http://www.carpages.co.uk/toyota/toyota_prius_gt_04_09_04.asp?switched=on&echo=601403937
2)also: one dealer told me the sales tax was dependent on where you register the car, not where you buy it... is that true?? doesn't seem right...
thanks!
On the tax, this varies by state. In my state, if you pay less than 6.5% sales tax on the car bought in another state, you have to make up the difference when you register the car. (They don't want people going to a lower-tax state next door just to avoid paying sales tax.)
The tires on my 04 PRius are...P185/65R15 86S GOODYEAR..INTEGRAS. After reading the warning I did investigate my tires to make sure of their limits. Seems that Prius owners have to investigate on their own as to the tire performance standards. You have to be a tire professional to be sure of tire ratings.
Note: the last letter indicates the performance rating.
Culliganman(investing in premium tires 2nd time around)
Culliganman( Goodyear tires are holding up better than expected)(04 Prius w/17K)
P.S. If you're as confused with today's tire specs I suggest going(like I did) to Goodyear's website for the details.
I also find it strange to Goodyear tells you that your tires are rated up to 119mph. According to what you say they are "S" tyres and these normally range up to 112 mph:
http://www.tyres-online.co.uk/techinfo/speed.asp
That would you be OK for the Prius as it's maximum speed is a little bit below that mark, but still, it looks a little bit minimalistic to me.
In Europe you get your Prius on Michelin Premacy 195/55R16 V tyres. These rate up to 149 mph. Far too much for a Prius, but then again, I'm quite happy with that as one can be sure that there is some margin, even when you drive your fully loaded Prius at high speeds on the freeway when it's 105 degrees.
Your impression is right on. I think though the tire rating may have to do with speed limits in the USA.
Culliganman(Good rubber to the road)
Then why are other OEM tires sold in USA rated at S-112 mph,T-118 mph, U-124 mph, H-130 mph ( many sold), V-149 mph, Z- 149+ MpH and even some W- 168 mph. Thes top rating Y-186 mph is only OEMed on exotics.
Maybe the Prius tires and the recommended 85 mph limit are based on the anticipated driver demographics and the actual performance capabilities of the car. The higher mph tires usually return lower mpg.
Cheers,
MidCow
The max speed of the Prius II is only 100-106 or thereabouts so who cares? The Integrity’s are S rated at 112 mph. If someone would want to change out their Prius’ tires, they will more then likely lose FE as the Integrity is one of the lowest RR available in a large size tire. Traction wise they suck in the rain/snow but they are quiet, comfortable, long lasting, and have very LRR ratings. The Michelin MXV4 + are a good candidate for replacements as they are LRR as well and have better traction all around but they are not the best traction tire around either. I do not know if they come in a 185/65 R15 size but you could look it up
Good Luck
Wayne R. Gerdes
I fully agree. Wouldn't it be that part of the complaints about the handling of the Prius are caused by the type or tyres they put it on? I think the Prius handles quite OK, but then again, it's on Michelins and I don't have a F1 type driving style (I guess nobody who buys a Prius does).
I personally would certainly give up some MPG to get a better handling and more comfort. For instance, at the moment my Prius is on winter tyres. I don't take the risk to hit a pedestrian because my summer tyres would fail in the snow. For me, all your life's MPG gains wouldn't compensate for hurting somebody or getting an accident that could have been avoided.
Now I understand why the Hummer is so popular in the USA. It's one of the few cars that won't disappear in the potholes! <):-)
The only issue I have heard on the Prius handling is cross winds. I imagine the EU Prius has better braking with 4 wheel disk brakes.
PS
The popularity of big SUVs & PU trucks in the US and especially in CA is Safety. Other than rollover they are far safer than any of the sedans. Our CA roads have very few potholes. That is a condition caused mostly by rain, snow & freezing.
Weight based safety is only a relative factor. If we drive in Trailblazer and hit a Suburban, then we will be injured badly.
Real safety is in Seatbelts, Airbags, accident prevention mechanism like ABS, ESP, etc.
Of late, there is a 9K discount (which includes 0 % APR) on Suburbans.
