I have almost 3K miles on my vehicle, and so far the honeymoon is still on as it is my first non-Big 3 auto. For the record, I have gotten 29.5 mpg on my last business trip. However I do have another question for the Group.
I have noticed from almost 1 day of my 2001 OBW, when I back out of my driveway in the morning, my brakes squeal or squeak. Having just read a similar post from another 01 OBW owner (with no solution replies in a newsgroup), made me think of asking here?
Thoughts?
Again, my thanks in advance...
Patti
seamus
You should hear the valve tapping noise on our 626. Scary, but it goes away after oil pressure builds, so we've been advised to ignore it.
Stromung should pass, no?
-juice
Do you park outside? I'm wondering if the squeaking is do to brake pad oxidation from morning dew.
Ken
Just wondering if you got my re-send of my case update.
Ken
Do you find it too loud, or more correctly, do "others" find it too loud? My days of holding the clutch in and coasting by cops are long gone.
Did the cop that pulled you over make any remark about it? T.I.A.
Frank
I bought a Subaru bra for my 2000 OB from Darlene last summer. Because of the reasons previously mentioned I only use it when I go on trips. I wash the car and then put a coat of wax on the front where the bra goes. I also remove it if it rains. Works great for protecting from bugs and stones but there is a maintenance effort required.
Initial install required a little extra pulling to get it to fit but now I can install and deinstall rather quickly.
Stitching on the one end came off. I was able to repair it with a needle and heavy nylon thread.
I beleive the cost was about $110. (Hopefully Darlene will be rejoining us).
Vince
BTW; took the bean in for first oil change. When I got home I checked the oil (on the level gargage floor) and it was so high on the dipstick that I had to pump 1.5qts out. What kind of customer confidence does this intill. Next tilme I go into Bud Clary Subaru I won't know if the really know how to rotate the tires or check the air pressure or any other complicated technical procedure :-)
Guy
The Philips Vision Plus are made only in H1, H4 and H7 sizes. I purchased mine on:
http://www.autolamps-online.com/
Ken
Since our dealer removed the glazing back in November, we haven't had the squeaks since! (knock on wood) Each day as we back our Outback out of the driveway, I give the brakes a nice firm pedal to reclean the nights moisture away. And I also occasionally give them the speed-cleaning described above.
-Brian
Well picked it up today and the paint match is perfect, in their defence titanium is one of those colours that gives painters nightmares, it is a very difficult colour to match apparently.
As well there are several alternates of the colour which adds to the difficulty anyway I informed them that I would accept nothing less than perfect on a vehicle only six weeks old and not to call until it was.
So the moral here is when you get the forester fixed be just as adament that you want a perfect job they can do it when they want, they would have been just as happy if I had accepted the first attempt, unfortunately for them they were dealing with the wrong guy.
Cheers Pat.
Thanks again,
Guy
-Greg
P.S. Sorry for missing the chat last night - another hockey game, which we lost in double overtime!
bit
Once again, thanks for your help with this situation. Dealer called to advise the new england tech rep will finally drive the car with me (as a favor to SOA) on June 11th. At that point at least we can be assured that he will actually hear this engine noise and be forced to make judgement of what is going on. Chris M had left a voice mail summarizing the prior visit's lack of a finding but I assume he and/or the case file is updated with the new info and upcoming appintment---thanks again, Mario
PS I assume the data stream from the short ride they took showed nothing of interest?
I'm sorry, but I don't know what size bulbs your OB takes. My Forester uses a single H4 for both hi and low beams. If the bulb sizes that are listed in your owner's manual are available on the website then you're all set.
Ken
Thanks again,
Guy
BTW I am using my new SandK torque wrench to check all my lug nuts. 65 ftlbs is correct right? Sure seems like nothing with the long handle of the torque wrench.
bit
-Brian
bit
Have a good day
Guy
Frank
bit
Sort of shoots a hole in my full size vs mini spare theory although I guess .5 - 1 inch difference is a lot better than the 2 inches difference in circumference for the mini spare.
bit
Frank
Found a set of oil change ramps at NAPA yesterday for 22 bucks... not a bad buy! Less than the cost of one oil change at my former JiffyLube. Tried 'em out on my bride's Villager first, though...just in case something went wrong!
Cheers!
Paul
Rattle turned out to be left rear seat cushion clamp that attaches the fender well when it is in upright position. I wrapped duct tape around the brace to which the seat clamps; also per suggestion of pattim3, did the same to the brace to which the left sie of the cargo shade clicks onto because it was rattling as well. Rattle(s) totally gone. Thanks again.
Interesting, bit. So the GT rims and tires weigh 36.5 lbs? My 15" steel wheels and tires were about 34 lbs, and my 16"x7" aftermarket alloys are about 34 lbs also, even with my wider and taller 225/60R16 tires.
-juice
bit
Actually with wider rims and section width, mine have more air. I guess the GT rims are not that light. Though they seem to be durable (never heard complaints about anyone bending them).
-juice
My next test is with infaltion to see how it effects circumference. And for the hell of it i am going to measure all 4 tires to see if they vary.
bit
-Brian
bit
-Brian
-Brian
My miata's tires are by far the smallest and suffered the biggest change - they were a good 8psi or so too high.
-juice
Anyone knows a CHEAP way to fill the scratches and make them at least less visible? It's an old car but I took great care of its finish (very nice burgundy "Mica Ruby" color, btw), and it's a pain to see it vandalized.
I doubt any wax will help. A repaint would be hundreds. Anyone?
-juice
If so, how did you tie them down?
Would this job require the "round" cross bars?
I have to pick up 2 sheets of 3/4".
Thanks for any help.
Ralph
Actually, come to think of it, I carried two sections of fencing for a friend. They were 6'x8' and far heavier than a 4'x8' plywood sheet.
The Home Depot guys helped tie them on the roof. No problem at all. Well, they were a little heavy to carry around to my friend's back yard!
-juice
Ralph
-mike
Sorry to hear about the scratch. Sounds like the damage went down into the primer.
Wax won't help hide that. What you'll need to do is get some touchup paint and fill in the scratch. It's best if you thin out the touchup paint with a little thinner (it's usually too thick) first.
Here's a link describing how to do it right:
http://www.autopia-carcare.com/painchiprep.html
For myself, I simply fill the scratch by putting some paint on the tip of a toothpick or brush and allowing capillary action to draw the paint into the scratch. After it's been filled, I let it dry for a day and then use some super-fine sandpaper (1000~1200 grit)with a dab of detergent and sand down the scratch until it's level. I put tape on both sides of the scratch to minimize sanding down the "good" paint.
Once it's close enough, I use 3M Hand Glaze to remove the fine scratches made by the sandpaper. It's pretty amazing how that stuff erases the dull white haze left by the sandpaper. Finally, I follow up with a good coat of wax.
It's not professional, but it does make the scratch a lot less noticeable.
Ken
bit
Wow, Ken, could you be any more specific? ;-)
Great tip.
-juice
Patti
