altima, but in my 97 Maxima it was located just above the passengers feet. All I had to do was unplug the wire harness and remove 2 philips screws and swap out the resistor for the new one.
It takes less then 5 minutes and the new resistor is only about 30 dollars, which is much less expensive then replacing the entire blower.
New plugs & wires?
New O2 sensor?
BTW, I have almost 60K miles so far.
This little MAF does get dirty, but that doesn't mean you have to replace it. Many of them get replaced unnecessarily. When they get dirty, they "fool" themselves, and then the engine's computer, about the amount of air coming into the engine. The wrong amount of fuel is put thru the injectors, so poor performance and bad mileage are the results.
If you do a search on Google, for "Clean MAF" you'll find several sites telling you how to clean it for less than $10, and less than 20 minutes. That's what I did, and my engine runs better, and gets better mileage.
Just my 2 cents.
Front tires wore out quickly and strangely even though they were always balanced properly with pressure monitored all of the time. biggest issue was random stalling, sometimes the car would die at 60 on the hwy. problems was oil in the distributor, which I fixed by spraying carbeurator cleaner into its every nook and cranny, that was six months ago, now the almost new battery just dies from some random electrical problem. what worries me is that when I put the battery charger on the battery the needle pegs, then the charger shuits down and recycles on then shuts down again then comes back on and eventually the battery charges and seems to work fine for days and weeks. Don't know if the battery is failing or if the electrical system is doing something strange. Also had to replace ALL motor mounts at about 75k. hope this helps some.
Check tire pressure, air filter first, new plugs and wires might help, dunno about 02 sensor, if it's DIY you can try but don't spend too much $$ on that, I think it'll trigger the check engine light if it's bad. Good luck
I'm a new owner of a 1994 Nissa Altima GXE, bought it 2 months ago with only 26,500 miles on it. Practically NEW!! It seemed fine, but after running on these rough back roads, I have noticed noisy rattles , actually sounds like something is ready to fall apart in the front end, of my car. It is not audible on very smooth roads, nor can you elicit the sound by pushing on the car. It seems to definitely be getting louder, looser sounding and more "> and I can now also feel it in my gas pedal. My mechanic put it up on a lift too, can find nothing. He suspects that it may be the strut mounts but has not had a lot of experience with Nissans and hates to put me to the expense because he really isn't sure. HELP!! Has anyone had any similar problems? I am starting to be afraid to run the darn thing. Addie<img src="
loose and the front end rattled. Check the front struts for oil leaks on the strut shafts under the boots. I've replaced the struts twice for oil leaks. The original struts were made by Monroe-within 30k all four struts had to be replaced. First I would check the struts for oil leaks. Just lift the boots up and look for oil. Then check the torque on the saddle bolts-three big bolts on both side of the front suspension 110 ft/lbs torque each bolt.
I just bought a 2002 Altima 3.5 V6 and when I drive over a bumpy or gravel road, I get a slight "popping" sound coming from the front right of the vehicle. Does anybody know what this might be before I take it to Nissan and get ripped off?
Also, THE RADIO STATIC IS UNBEARABLE. I strongly suggest filing compliants to Nissan as others have suggested.
Johnnie
Hope this helps.
I bought my car July 21, and have been dreading it ever since. Your story reads exactly like mine. Nissan won't acknowledge the problem.
Any insight would be appreciated
I have a 95 Nissan Altima GXE and it had starting problem too, and it turned out that the distributor was bad. You can see the following message (in this board) that I posted some time back:
561 of 1193 95 Nissan Altima GXE/Auto Engine Problem by msahmed United States of America Sep 04, 2003
- Blower not working on low settings. Only work on the Highest setting.
- Read from other articles with the same problem suggested that the blower
motor resistor is not working.
- I got the resistor removed and check the connectivity (as suggested by the
Hayne book) between all the leads and seems OK.
My question:
1. How to check if the resistor is broken?
2. What should be the reading from the Ohm meter?
A 3 year old car with 29K miles should not have this kind of mechanical problem. Like I said, Nissan has a huge realiability problem, along with service department people avoiding huge repairs on vehicles that actually do need repairs. We are worried that the problem could go back so we're trading it in for a 2005 Honda Accord once the car has been fixed. I have a 1997 Honda Civic with 156K+ miles on it and it still runs fine, no mechanical problems whatsoever--that's realiability. Our huge lesson here, never ever buy a Nissan. And since Infiniti is Nissan's luxury line, you have to think twice about getting an Infiniti as well. :lemon:
Sam
