link title
I am not sure what to think myself. There are regular contributors to this board who have 100K+ on their rattlevans with no issues from the noise.
As for me, my van is used mostly for suburban/city driving where it is exposed to a lot warm-up cycles when the rattle occurs therefore ultimately I do not anticipate to reach a respectable mileage with this van.
Yes there is class action being pursued against GM but I do not know the status of it. GM is not the only manufacturer that has had to deal with this issue, Ford, Subaru, Nissan are some others that I am aware of.
At this time I would concur with Dirk's early posting of this being a manufacturing tolerance issue. Appears it is either the block or the pistons are not fitted quite correctly.
alien
This week I was told by GM that my van is being recalled for the inside door handle on the power sliding door. I had advised GM Canada that there was a recall on this back in February and was told that the door was fine and only Ventures and Montanas were affected by the recall. NOW they decide to add it!! Could it be because it almost tore my 3 year old daughter's arm off????
My next step is to sell the van and buy Japanese...... Reliability aside, I think safety should be their first concern. GM is losing yet another customer here. :lemon:
Long time reader, first time... blah blah blah...;-)
I've read here a lot of post that help me understand my 2000 SWB basic Montana (75 000 miles) Saved a lot of money ... But now, I never read anything on that one...
When I turn right, and only right, when the driving wheel (! sorry if that is not the correct term, i'm french...) turns 180°, I hear a big TOC coming from the direction under the car. Took it to my trusted mechanic, he heard it while test driving the van, put it on the lift and couldn't see where it was coming from or what it was. Changed both wheel bearing a year ago (400.00 $Can. Deal...) but the TOC started about 3-4 month ago. Had the wheels "aligned" 1 month ago....
This happens no matter what speed between 1 and 50 km/h...
Weird Hey!?! what do you think...
Simon
1. One of the strut bearings has started to fail. This is a "bearing" at the top of each spring that allows the spring assembly to turn. They are permanently lubricated and generally don't fail. If the noise is present when the van is not moving, you may hear or feel it by opening the hood and turning the steering wheel.
2. The rack and pinion unit is loose. It might be hard for your mechanic to detect but he/she could try tightening the bolts that hold it to the frame.
Dirk
Simon
I was driving my 2002 Venture to work today, and noticed that the vehicle would accelerate gradually without my putting my foot on the gas. Once the van got up to speed after a red light, I had to ride the brakes to keep it there. Then, over the last few blocks, the needle measuring engine temperature started climbing. It was get close to the red (though not there yet) when I pulled into my parking spot.
The van was also diagnosed last month with a cracked air-conditioner condensor, which seems a little early for a vehicle with just over 80,000 kilometres.
If anybody can give me any answers, I'd appreciate it.
Right side turn signal doesn't flash. It stays on solid. Left side flashers work fine. I've replaced all bulbs and the flasher unit under the dash but still doesn't work.
Of possible interest is that when I click the emergency brake down two notches and turn the key to ON position all exterior lights should stay off. However, the right side marker light (the one facing forward, not the smaller side panel light) is on. This bulb is a dual filament type and from what I can tell the daytime running light filament portion is on continuously any time the key is in the ON position. It also appears brighter than the left side daytime running light.
When I hit the right turn signal the second filament lights up as normal but doesn't flash.
Thanks for any help.
What you describe may be normal. On my 98 if the headlamps are on, the turn signal lamps alternate between the front (DRL) and side markers. If the headlamps are off, both are in sync and the DRL filament that flashes is brighter.
Don't know if it will help but I put some grease on all the bulb contacts.
Here's an interesting article on all types of coolant.
Since my 02 Montana is off warranty with about 115000 km, I'm thinking of changing to a G-05 (2-EHA free) coolant.
http://www.findarticles.com/p/articles/mi_qa3828/is_200408/ai_n9453107
the dome light will turn on an off on its own when driving or parked on a humid day. I check all the door actuators and I can't pinpoint the problem. I'm thinking it might be the wiring elsewere in the van.
So far all I can do is dissable the dome light with the console switch.
any help would be appreciated.
Cheers!
Eric
We also have the rear heat which works fine.
It is a 2002 Montana EXT.
Dave
Fun hey?!?
Simon
I have the same problem with our 2002 Montana. Did you ever find a solution?
Dave
list of problems ive had in just 1 year.
1) float in the tank (gas gauge was always reading full)
2) wouldnt start fuel not getting to engine(little wire harness underneath van loose.
3) Upper intake manifold ( very common problem for 3.4 liter)
4) Switch for power windows
5) blower motor resistor( 1 to 4 Blower speed does not work)
6) Rain water leaks in from overhead lights
7) Wheel bearing gone passenger side
8) exhaust manifold leaking
The van had only 106,000 kilometers(65,000 miles when i bought it 1 year ago.
