Toyota Tundra vs. Chevrolet Silverado
Auto LSD?
A-TRAC?
Traction Ctl?
Rear Locking Diff?
8 track?
I don't know what I am writing about huh? I have had Autotrac 4wd in my truck for the past 7+ years and use it all the time (in the winter). Have you ever driven a GM with it? Didn't think so, so it's you who doesn't know what your talking about.
FYI, Autotrac (aka Auto 4wd) is GM's technology for locking in the transfer case and using an electric actuator in the front diff to engage/disengage the front axles as needed. The ABS system senses rear wheel slippage and engages the front axles as needed. This happens so fast that it is far beyond human recognition. You CANNOT notice any delay. This not only saves fuel, but it saves wear and tear on 4wd drive systems. Traction control does NOT work this way. Toyota ONLY has 3 settings for the drivetrain, 2wd, 4hi and 4lo. GM has those plus Auto4wd. They also have Stabilitrak, so don't tell me Toyota's traction control is a better alternative to Autotrac, they are different animals.
I am a boater, and I won't be. I'll get to the water and back just fine in my GM, Thank You.
1. Cell phones are NOT a suitable alternative since Onstar notifies emergency services automatically upon air bag deployment. How well will a cell phone work when you are either unconscious, in shock, or the phone flew out of reach and you are trapped?
2. The point is GM is light years ahead of the competition with new technology and safety.
Well said offroader...
but as well as the diff lock wouldn't angle of approach and angle of Departure as well as gound clearance be as equally as important?
That said, neither vehicle is set up for serious offroading. For that, either vehicle will need a lift kit.
Basically, any trail that will thrash the Tundra will also thrash the Silverado, and vice versa.
1offroader
Commercial productions are just that...Productions!!! They can do what ever they want with video and editing equipment. You have no idea what that looked like in "real" life (they may have done it at 1/2 the speed of the video? Or who knows?). Look at the Edge commercial from Ford as an example.
Also, I would like to know how many times it could stop that load before the brakes burn up and the rotors warp. I am sure the GM (and every other truck in this class) could do the same thing.
Mostly because of cheap parts IMO,,,,,,,,,,,
But yet again most folks are clueless esp. those not
familiar with ABS systems and the way they "feel" when
applied during normal stopping. Forget when people freak
out after a few panic stop situations and post "my brakes suck or don't work right"...............
I had that problem with my mom. She would freak out when
the brake pedal would bump and/or the ABS computer would
make its crazy noises when activated esp. on snowy or icy
roads.
Had to take her to a snowy parking lot and have here do a
few panic stops and know the noises and pedal feel were
"normal" !!!!!!!!!!!
But noting from posts on BOTH GM truck and the tundra solution.com sites............
Each have troublesome brake systems or just crybaby owners!
Personally I never have had any brake issues with any of
my vehicles esp. my GM trucks which I heavy tow and snow
plow with...........They sure get a workout !!!!!!!!!!!
Hey, if I ever need to tow 10,700 lbs. instead of merely 10,300 lbs. I'll consider the Tundra, OK? Or maybe I'll do what any responsible driver would do - get a 3/4 ton diesel.
Standing 1/4-mile times? See my previous posts on how completely useless that statistic is.
The locker I will use often. It's not just for radical offroading. It's for everyday low traction situations - slippery boat ramp, deep snow, muddy trails. Stuff that truck owners see every day.
As far as my previous post on clearance, I can get a small lift kit (2"-3") to solve my clearance problem (which the Tundra needs also), but I can't get the locker on the Tundra AT ANY PRICE. Well, that's not quite true. I could spend $4,000-$5,000 and retrofit the Tundra with a modified Ford 9-inch, but that's not an acceptable alternative IMO.
1offroader
Let me say it's nice to finally see some posts on here that employ common sense!
Nice job, but I am starting to think it is futile arguing with these Toy lover's. They are "selective" readers/listeners and only hear what they want to hear.
From GM's website:
Transfer case: Autotrac includes automatic 4WD and panel-mounted controls; 4WD only (standard on 4WD models)
When you engage the automatic 4WD mode, the system detects wheel slippage and automatically transfers torque to the front wheels for enhanced traction and then returns to two-wheel drive as conditions warrant. You may also choose to engage 4WD on a full-time basis.
