bad ground or bad ignition switch? aftermarket alarm does something with the ignition switch though, right?
-Brian
The Check Engine Light illuminated for the very first time late today, so my wife drove to the dealer for a diagnosis. The computer threw a P0139 - Rear Oxygen Sensor Circuit Slow Response. The dealer reset the CEL lamp and told my wife to "keep an eye on it".
What exactly does this error mean?
Could it be the key to the intermittent pinging solution we've been seeking for 1-1/2 years?
Thanks for any advice.
Asa
-Brian
I posted on nabisco and someone there said that since I can't get into valet mode with the keypad, the switch is probably disconnected or bad. I guess this is a good argument for having AAA because now I can't get to the alarm dealer. Hopefully I can use my wife's AAA.
-Dennis
hopefully the alarm fixing doesn't cost anything and that nothing but the alarm module is at fault.
-Brian
-Dennis
Assuming they have a clue as to what they are doing, they should have made some attempt to remove the mud (if there was any) before balancing the wheels. Otherwise, you have a totally unbalanced and variable system. If they did that, and rotated the tires (front to back), the feeling you experience in the steering wheel should have changed. If not, then something might have been damaged suspension wise when you hit the deep hole. Usually simple alignment problems don't cause what you describe, but if say a bushing retainer was damaged and there is free play, it could act up at speed.
Steve
Your observation that the light was off when cold, and came on at about a mile accompanied by a slight hesitation might be significant. Initially the car is operating in 'open loop'. When the temp gauge reaches just short of normal (about a mile??), OBD switches to closed loop, and now uses the O2 sensor to regulate the mixture. The O2 sensor might be iffy, and messed up the mixture during this transition, causing the hesitation and triggering the light. If it doesn't happen again for a while, the light will go out on the 4th startup, but the code along with the conditions at the time are all stored. I get this too occasionally on my '02 OBW.
Steve
OBD2 uses two oxygen sensors, one before and one after the cat con. The front one does the active job of sampling and reporting for the purpose of regulating fuel/air mixture. That sensor could potentially play a roll in pinging, but not the rear. The rear one is really just a monitor of how efficient the cat is at using up all the available oxygen in the 'burning' of leftover hydrocarbons. If it comes on again, it could be a low efficiency cat, or as the code suggested, a slow to respond (warm up) sensor. Cat is covered for 80k miles, but the sensor only to 3yr/36m.
Steve
i recently acquired a subaru forester 98. for the most part a great car... a few months ago i heard squeaking/rubbing and thinking it was a bad belt discovered my crank pulley had separated (i hope that makes sense. the stock model has rubber separating the outside where belts connect and the inside where it bolts on.) scary to drive on :surprise: we (my boyfriend, Ben... the one who fixes things) decide to go with an aftermarket part seeing as it is the same price but better. this being a new vehicle for Ben to work on consults the local Subaru dealer trying to find the 'proper' tools for the job. we were told it was a reverse thread... several times!!! ...it was not ...we broke tools trying to remove it... made new tools to try again and what do you know? we snapped the bolt... if only i had switched my insurance to storage sooner... the wonderful guys at the dealership wanted no responsiblilty claiming what they say on the phone can't be held against them.. especially because we took the liberty of doing the work ourselfs.. bastards :mad:
but he got it out! ...if you can believe it he super glued a wooden doweling rod to the end and just twisted out the broken threads (with the old part still on the threads didn't bottom out and came out fine)
now were not sure how to get the new part in (as the motor still moves.) just picked up the new bolt (had to get it through the dealership because when they didnt have it in and i asked for the specs to find it elsewhere i got put on hold and than told they dont know and couldnt find the specs!!! are they serious???) *sigh* so anyway... im sure there is some little simple thing to do to stop the turning and make this be a happy ending.
please help- sera
The front pully also serves as a harmonic dampener for the crank, which is part of the reason for the rubber isolation between the dampener section and the pulley. Only once have I had that interface fail (an old Nissan), and that had reverse threads, IIRC.
If your Forester is a manual, you have it made. Put it in 5th, and the crankshaft should be locked in place. If it is an automatic, it gets more tricky. Subaru has a special service tool that slips into the holes found on some crank pulleys to hold everything still. Alternatives include removing the starter and wedging something in place to hold the flex plate (flywheel) teeth.
It is also a good idea to change the front oil seal while you are there.
Steve
Any tips on loosening , removing, and then replacing the fuel lines on the filter fittings? Thanks.
Randy
I have used slip joint pliers. Most have a pipe grip just past the nose region that is perfect for this application. Wrap the fuel line in two-three layers of cloth or paper towel, and clamp light/moderately with the pliers. Rotate maybe 1/16 of a turn to break the 'weld' between the rubber and steel. It should then just slip right off.
Steve
Take it down the block and let her make the call.
-juice
Not the end of the world, but what happened next was interesting.....
I went to the dealer to get a similar length of fuel line, he measured it and "no charged" it for me since I buy all of my maintenance parts through him.