About the safety: I think that it is more an IDEA that SUVs and truck are safer. If you look the IIHS statistics:
http://www.iihs.org/sr_ddr/sr3507_t1.htm
you will see that the safest cars are vans and stationwagons between 3500 and 4500 pounds (death rate of 38 per million). Even the heaviest SUV and pickups can't match that figure. I have always understood that SUV and pickups are superior in multi-vehicle crashes, because of their weight, but inferior in single-vehicle crashes and rollovers. This cancels the weight advantage.
Also look at this:
http://www.iihs.org/vehicle_ratings/ce/html/0110.htm
http://www.iihs.org/vehicle_ratings/ce/html/99009.htm
Doesn't look too good, does it?
However, in practive the facts do not matter. People will ignore facts and just buy a car because it makes them a feel safe. But in reality I think you are as safe in a Prius as in a SUV. In TOTAL, that is, of course not in a crash between a Prius and a Hummer.
In an accident, Hummer is safer than Prius.
But in a Gas Station, Prius is safe than Hummer.
I think the probability of Prius meeting Hummer in a Gas Station is much more.
I think Hummer sales have declined by around 8 % despite a SUT model being launched. Prius sales are increasing at a faster rate.
Please help me.
Culliganman(by the way...it happened to me too)
P.S. Ain't Technology Fun!! ha!ha!
Culliganman(A CAR FOR ALL SEASONS)
Culliganman(oil is $55.00 Gas is $2.09) go'n up
Well there I go again...telling the everyday Hummer jokes. My bumper sticker use to say..(picture of a screw next to OPEC.
Culliganman(Prius Is Good For Wallets)
Did you miss my point entirely? That is cubic feet, not square feet. If it is square feet, what is the cubic?
Culliganman(I've yet to see the specs in square Ft)
They can put a box like structure and claim the capacity in CUBIC Feet.
Is it a method to make people buy longer trucks. All means of efficiency shoud be promoted.
It is because pickup owners need to know how long their cargo can be. The classic measurement is how big a sheet of plywood can be and still fit in the bed.
The reason cubic is so important is that one needs floor space to place luggage. A Ford 500 has 21 cubic feet of cargo space. One would think "oh, that's only 5 cubic feet larger than the Prius", and one would be correct. But the space in the 500 has more square feet, and you can get more luggage back there. Cubic is very deceptive when discussing SUVs and hatchbacks, which rise vertically. One of the big problems I have with the Prius is that the cargo space is just too small length X width X depth, never mind the cubic (height).
I have similar issues with my CR-V. It has up to 40 cubic feet behind the rear seats (with the rear seat slid all the way forward). But if you compare it with a Ford Explorer, the Ford has a lot more space back there, even though it is not that much bigger in cubic volume. But 40 feet is a lot of cubic volume (as is 33 cubic feet with the rear seats slid all the way back). So I get by.
It is critical for all prospective buyers of any smaller car to check the carrying capacity of the cargo area. Take you child seats and stroller to the dealer.
Culliganman(a better mouse trap)
Pkg# 4 to get side impact plus stabilization
$795 for Platinum warranty (to 100,000 miles?)
$345 for road hazard (includes wheel replacement)
$895 pre-paid scheduled maintenance (through what mileage?)
We received a quoted "price break of $500" which made our "plain" Prius cost Out-the-Door to be dollars over $23,000 but I have not discussed these other items with the Washington, D.C., area dealer. Has someone bought all these in a single package and are the prices doable?
$27,309.77 which includes safety (sida air bags, stability) as well as cassette (in stereo).
We are in Virginia, just outside Washington, D.C.
Now (because I asked about warranty:
"The total O.T.D. with the 7Yr 100K platinum “0" deductible “TOYOTA” =
$29,001.02
you can use your Toyota warranty at any of the 1300 dealers in the USA.
You also may purchase that warranty at any Toyota dealer that sells that Platinum 0 deductible warranty."
In my reading I have noticed people have quoted as much as $2,200 for Platinum warranty.
Some have claimed $1,200 as "dealer cost" but some have paid (as little as) $795 for it by negotiating ("that is all I will pay").
Your opinion of what sales here has quoted?