So it needs to be engaged first but depending on conditions the truck drives in 2WD mode until slippage is sensed then some ( 50% 30% 70%? ) of the engine torque is diverted to the front axles. Then when conditions warrant all the torque is returned to the rear axle.
Nice feature in that it's quick and automatic - after it's engaged.
The main difference ( benefit ) I can see is that once engaged the driver can forget about having to switch on the fly from 2WD to 4WD.
Stabilitrak is an option on most GM's, standard on the CrewCabs, but it's standard on all Tundras ( VSC/TC )
While it's standard on GM vehicles, it's also available on any vehicle. Ditto Extended Service Contracts, GAP Ins, Health & Disability Ins, Life Insurance, etc.
It's just a personal choice.
This is a GM exclusive feature.
1. Chevy Silverado
2. Nissan Titan
3. Toyota Tundra
4. Dodge Ram
5. Ford F150
That's it. I have a very low opinion of C&D in general, but no dog in this fight.
2013 LX 570 2016 LS 460
http://en.wikipedia.org/wiki/OnStar
Then there are the Onstar owners being left behind by the advance of technology...
http://www.nytimes.com/2006/11/19/automobiles/19ONSTAR.html?ex=1321592400&en=9fe- 716b9a78201ad&ei=5088&partner=rssnyt&
And finally, don't pay the monthly subscription and 'poof' it's gone.
I've noticed in 2wd my mpg is X.
In autotrack its about X-1
In fulltime 4wd its at least x-2.
Best thing is that with most fulltime real 4wd sytstems you can't drive on completely dry roads with it...which means you can't be driving down 'dry' winter farm roads and then have 4wd when you run into a long icy patch. And tehre is no doubt that there is better directional stability with 4wd than with rwd on ice.
Autotrack is nice no-brainer system for people like my wife. Push it, go.
I've pushed my truck in deep snow (over front bumper).
Onstar used once makes it worthwhile.
A rear locker is useful alot more than a fraction of a second in a 0-60 or 1/4 mile time.
Thanks for telling me what MY opinion is. :sick:
A: Because they smell like a new truck!
Sorry, ladies...
BTW, picked up my new Silverado today (2/24). It was ordered Dec. 30 but because of the Holiday the factory didn't get the order until Jan. 8. So I guess that's about 7 weeks delivery time (to So. Cal.). I love it. Better yet, the family loves it - roomy, quiet, comfortable, powerful. All the different options for the stereo & data center are a little intimidating, I guess that will just take time to learn.
4WD Crew, 6.0, 2LT pkg., Z71 Off Road, 18" Z71 alloy wheels, EZLift tailgate, power rear window, Safety pkg., Desert Brown metallic ext., ebony cloth int. Price about $150 above invoice. Did the deal over the internet, dealer treated me well, no complaints with the service (at least so far).
1offroader
This is 180 degrees from the truth. Your thinking of part-time 4wd systems. With full time systems you CAN drive all the time in 4wd. No full size pickup truck I know of except a Unimog has fulltime 4wd. They are all part-time. Hummer, some jeeps, and landrover all have fulltime 4wd...
I ordered mine on Jan 22nd and it is built and in transit. Dealer expects it early next week. But I am having several accessories put on so it may require a few days to get them installed. So I will probably be picking it up next weekend.
2007 GMC Sierra SLT Crewcab 4x4, 6.0, 20" wheels, electric sunroof, Side surtain airbags, HP suspension pkg, Rear locker (3.73), skid plate pkg, engine block heater. Basically everyting except NAV and Rear DVD.
Paid invoice exactly,
Invoice: $38,929
less $2000 (Trade-in bonus cash and Loyalty rebate).
less $11,500 for my 2000 GMC Sierra Z71.
= $25,429 + TTL
Accessories:
6" Oval SSTL step bars ($614)
Hood Protector ($156)
Linex Spray-in bed liner ($450)
Access brand Tonneau cover ($450)
Remote Start ($262)
I decided to get the remote added after because I didn't want the entire safety pkg which included rear park assist and power adj. pedals.
Chevy or GMC 3/4 x-cab 4x4!!
