Me driving on I-95 last week, doing 82 mph, and here comes grandma coming alongside next to me. She looked over, smiled, and brrrrrrrrr she went.
Even li'l old lady don't drive like a li'l old lady in a turbocharged.
She was in a black '07 STi.
-Dave
Different headers? Modified valve timing?
Or is the whole idea of the Subie engine to rev at high RPM and you use a manual to get power out of it?
A CVT sounds like a good match for this kind of engine, but Subie doesn't offer it.
YET.
Nissan does and the Subaru auto trans is sourced from Nissan. That suggests we won't have too long a wait. Yes, I know Toyota has a part ownership of Subaru, but that probably does not matter. Nissan and Toyota share some components.
Compared to other Japanese cars, the Subies actually have a lot of low-end grunt. Honda especially is very top heavy.
On Turbo models you need to get up past about 2600rpms to get into the turbo, but with my LGT I can easily get to 80mph and I skip-shift 1-3-5. Not sure how much of a rocket you want but that's a pretty good torque band if I'm skip-shifting all the time.
-mike
I wouldn't be surpised to see Subaru use some of the Nissan CVT technology.
Also all your switches are Nissan sourced switches. Pull the driver panel window switches and you'll see a nissan control box there.
-mike
Anyway:
I'm wondering if the '08 Outback XT got similar "torque enhancing" mods that were given to the '08 Impreza.
A subaru dealer I visited said this was so.
But I cannot find any confirmation of that on the Subaru web site or anywhere else. :confuse:
Actually it was the '08 Imprezas that got the controls that the 07 Legacy/Outbacks got. I-drive IIRC is what it's called.
-mike
Is he not referring to the change in the turbo, cams, etc.to reduce the rpm at which torque is maximum?
Dave
-mike
And from what I saw on two other comparison sights, other than ratings, the Outback XT engine appears to be unchanged from 2005.
There is a "speed package" that offers a less restricted intake pipe and heat shield for more HP/ torque, but I'm not sure how well that air filter protects the engine.
I did see the Impreza engine did get tweaked for broader torque, but unfortunately the former VW style seat (hinged at front,tilts you into the dash when raised, etc.) proved no match for the outback. Custom leather only made the Impreza worse (why on earth does a custom leather maker put a hard seam right under one's butt ?? ).
Does this qualify as righty-tighty/lefty-loosey?
Cheers!
Paul
Aim it against a wall with horizontal lines, then turn the light on while you adjust. That's how I do it.
Is this typical for all Subarus, or just the outback?
I do think it's crucial to keep the prices flat. The segment is more competitive now, and Subaru needs volume from the Forester.
The other thing is my 1998 has excellent lights. Bob's isn't as good. He has an 01 or 02, IIRC. So it depends on the optics.
If they can get lights as good as my 1998's, which were cheap and halogen, then I'd say stick with those. Cheap and effective.
Impreza has had projectors since the 06MY.
-mike
In 07 the turbo Outback/Legacy got a manually adjustable ECU which adjusts the boost and some other items and on AT cars changes the shift points.
-mike
Is this adjustment the 3-setting engine response control Subaru is talking about, with intelligent, sport and sport sharp settings?
or something else?
In intelligent it turns down the boost along with a few other fuel saving ECU items. In Sport it's "normal" and in sport sharp it increases boost as well as throttle response.
-mike
1. intelligent = linear but rather sluggish
2. sport = 2 step response (linear jumping to turbo in about 2 seconds)
3. sport sharp = less wait between linear and turbo transition, but still there.
Noted no turbo response until over 3K rpm. Meanwhile auto trans kept wanting to keep engine down around 2K or so.
Seems like the turbo's still not all that well matched to the auto. Perhaps a CVT would be a better fit?
My dealer research first checks them against BBB. While not foolproof, BBB does flag the really bad outfits (like one in Portland that I now avoid like the plague). If they pass that check, and Edmunds readers' dealer ratings, a visit is in order, during which _Any_ dishonesty in a sales person, excessive handoffs leading to high pressure tactics, or any tricks started by the finance department, will lead to a polite "no thanks" and hasty exit.
It does no good to complain to those types - they are usually short focus "deal makers".
I'd suggest doing business with the "good dealer" as much as possible, and leave the bad one alone.
Just as important as keeping business from the bad dealer is sending business to the good dealer. So, what dealership did you drive farther to for a great sales experience? Folks are looking for dealer references here all the time.
Yes, your bad experience does reflect on Subaru. Fortunately for the brand, you had a good first experience elsewhere and were willing to go there to be a repeat Subaru buyer. For many folks, that bad experience would be their first impression of the brand and would be enough to keep them from buying a Subie. Something like that might be worth repeating to a Subaru Customer Service rep. You can contact them through this form at the Subaru.com website: http://www.subaru.com/tools/contactus/index.jsp or through the 1-800 number at the bottom of that form.
Congrats on the new car, BTW!
My problem is to keep the XT from doing (for me) the dreaded "turbo two step" where the car keeps switching between turbo and non turbo mode. That proved unpleasant and, in real world driving, unpredictable.
The only way I can see, so far, to avoid that is to always keep the engine above 3K RPM and shift like mad. Which is what Subaru apparently has in mind all along.
...or just bypass the issue and consider the H6 instead ?