The Platinum quotes were for 6 years and 7 years, each 150,000 miles. Should there (also) be a 10-year Platinum? If so, is there any reason they should not have quoted it for us?
We are wanting also to do a bicycle rack but they quoted about $560 including 3 hours of labor charge (to put it on).
I suspect this does not have the cassette of Pkg# 6 but is $2,661.58 less than the other offer, both read just this morning.
MSRP for $23,790.
Going rate (in this Area) is $500.00 off MSRP Making vehicle, (including Tax, Dealers Processing, etc.),
$24,391.95 OTD.
Platinum Warranty is for 7 years/100,00 miles and goes for
$1650.00 OTD and the
Pre-paid Maintenance, longest, is 4yrs/55,000
$695.00 OTD
So all total
$26,736.95
Do you put it inside the car?
Do you put two inside?
Roof rack? if so, which?
Rack that can be put on and taken off (our current one fits the back of our VW Golf 1992 4-door)?
Link:
http://www.fitzmall.com/carfind/resultsb.asp?Search=NEW&ID=038237&photo=TO051224&loc=LFT&m- all=GA&year=2005&mk_code=TO
Our other car is a 2002 prius, I can't remember how many miles are on it but we've been very happy with it.
(My teen-age son figured the screen problem in about 2 seconds and gave me the "gee you dumb mom look" only a teen-ager can give.)
We live near the top of a hill at about 1,000 feet. When we arrive home, the battery is usually two notches below full. As we drive down the hill, the battery charges up quickly (it's steep, so we drive on and about 1/2 way down it's fully charged. Now this suggests that we are wasting some potential energy. It would be nice if we could control the battery charge level so that it's not so close to full when we get home.
Coastaletech.com advertises a gadget that is supposed to allow the driver to select an "electric-only" mode for speed below 30mph. This would probably do the trick for us, but it prompts a few questions.
1. If not used carefully, can this gadget lead to a level of charge so low that it can damage the battery?
2. Do the electric motor and battery tolerate frequent use of the motor at full capacity?
3. Will the coastaletech gadget void the warranty?
4. Has anybody had any experience with coastaletech? A search on priusonline.com shows a few negative experiences, and none good.
5. Are there other solutions?
Thanks a lot!
Luigi
I don't live near the top of a hill, so maybe I ask a stupid question: can't you drive the last half a mile or so in EV mode? That will drain the battery to a lower level, so the next day you will have more room to store braking energy. Isn't this just a matter of pressing the EV button?
Crus'n in 6th,
MidCow
experience at the dealer was typical pressure sales experience. also, outside the hovering sales agents were making comments about people driving into the dealer... totally unprofessional in my opinion.
Edmunds, Kelley, and Toyota's websites should have this info.
http://www.kbb.com/kb/ki.dll/kw.kc.ncb?kbb.WA;977850;WA011&98660;sed&6;Toyota;2005%20Prius- &M40M8A2;;M40M8&&3&&nyrnc
And one bad experience at one dealer hardly would make me eager to buy from a private party...
Just got a Prius last Friday and am still confused about a few things
1. Is the bottom part of the hatchback window connected to the defroster? When I turned on the rear defroster, the top defogged fast, but the bottom did nothing.
2. I'm totally confused about the Consumption display. I drove today about 20 miles over 35 minutes. It began at about 25 mph (it always seems to start low), then jumped up to 50 ish, and at one time jumped to 75, then back to 50. Sometimes, the little car icons appeared (2 of them), other times, only a half of one. There seems to be no relation to MPGs and the icons. Can someone explain this?
3. Can you make the lights on the steering wheel brighter? I can hardly find them at night?
4. Is the MPG average accurate. I filled up today for the first time. My calculations said 37 MPG, but the display had me in the mid 40s.
5. Does the battery ever get fully charged. When I bought the car, it was in the blue zone. It usually gets to one green bar, and only one time have I seen it with 2 green bars. Is this OK?
6. Is there a way for the heat to come on without the compressor? I wind up 'unclicking' AC to save energy. It took me a while to realize there's nothing called 'heat' only 'a/c'
Thanks in advance for your help.
David
