Blown fuse.
Thanks for your responses.
Anyone have the fix/ideas?
Dave
Low coolant can cause a super high temp steam pocket which can give a false reading as can a bad temp sensor or wire. A bad thermostat can also do it but they're supposed to fail in the open position so it doesn't cause overheating.
I liked the 1999-2004 better though.
Reasons: Not as wide and easier to park. Headrests!
The new 05 and up seem to have the forward bent headrests that make you sit like you're in an airplane seat and they cannot be removed. Before I buy one I'll have to reverse the headrest or take a hacksaw to it as it is really annoying.
I had to adjust the seat bottom where the front was up fairly high and the bottom was all the way down then had to slide the seat forward a bit to be able to comfortably shift and work the pedals.
Dealer has tried for over thirty days to have Ford reply via phone or e mail about engineer checking car out. NO Response.
I have called five time to Ford and have a case number and twice been promised calls back only one call and they said if dealer cannot locate problem nothing Ford can do about. They did suggest starting the at least every 72 hours (asked if they were joking?).
Any solutions or know of what maybe draining the battery enough to cause this periodic problem?
But that was me, check the engine codes first.
new muscle cars
Ford says that After a " Prolonged period" the vehicle will not start. Three days is about how long it takes for a battery to go dead.
For your information about six other Ford vehicles have this problem.
One cause is failing to turn off your radio when you park. The ignition does not stop power drain from the radio.
Oh, it only would happen for a short time after filling the tank. It would start at about 7/8th and last for a few hundred miles. Start a log as to when it happens, what you were doing, a note the mileage.
Look at this post for more details. 2793
The dealer also broke the bolt, denied it, and it WASN’T covered.
then it will probably be covered.
Chintan
Corporate Communications
Edmunds.com
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
About one out of five times, while opening the trunk using key button, I get a weird somewhat loud vibration sound (coming from the trunk latch/solenoid mechanism) instead of a typical single thunk that usually happens when it works correctly. After that vibration happens, the trunk may or may not be still locked. I think there's a 50% chance a second press of the truck release button is required to unlock the trunk. It always works after the second request. Furthermore, about one out of 20 times, after I get the above issue, the trunk wont close since the latch toggle hook mechanism is flipped. This is solved by manually resetting the hook and pressing the trunk release button again and then closing..or something along that procedure.
I decided that I'd bring it up on my first maintenance service which I did yesterday at 5300 miles. The service rep said that the mechanic/technicion found the trunk to be misaligned with the latch. The trunk was "recentered", and he said the problem was solved. Looking at the trunk, I could see that it was now shifted about an 1/8th to a 1/4 of an inch to the right. Off center. I was a bit annoyed, but if it solved the latch problem, I was fine with it. Next day, (this morning), I got the same latch/solenoid vibration and trunk didn't open on first request.
I want my rear trunk lid recentered and I want that latch mechanism replaced. It's obviously faulty. Actually, I was told two weeks earlier by someone from Ford that this latch/solenoid mechanism is known to be faulty and has been replaced in later production cars (after the month mine was manufactured). He even scheduled to have the part sent to a local dealer and have it ready for me to pick up. It was my fault for forgetting the name of that dealership. I should have mentioned yesterday to my service rep about this but I didn't because I didn't want to seem pushy. I hoped they would know about the problem or figure it out themselves and order the part on their own. Just goes to show you, the repair you get at a dealership does not guarantee a propper fix.
I'm annoyed but not upset because service was prompt and they are very polite which I value so much! I don't fault them too much since their solution was kind-of a reasonable fix, given that they probably didn't know about the issue. I was told by someone from Ford that the faulty latch only appears in 2010 Mustangs produced in the first several months. It's been replaced with a redesigned one after that.
Now, I expect and hope for prompt correction of the issue. I'm reasonably confident I'll be satisfied with their response and I will post what happens as usual.
By the way, I love the car overall. Especially the engine note and rear wheel spinning torque delivery. Reminds me that 1968 movie "Bullitt". :shades:
Joseph
San Diego
Mitch
I don't know how Ford will pull off bringing back a 5.0 in such politicaly charged times regarding the environment. 5L sounds like a whole lot even if only 0.4L more than the current engine. It will be a challenge to their engineering and marketing teams to avoid a negative backlash. I hope they succeed since the 5.0 is a legend.
I'll be blasting my 4.6L GT in the mean time.
Joseph
San Diego
:shades:
Joseph
San Diego
i get goosebumps listening to the mustang start up.
One cool thing about the prospects of 6 gears is that it enables Ford to safely offer a significantly higher rear gear ratio. Imagine a factory 4.75+ option? That sounds enticing.
Joseph
San Diego