Haha! Many of the folks I see driving turbo Subarus do just that! I cannot comment on that aspect, though, as I have never driven a turbo-charged car of any kind.
I expect that the 5EAT has the sport mode for the transmission. You shift it into this mode by pulling the shift lever to the left as though you are going to engage the manual-shift option of the transmission, but then do not move the lever up or down. A small green light should illuminate on the dash just below the gear selection indicator that says "SPORT." I notice on the 4EAT that the transmission holds the gear longer before shifting, even if accelerating slowly.
Folks say it is a very different experience, but, considering all the research you are performing, it seems to me like you should try an H6 for yourself to see whether it is even something worth considering.
I'm not a performance hawk, but would like to see the same responsiveness in a Subaru that I get in my current Malibu Maxx (something Car&Driver liked about the latter). So far, I've not found a Subie that does that - they've proven either underpowered or non-linear (the latter apparently an inherient trait of any turbocharged system).
But thnx for suggestions...I will try those things when I do another Subie test drive.
If one's objective is fastest 0-60 times, the turbo is a delight. Drive both the turbo and H6 in heavy traffic before you decide.
BTW, the 2.5 is pretty good propelling the lighter Legacy sedan and, yes, is a bit pokey when in the heavier Outback body. It's one of the reasons we upgraded from our '04 Outback sooner than we typically would. A 2.5 Outback's not bad, but I think you'd have a hard time calling just the acceleration aspect "fun" at any point.
I believe they complained about its slightly tail-happy cornering.....one of the reasons I like it!
As to fuel economy, it is about 1/3 BETTER in town than my Passat W8 wagon was.And it stays out of the service bay.
H6 sounds promising, however, and perhaps the SI drive will give the option for a bit more spirited response (as needed) than CU got (they tested an '06, BTW).
And they (CU) do not use brake-throttle combination for maximum accel. I do when needed. There is a large difference in 0-20 mph.
The auto trans on the W8 was so marginally sized that VW did not (and could not) permit preloading!
I'm finding that info very hard to locate, and Subaru is strangely silent about those when asked.
1. loud clunks in the drive line when accelerating gently around 30 mph. happened several times. Is this typical for Subarus running at midrange speeds?
2. substantial hesitation in acceleration. for speeds around 30 - 50 mph, pushing the gas for passing didn't get any real response from the engine for about 1-2 seconds. Shifting the transmission in to third helped things a bit, as did manually shifting the trans. this was true for both sport and sport sharp modes (intelligent mode was pretty lakadasial).
Does Subaru expect drivers to shift an automatic transmission "manually" in order to get a responsive driving experience?
this is all in comparison to my primitive 4 speed pushrod Malibu Maxx, which proves very responsive if not having the ultimate power of the Outback.
2) Mine is sensitive to whether I use premium gas, as recommended, or not. It will have a hesitation when I really get on the gas if I use regular octane gas. Premium alleviates the hesitation. Perhaps someone saved a buck or two when they put gas in the car?
I have a legacy GT w/5MT and I drive in NYC and NNJ traffic all the time with it. No hesitations, etc.
I drove my brother in laws outback 2.5i and it's a bit sluggish but in sport mode on the trans it was adequet for me, and I'm fairly aggressive.
If you do get a turbo and keep it above 3k RPMs your milage will drop to nothing. I rarely go above 3k in normal driving, except when I want to pass.
Also the transmission learns (over 1000 miles) what your driving style is and will adapt to it so that is something to consider.
-mike
2. same as 1. Also, smoothes out when driver gets acclimated to the AT.
i.e. stumping/flooring the accelerator from standstill or cruising in overdrive will result in hesitation.
-Dave
I've no idea whether the dealers are using premium or regular in the cars I drove. But it's good to know that when Subaru says premium, they mean premium.
And no, the test I'm doing is pretty simple; simply trying to determine how the car will handle in a S. Calif passing situation. Which is usually running 30 - 50 mph and then pushing (not stomping) accelerator down to get speed up to pass.
Yes, if the accelerator was stomped, the car definitely bogs for 1-2 seconds.
By comparison, the Maxx only bogs for half a second, and perhaps that is because its tranny is sorted out.
I'll try to find used versions of these to drive.
When I finally got unstuck, I noticed all 4 wheels were spinning but moving me out of the snow.
My wifes 05 Legacy turbo was fine, and went right through the same conditions.
Could the snow have packed under the diff, It was as high as the bottom of the door.
If there is anyplace that I can get an answer, I thought it would be from all you very knowlegable people on this forum.
Thanks for your anticpated help. Bob "G"
If you had snow up over the doors you probably high centered yourself. The Legacy may have been heavier and been able to dig down better. The other thing is it could have been a tire difference. Let us know the spec on both cars and we may be able to give you some more insight into it.
-mike
The Forrester is a 04 turbo automatic with yokohama AS 430 replacement tires with 20, 000 miles on them. Standard factory size. (I don't know what the size is).
I did notice in spite of the high cost and advertising, they always seemed a little slippery in snowy conditions.
The Legacy is an 05 turbo automatic with standard factory Z R 17 high performance all season tires. These tires also have about 20, 000 miles on them.
The 05 Legacy auto turbo, has traction control, and I don't think the 04 Auto Forrester has traction control.
Again, thanks for your anticpated help!
Bob "G"
Is there a particular area I need to keep an eye on, and make sure is properly maintaned, to avoid it?
