You should be able to beat the oil filter price by a dollar or so, and I'd get a 17mm crush washer (I think that's the size, anyone confirm?) from the hardware store for a few pennies, maybe even buy a dozen.
-juice
$5 for the filter & washer
Shipping is $3 whether you order 1 or 10
It took just about a week to get the parts.
Hope this helps you!
~~~Pat
Ken
oil filter is $4.60, washer is .39. If you get a dozen filters it's $4/each.
fyi cabin air filter is $29.96.
I ordered recently from them, I had to wait for a backordered item but once it was in I received everything 2 days later. Shipping was reasonable, but we're both on the east coast. Subaruparts.com charges 10% of your order for shipping.
Very pleasant on the phone.
Is it worth $1 savings on an oil filter?
steve-v
santa cruz
-Colin
-Colin
-mike
Just to let you know (and Patti) that Subaru took care of my chattery clutch issue. They put in a new clutch for me last week and all is smooth again. My initial complaint (which was not duplicated by the tech) was at <15K and since then has gotten slowly worse, but unpredictable. I am now at about 35Kmiles.
When my car was in for another service, about a month ago, the district rep was in town, drove it and approved the repair.
Kudos to the folks at Van Bortel Subaru and SOA for their eager-to-please service.
I wanted to re-iterate, because I have not seen it mentioned, the great experience I had with Premier Subaru (www.premiersubaru.com) as far as getting parts. I ordered the 6-disc changer, received it a few days later. They were the cheapest to boot! ralvine@premiersubaru.com is Robert Alvine's email there.
Happy Holidays!
Howard
-Colin
Patti
Could someone clarify what is meant by "winter mixture" gasoline? Has it been scientifically verified to reduce mpg? Does my state of Pennsylvania use it? Are there officially stipulated dates between which northern states are to use it?
Joe
Winter gas typically has more stuff in it to make it less polluting. That makes it burn differently and does affect the MPG in any vehicle. I know my mileage goes down slightly in the winter - about 1-2 MPG. I'm not sure if it's been scientifically proven, but the local papers have run stories on the affects a few times. I have kept a gas mileage spreadsheet (isn't that OCD?) and can see a slight decrease in mileage with the winter blends.
I have read other stories about people getting worse mileage during the winter blend usage. I basically just shrug my shoulders and continue to fill 'er up.
Hopefully someone will chime in with that web site and maybe a more technical answer.
-Brian
ramon: pix, yes, right here.
-juice
first of fuels are by no means the same everywhere. due to idiotic regulations, there are actually well over 100 different blends of gasoline in use right now. some differences are minor, but it still makes for a very specialized and optimized supply chain that is vulnerable to large consequences for certain markets based on a single failure.
anyway, winter blends as a whole are not 'to make money'. quite simply the idea is to make money all the time, and because of basic economics (high fixed costs, lower variable costs) it is easiest to make money when the price of crude oil is high rather than low.
oxygenates do not help emissions 'only until the converter warms up'. their waste more readily forms water and carbon dioxide, which we've decided is less dangerous than carbon monoxide. there are really only two readily available oxygenates, methyl-tetrabutyl-ethylene (MTBE) and ethanol. neither are great for you-- what is these days? ;-) -- but MTBE is a whole lot more toxic, carcinogenic, etc. and easily pollutes groundwater. and yes, it is being phased out.
ethanol's problem is that it costs far more to energy to produce from corn that the resulting product is worth-- it ONLY survives on government subsidies. it also costs a good bit of money outside of corn-producing areas of the country.
anyway, that's enough for now. you can learn more at www.api.org or use your favorite search engine.
-Colin
-Brian
Hello, all!
I just thought I would join the Subaru frenzy. My wife and I just purchased a used 2000 Subaru Legacy GT Limited sedan with manual transmission. It currently has 8,800 miles (low!), and has the Rio Red finish with tinted windows and a rear spoiler.