Initial dealer buildup of both models is still happening
and none of my local dealers will do a GM employee
discount deal yet !!!!!!!!!!!
My bud across the street got his Chevy x-cab 4x4 1/2 ton
2 days ago. Finally got to touch, feel, and drive one
without messing with a salesperson !
Nice rig.......You won't be disappointed !!!!!!!!!!!!
tundra.....phooey !!!!!!!!!!!!!!!I need a REAL truck to work hard and GM fits the bill..........
The Chevy Safety pkg. has the side curtain air bags, and also incl. the power adjustable pedals. My wife really likes that, she can make the truck fit her. I can never figure out how they come up with the pkg. combinations - power pedals don't really seem like a 'safety' item, more of a convenience feature IMO.
The Chevy Z71 pkg. incl. the skid plates and rear locker - that makes more sense to me.
MSRP on mine was $38,875, Invoice $35,389. I paid $35,642, but got the dealer to include a third key which is worth about $150, for a total of 'about' $35,500. It's not like the old days where you could go down to Home Depot and have a key cut for $2. Well, you can, but it'll only get you in the door, won't start the vehicle. I didn't have a trade in, and haven't bought a GM in some years so didn't have the Loyalty rebate.
Does the GMC come standard with the EZLIft/locking tailgate? That's an extra option on the Chevy but worth it IMO. I've heard of tailgates being stolen - they are about $900 to replace.
I'm going to be getting a tonneau soon. Your tonneau sounds very inexpensive, the SnugTop that I am looking at is about $1,100. What's up with that?
1offroader
I got Steel Gray mettalic with ebony leather interior.
The option packages are slightly different between Chevy and GMC, also, I think they are different at different trim levels.
I didn't want the power pedals because my wife won't drive my truck. In the 7-1/2 yrs I've had my 2000, she has never driven it. How awesome is that? Not because I won't let her, she just doesn't want to. Go figure.
I couldn't get the Z71 because I got the 20" wheels which req'd me to get the HP suspension pkg. So I had to add the skid plates. The HP suspension includes the larger stabilizer bar and the HD monotube shocks. But if you were as thorough in your research as I was (borderline anal), you probably knew that. No EZ lift locking tailgate, my theory on that is with a soft cover and a locked tailgate, curious thieves will just cut the cover to see what I have to hide/lock. I never leave valuables back there anyway. As for theft, insurance will cover that.
I HIGHLY recommend the Access brand roll-up tonneau cover. It is far superior to any other soft roll-up IMO. I have had one on my 2000 since new and it is still like brand new, still tight and in mint cond. I do treat the vinyl a couple of times a year, that's it. I would not even consider anything else this time around. My buddy has a Truxedo on his F150 and it is junk, always loose and flopping in the breeze.
I do carry valuable stuff in back, so I'm getting a hard tonneau that locks. SnugTop makes a good one. I have used their camper shells on several trucks and have been very satisfied. Along with the locking tailgate it's about as secure as I can make it. If you know of a different brand hard tonneau other than SnugTop that you can recommend I'll take a look at it.
1offroader
So, you carry valuable stuff in the back huh? Where do you live? haha JK.
Good Luck with yours, I am sure you'll love it as I know I will. Can't wait to get mine, but were in the middle of a snowstorm right now and I would kinda prefer winter to be over before I get it so I can keep it clean while it is brand spanking new. Oh well, another month and it'll be spring.
What ?????????? I'd tell them to go to hell and get on the phone and find other dealers !!!!! :mad:
Rocky
http://www.sportruck.com/news/2007-GMC-Sierra-Denali/index.htm
So the Z85 does what ? Is it like the Z-71 ?
I'm kind of embarrassed I don't know much about these pretty new suspensions and was use to Z-71 being the only option for years. Y'all can educate me a bit and perhaps this can be a break in the he said/she said for a bit.
Rocky
Never had a boat, but I've towed plenty of construction equipment to various on and off road sites.
1. Ford
2. GM
3. Dodge
4. Others (including Toyota)
How'd I do?
The 2500s are not showing up on GM Buypower yet!
No nearby dealers have a black x-cab with the WORK
goodies I need ie: locker, plow. prep., tow pkg.
