intake manifold gasket failure?
I have a 1999 gmc c/2500 w/7.4 engine in which i have replaced the intake gaskets and 1 lifter. I have discussed this issue with GM but to no avail. Any suggestions? Also water pump and only 57000 miles.
Malcom E. Kelley
Malcom E. Kelley
This will dry out and overheat gaskets as well as lubricating the water pump.
I disagree with leaving any fluid unchanged as long as they suggest. I would change and flush my cooling system probably 30,000 miles or 3 years. I would not hesitate to use dex-cool as it is probably a little advanced over older coolants.
only about 15 inch pounds of torque. Mark
A number of the mechanic's I have seen still try to bolt these intake's down by "feel" and fail to follow the manufacturer's guidelines. Most still try to torque the manifold in ft lbs not Inch lbs.