The car is currently sitting in our garage. Thursday we will have an Invizibra kit installed to prevent the paint and lamps from being chipped up. It's been absolute torture letting it sit for the last week, but I'd rather wait until the Invizibra is installed before we take it out. What's worse is my area has received a ton of snow in the last week, and the Legacy would have been perfect in it.
This is our first Subaru. Until now we've been Honda and Toyota fans. Any advice for maintenance and care of the Legacy sedans (common issues/problems)? Also, the manual mentioned you can't use snow chains on the GT models because of clearance issues. Will cables fit instead?
Ty
Duke
Bob
rsholland: thanks for the welcoming!
Ty
Jon
-juice
You can check out the Amsoil ATF here:
http://www.amsoil.com/products/atf.html
-Dennis
I found that the current model Legacy/Outback sheetmetal does dent easily. The paint holds up pretty well. Most hood chips that I've got were from following construction dump trucks too closely.
Second, upgrade the H1 bulbs with Catz Galaxy Whites. About $42/pr from www.autobulbdepot.com. If you are planning to work on the car yourself, get a set of the Blitz Rhino ramps. It's hard trying to slip a floor jack under the center jack points in a low ground clearance car.
I have under 7,000 miles on mine cause the wife drives it mostly in a 3mi. commute to work. Using Mobil 1 in winter, dino oil in summer. Only problem I have so far which I need to bring in to fix under warranty is a tear in the weatherstripping in the least used door. Don't know how it got there. I have fog light protectors only.
Patti
Patti
I definitely agree about the Potenza tires; they may offer good performance on dry pavement, but they slide around in the snow. I'm not sure about going with a dedicated snow tire, though. I may look into an all-weather tire like a Michelin MXV4 or X One. Since our roads are generally clear about 90% of the time, I'd prefer to have a good all-around tire and carry cables for those days we head into the mountains.
Why new head lamp bulbs?
I too would like to know more information about switching out the headlamp bulbs.
On parts, my wife bought me a Subaru Cooler for Christmas. The only reason I know about it is because I answered the door when the UPS man came! She bought it at subaruparts.com and their price was significantly LESS than our local dealer! She said she got great service, and the cooler arrived in less than a week!
Has anyone changed the filter for the air filtration system? How often does that need to be done? I thought I had heard that it needed to be done anually, but on subaru.com in the maintenance schedules, it says the "air cleaner element" needs to be replaced every 30K. I think I'm talking about two different filters... any advice?
Thanks all- hope to see some of you tonight in the chat.
Pete.
For the headlights, I have one H4 bulb per side, I think you have two bulbs for high and low beam and they are different.
Can anyone else offer help?
-juice
Cheers Pat.
in the end I paid nothing for them wasting my time and I won't be back. now I'm looking for a shop that does want the money for the labor and will use the parts I provide. if I can't find one soon, I will do the work myself.
-Colin
Outback165: The 30,000 mile scheduled replacement air filter (air cleaner element) is for the one in the engine. The one for HVAC (Air Filtration System) behind the glove box is at 7,500 miles. There are 2 elements that are behind the glove box which have to be removed. Instructions are included with replacement elements. I just opened mine up and I hope that the one used in 99 model year is the same as 00 model year. I bought it from subaruparts.com. The diagram looks like a 00 dash. Don't know what the 99 dash looks like. The instructions for my unit says 99MY.
-Dennis
-Brian
Look under "Installation Instructions" then "Air Filtration"
http://www.subaru-parts.com/
HTH
Greg in IN
Cheers Pat.
Also, there are a couple of dense foam rubber 'doughnuts' that are made to sit in the bottom of the cupholders. According to the parts guy, there is no number or source for those, they only come on new cars.
Thanks for any help regarding these parts!
-r
Pat: me too, very useful at times, that simple net.
Colin: I figured you'd do it yourself anyway. I'm not sure a mechanic is going to apply the exact torque and in the specific order they're supposed to for those heads.
-juice
My rear washer doesn't work and the dealer checked it off as full when they did the initial service check of the vehicle. I can't the fill location for the rear and the owner manual is no help.
Mark Ayares
-juice
