How difficult is it to change CV joints?
Have any of you ever replaced the CV joints on a Toyota Tercel? I've been told that the entire axle assembly can be purchased (with new CV joints already installed), and this was by far the easiest way to replace them. Is this true? How tough is it to remove the old axle assembly, and install the new one?
It may get a little messy however you'll probably in long run feel you happy you performed the work
are those split CV joints that you see in places like AutoZone worth anything? My guess would be that it would be next to impossible to fill these things with grease and slap them on an axle without getting the whole dealybop completely filthy.
If anyone has ever made these things work, I'd be interested. Obviously doing the job right is a lot more money. I'm thinking about this primarily in old beaters that you want to get a few extra miles out of. Fifteen bucks for the kit and you can get an extra 20K , and then replace the axles if you still hold onto the car.
Depends on the type. I've had the ones with the little screws that hold the seam together. They are junk. Had to replace several of them. They are semi rigid (to make the screws work) and end up cracking. Then I used the type where you glue the seam together. They are better.
But use them on the beaters. They save a lot of work.
On Ford, GM, VW, or Chrysler, it only takes seconds with a mallet and punch, or a snap ring pliers (depending on type of retainer) to remove the joint. The western Pacific variety require enough force to destroy the ring, it seems to be because the groove in the star lets the ring expand more. As stated earlier Warranties on re-conditioned axels are better too.
Harry
(My experiences on this are ONLY Japanese cars)
I just had my axles replaced but about three weeks later when I tried to accelerate I got a continuous clicking/popping noise and the car would accelerate slowly but the front would shake violently. I took it in and was told that the right front intermediate shaft was broken and the right front axle had come out of position. Also the engine mount was broken. I don't understand what happened. Why would the axles cause the engine mount to break any help would be appreciated. Thanks.
Harry
I'm an Engineer by ocupation and it bothers me that when I talk to mechanics I can't be intellegent about it. Maybe I should take an auto mechanic course somewhere. I guess that is what this board is for to learn and grow.
Co-incedences also happen. Someone once left a car at my shop, and I did not know what it was there for, so I never touched it. In the afternoon this guy stops by, and explains that his daughter left the car at the wrong shop. Then he wanted to blame me that it wouldn't start. Turned out she left it in "Drive", I went out, looked, put it in "Park" and it started right away. (he was supposed to get a brake job somewhere else. :<)
Harry
HINT: Replace both tranny seals while you are at it and use the OEM seals. Got the first one from AUTOZONE and it wasn't any good. I had to get one from MAZDA and ..........it worked.
That means I took out the shafts 3 freaking times.
Have Fun!
Leo
Maybe for a short term fix it would be ok, but I definitely would'nt recommend it for the long run.
I eventually had to have both CV shafts replaced.
Maybe they have gotten better these days..
Leo