Anyway, I installed the hose and everything was fine. For about a week. Then I looked under the hood to add some w/w fluid and noticed that the new hose was noticeably swollen. As in really swollen. I think the hose was SAE 7 rated. I bought a hose rated for high pressure fuel injected cars (SAE 9?) from PepBoys. Swapped them out and its been fine ever since.
I may have the SAE numbers wrong, but do remember the hose I bought from PepBoys was a different, and I think higher, SAE number.
Wouldn't have been pretty if the other hose had ruptured.
Larry
-juice
Good luck!
-Wes-
as for finding a book... i have not. i searched Haynes website and it seems they dont have one for the 98 forrester.. i know theres other books but once again the only place i can find them would be ordering through my 'favorite' dealership. they have one thats split up into three different books and are super spendy to get them... which sucks... anyone who knows where i can track one down PLEASE tell me... ive had books for all my other cars and it has helped lots.
thanks again- sarah
Asa
Steve
The alarm company guy charged me $30 to come out to my house and temporarily bypass some things to get it running. I'm taking it in to them tomorrow.
-Dennis
I'm an old lurker who's been away from the boards awhile, but thought I might come back to see if anyone could help me out. I have a new son in the back of my '04 Forrester XT who needs daddy to fix the windows, they're too bright!
I'm looking for a reputable window tinter in the DC area, someone who will work to get all those little bubbles out of the tint. I'm hoping to get this done sometime in the next month, before it gets too hot. Anyone out there got any suggestions? Juice? Bob?
--Subarufus (aka locus)
Any ideas what this could be?
$1200 is rather excessive.... I would figure that a rebuilt pump should be available in the $250 range. If it dumped metal shavings into the system, it might need much more work, but a simple pump swap shouldn't be more than $400 or so, I would think.
Steve
I got under the car today and noticed I could turn the rear drive shaft close to an inch back and forth....There is no clang or clunk or any performance problem although I am starting to notice a speed sensitive low "whine" from the rear of the car after about 25 MPH +.
Am I ready for new U joints?
Also, with the whine, is that indicative of wheel bearing wear?
Other than that, the car has run flawlessly for 5 years. There are no seal leaks or other telltale indications of any other problems..
If anybody has had any other experience like this I'd appreciate any info as to cause and future approx. repair cost...
I am thinking about trading for a new '06 Forester XT if repairs look high..
Thanx
Thanks for advice. I drove car straight home and has remained parked since. I read an earlier posting that suggested belt tension caused alternator failure and so I suspected too high belt tension may be the case also, but didn't know who to call for a specification. I was also told that the power steering pump from my model onwards was a different non-rebuildable design which is much more expensive. Dealer said pump cost is 1,030 dollars without labour. Is there an aftermarket pump? Foil sticker on pump reads "UNISIA JECS" "25214005" and "34430AE032"
Jon
1stsubaruparts.com - p/s pump for 2000 Outback: List $329.95; their price: $237.56.
You may want to call a couple of other dealers for comparative pricing.
Jim
The adjuster on the parking brake handle is really for fine trim use only. The real adjuster is a manually adjusted star gear located within each rear parking brake drum.
Your car has rear disk brakes for the main service brake. Buried within the center hub (lug nut region) is a secondary miniature drum brake like on cars of old. They used a star nut on a threaded shaft to set the spread of the shoes, but also had an autoadjuster which worked when you drove in reverse. With this unit, you must go in and turn the star gear with a screwdriver thru a small rubber cap covered hole in the backing plate. The tricky part, at least for me, is to 'feel' when you have the shoes to just about touch the drum, but not drag too badly.
If you have taken up most of the slack in the cable with the handle adjuster, you will have to first loosen this up in order to set the shoes.
Steve
Mark
A lot of owners end up removing the heat shields because of what you describe. I believe the only thing you need to worry about is parking over dry grass or leaves.
Ken
Tint: I used New Again in Silver Spring, MD, close to the Metro stop. Back then it was $170 for SolarGard tint film (not metallic).
Everyone swore it would fade to purple but 8 years later it still looks good. I did have one single window peel slightly in the corner but it may have been my fault - not enough time left for it to dry. We had also done our 626 and that was flawless, though we gave it something like 2 weeks to dry!
-juice
-Dennis
-juice
-mike
There was a TSB, I believe they substitute Legacy bearings, which are more robust. People that got those did not have repeat failures.
-juice
Juice- as for DC - my brother wouldn't mind. I'd be able to keep an eye on his daughter who's going to George Washington.
As for the shield, I am on city streets 99% of the time, so I guess I will climb underneath this weekend and remove them.
Mark
What does she look like? )
-juice
-juice
-mike
Appreciate it, but I have to see how the day goes. I have to be in Brooklyn by 11am for a function. I'll keep it in mind, though.
Mark
Good luck, Chris.
Good luck, please keep us posted.
-juice
