GM Vehicle Leaking Intake Manifolds-Anyone?
Former or current GM owners, post here if you have experienced a problem with your GM auto or truck with an external or internal coolant or oil leak related to the intake manifold/gaskets/mating surfaces. Also, state year,vehicle type, mileage. Curious as this seams to be a common problem with GM. I have had a few early '90's GM trucks that had exteranl leakage, my sister just had to replace the engine in a '97 S-Blazer with only 46K miles due to an internal leak.
and probaly internally with the oil. I cleaned
the overflow reservior real good put sealer in
the radiator and eventually traded the car. The
engine had about 66,000 on it.
I also presently haave a 96 cutless with the same
engine and same problem. This cars problem poped
up with 95000 miles on it. I put a sealer in it
also and plan on trading it also.
Both cars were very well cared for. I was guessing it could be the Dex cool coolant.
94 3.1- 76K when leak occurred
I have heard the DexCool theory but I don't believe its the whole answer. Dealer told me in 2001 that it was still occurring even with DexCool. I assume it is a problem with Aluminum heads/cast iron block.
Great engines otherwise but fatally flawed.
Does anyone know if the 3.4 engine is prone to this? My understanding is -yes.
This is a widely know problem with the Vortec V-8 engines. The mechanic that worked on mine said that the intake was torqued down too tight from the factory, eventually causing the gaskets to crack and leak. This might be the reason the intakes on the above mentioned cars are also leaking.
Wayne
1984-2000 Models
Sunbird
Four... 3.9 hrs
V6.... 5.4 hrs
Includes: R&I plenum, runners, fuel rail, and injectors
Same problem killed my 84 S-10 2.8Litre 4WD when it had 104k.
A coolant leak on my 1996 Chevrolet Corsica is what actually got me interested in Edmunds Townhall - so something good did come from it. :-)
I had my Corsica's leak repaired at about 70,000 miles (I think) and the car now has over 100,000 miles. Has anybody had this problem re-occur? One more $650 repair bill and my Corsica will be ready for the glue factory.
It sounds like your mechanic is setting you up for a big repair bill, or doesn't want to be bothered with the job, and trying to scare you off. I think you should find another mechanic.
Or, find yourself a couple cans of spray engine degreaser and give the engine a good bath. That way, you can find the source of the leak and repair just that. The airstream that is generated by driving the car has a tendency to blow fluids all over, making a small leak look really big. A clean engine is easier to diagnose.
All GM cars I have owned, most purchased new, ALWAYS leaked. Some coolant, some oil.
The answer is simple.
Has your oil started to get greyish and slimey? If that is the case, then your leak has compromised your lubrication system and could cause some internal damage. Do you know how long your engine has been leaking coolant? Two weeks likely won't harm you engine severely (or at all), but I would keep my driving to a minimum just to be safe. They will (or should) change your oil when they do your manifold/water pump work.
http://www.petitiononline.com/GMcnsmrs/petition.html
If you have had this problem please visit and sign
The tube that connected the heater hose to
the engine cracked off the manifold.
The manifold needed to be replaced for $600.
I was later told by another tech that they can
drill and tap that hole and screw in a plumbing
type of fitting. Too late now...
Jay
salem,MA
Thanks..
I'm contemplating it myself as I have a well equipped shop, but my leak is exernal so far and very small. And its a Van, so its 2x harder.
DD