If the dog can't hunt....I don't need it !!!!!!
If I was looking for a driveway queen racemobile
possibly a 5.7 tundra would fit the bill.........
NAAAH!!!!!!!!! I would NEVER hear the end of it!
ALL of the ones I have seen also are loaded out with
leather and are $40k plus ! Mr. dealer don't wanna
hear "GM employee buyer" discount on the 3/4s either !
But they are quite eager to sell me a 1/2 ton but NO
firm answer on warranty issues plowing without the VYU plow
prep. option !
They are drooling over my 04 2500 x-cab 4x4 trade with 20k
miles. These late model 3/4 ton GMs sell like hotcakes
used up here for top dollar!
I can wait...Besides we might get another 11 FEET of snow
like last week so I have to be ready to plow !!!!!
Fords and Chevy's like now it depended on the buyers.
You insult other posters as being stupid yet you don't seem to understand what makes up the full size truck market. Toyota is not a player in the HD market, has no diesel and has no production capacity. Nissan can't even fill the capacity they have. It will take Toyota at least 12-15 years to be able to challenge Ford and GM, if they ever do. GM and Ford have loyal pickup buyers because they make great pickups. Toyota will have as hard a time getting Ford/GM converts as Ford and GM will getting Camry converts in the car market.
According to the Silverado pamphlet:
Z83 Solid smooth ride with rear twin tube shocks and 32mm front stabilizer bar
Z85 Handling/Trailering with rear monotube shocks and 34 mm bar
Z71 off road susp. w/rear monotube shocks and 34 mm bar
Z60 Hi Perf. susp. w/rear montube shocks and 36 mm bar
MAX TRailering susp. w/hi capacity rear springs and 36 mm bar
So...
Sounds like the MAX trailering is the heaviest and Z83 is the softest. The Z71 also comes with skid plates. If you are getting a 4WD and do much offroading I can recommend the Z71. I like the handling - firm but not harsh, corners flat, little body roll. Good compromise.
1offroader
Rocky
Rocky
I will venture that if Ford doesn't solve it's problems before it runs out of money it will be absorbed by someone as a much smaller entity. Already the volume is down to 800K units and they just cut the workforce by 50% closing the plant 10 min from where I work. And even with reduced goals on sales Mullaly advised the workers that they would not hit their Feb or Mar numbers either.
I know very well that to be fully competitive both the Nissan and the Toyota will have to offer HD versions. Soon, they will be here soon enough.
As to 12-15 years it may very well be that to challenge GM. I've never said otherwise.
If Ford doesn't solve its financial problems immediately it won't be here in 12-15 years and those sales will have to go somewhere.
Dodge may not last out the year much less see the next Ram.
If GM were to buy it..
If the Chinese were to buy it..
If an PEF were to buy it..
If it's spun off to the unions..
Which of these four have the multi-$Billions to fund development of the new Ram while at the same time funding ongoing losses in the current model?
'Toyota's San Antonio plant was announced in February 2003, and construction began later that year. When the plant reaches full operations next spring, it will have the capacity to produce 200,000 Tundra full-size pickup trucks and employ 2,000 team members.
The plant's investment was originally estimated at $800 million, but grew to approximately $1.28 billion because of a capacity expansion for 50,000 more trucks; rising material costs, especially for steel; and additional infrastructure needed for the on-site suppliers.'
Can you show me where it says that they can produce 500,000?
By the way it took 40 years for BMW and M/B to start outselling Cadillac in North America after WWII. That seems pretty long to me.
TMMTX is on one shift until June when they will bring on the 2nd shift. Indiana is well established but smaller with more vehicles on its schedule.
The plant was built with the expectation of going to 700K units somewhere in the 2015-2020 time frame.
If events shorten this then it will have to be addressed.
The whole purpose is just to make money as every business wants to do. Being first or second is of no importance here as long as by the end of the next decade all the vehicles are profitable, whatever the volume, and the lines are busy. It's been 14 yrs since the initial baby step. That's just a beginning in a 25 or 50 year cycle.
the 4.7 has? Seems GM isn't the only one having this problem.
This link is one to watch:
http://www.tundrasolutions.com/forums/tundra/89753-do-2007s-knock-cold-weather-s- - tartup/