I now have 131,000 km(77,000 Miles)
I have spent over 2500 dollars fixing problems on this vehicule. Thats at $ 50.00 per hour. :lemon:
I turned the key to the ON position in order to light up the headlights and side markers. I then pulled the main fuse for the DRL, headlights, etc. All of the headlights and side markers went blank as expected. I then reinserted the fuse and everything came back on again as expected. I then tried the right turn signal and it works perfectly now.
I can only guess that something in the DRL controller was screwed up and removing power to it reset things properly. It has been working just fine for over a week now so it seems a "permanent" fix.
Is it easy to take out and install? IE: Is the LS prewired for the control unit??
Thanks in advance, (and a tip o' 'da hat)
Right now it sits in the driveway with the power center disassembled so I can check connections. I read somewhere about a loose wiring connection down by the fuel pump, so I will check that. Also, I will check just about any other wiring connection I can see. If you find out more I would appreciate you posting it. Each time this happens I feel more and more like the Montana is a :lemon:
Steven
1) Remove key from ignition.
2) Remove "BCM PRGRM" fuse from panel by passenger door - use the legend in owner's manual - NOT the "BCM" fuse but the "BCM PRGRM" fuse.
3) Close all van doors and liftgate.
4) Insert key in ignition and turn to ACC (one click TOWARDS you, opposite of start).
5) Quickly turn to OFF then to ACC within 1 second - fast as you can!
6) OPen and close any vehicle door. A chime will be heard indicating in program mode.
7) Press and hold remote LOCK and UNLOCK at the same time for 14 seconds. Chime will be heard when programmed. This CLEARS any old remotes so you have to repeat this step (7) for ALL remotes you want to be coded.
8) Remove ignition key.
9) Return fuse.
You are programmed!!!!!!!
The dealer sees no connection between their work and the Check Engine Light that lights up the very next day (it was never on before).
So I ask, is there a connection between the two?
I realize that it is hard to trust the dealer when I make the comment that the Intake Manifold Gasket seems to be the biggest problem with the 3.4 GM engines. His reply was: "I haven't noticed that".
KC
The only possible help I see in my Haynes manual is in the chassis electrical system diagrams that mention that each motor for power doors or lift gates contains an (ECB) or electronic circuit breaker. However nowhere does it tell me where this blinking motor should be or how to get to it so I can check the ECB
The Haynes manual also mentions a solid-state control module but once again no information on where it might be located or how to trouble shoot it.
The only thing I can add that might help here is that if you leave the door open and place the mini-van in gear the warning buzzer still buzzes.
I have scoured the forums and not found any help for this problem. If someone could help me out I would really appreciate it.
Gary
"TO REINITIALIZE THE PSD:
1. TURN THE IGNITION SWITCH TO THE "OFF" POSITION.
2. POWER DOOR ON/OFF SWITCH IS IN THE "OFF" POSITION, LOCATED AT OVERHEAD (O/H) CONSOLE.
3. MAKE SURE THE SLIDING DOOR IS IN THE FULLY CLOSED, LATCHED AND LOCKED POSITION.
4. REMOVE THE TAIL FUSE FROM THE FUSE BLOCK.
5. KEEP THE TAIL FUSE OUT FOR 30 SECONDS.
6. REINSTALL THE TAIL FUSE.
7. WAIT 10 SECONDS.
8. POWER DOOR ON/OFF SWITCH IN THE "ON" POSITION.
9. CYCLE THE PSD FULLY OPEN UNTIL DOOR STOPS, USING EITHER POWER DOOR SWITCH ON THE "B" PILLAR OR O/H CONSOLE.
10. WAIT 5 SECONDS AND CYCLE THE PSD FULLY CLOSED.
11. WAIT 5 SECONDS AND REPEAT STEPS 9 AND 10.
12. IF DOOR DOESN'T REST IN FULLY OPEN POSITION, REPEAT STEPS 9 AND 10 ONCE AGAIN.
13. CHECK POWER SLIDING DOOR FOR PROPER OPERATION."
Thanks for posting - I was about to break down and take it to the pirates..
You did it my power door is working fine. Your directions were 100% on the mark.
Thanks a billion.
Happen to know anything about the a/c systems? Mine is currently not working. 1st the door then the a/c and the power window motor on the driver’s side. Guess that is what you get for owning an 11 yo van with 150,000.
Thanks again
Gary
Our 98 Montana just rolled over 118K yesterday and still runs well. Got a few small rattles but hasn't given me a reason to trade it in!
What's your a/c doing or not doing? Does the blower run but no cold air? .. good thing you don't live in the Phoenix area and no a/c. We've been getting triple digits highs !.
Have a set of gages but not sure what the proper psi is.
Thank god it is r134a which is still easy and cheap to get if the gas is low.
I am leaning toward a electrical problem as when you hit the ac switch and nothing happens ( no clutch noise and no clod air) when you push it again the ac does not shut off (the light stays lit).
Gary
When you push the ac switch the second time and the ac does not shut off, is the compressor operating and the system blowing cold air?.. or is just the light staying on?
Gary
:confuse:
