I don't think there is a difference between the two, is there? IIRC the Malibu has an electronic start that is PCM controlled. When the key is turned to the start position the PCM engages the starter until RPMs come up sufficiently to consider the vehicle running or until a set amount of time elapses, whichever comes first. You can hold the key on start all day, but the starter is disengaged by the PCM when the engine is considered started or is shut off to prevent damage. I always start by breifly turning the key to start and then releasing.
I had these messages with the first Maxx too so I was not alarmed just curious as to what they meant. The service guys don't seem to know what they are either. Thank you for your help. This has only happened 3 or 4 times since I purchased the car in June.
It has a build date of 1/06/05.
Too bad, mine is pretty wacky. Try these things:
1. Fan speed on Auto, Level selector on Auto. Temp @ 60.
2. Feel the air coming out of the vents, note how fast it is going.
3. Turn the fan speed up to the highest setting. Air speeds up. In the manual and SI, it says that the air speed is supposed to be at high when both knobs are Auto and temp is at 60.
1. Fan speed anywhere but off or Auto. Level selector on Auto. Temp somewhere between 60 and 70. A/C off, fresh air.
2. Set fan speed to Auto.
3. Order 60 degrees. Unit doesn't turn on A/C, even though it is in fully automatic mode.
Thankfully I did not have to take it to the dealer although I am very happy with the work he has done so far. The new steering column works great and the car tracks straight and true. He also updated the software for my ECM and the intermittent no-start has never happened again. I did not even buy the car from him. I relocated from California to Kentucky and if anybody is looking for a good dealer try Wilson Brothers in Bardstown.
As far as the Key fob, I bought one also ~ $59 each..... (Total for key & fob=$105)
But I see the dealer has to program that separate. At $95/hr labor rate I'm going to shop around... I'm just a lil P. O' d and feel taked advantage of... that I have to pay for all the programming costs for a key fob I "just bought" to replace one that was stolen from me in the 1st place. (fyi -I was on Business on theTexas Gulf coast and my rental car was broke into... they got my belongings which included my home keys and these car keys/fob) D~
I'm on my 3rd tire rotation and it still tracks to the left at hi speeds. ANY Comments on a fix would be great?. At the price of Gas driving around for a qualified dealer is a pain. I think they wanrrant alignment for 12K only anyway. I've hit 13K now and seem ripped of with the last visit and No satidfaction at the dealer! D~
When you had the rotation, did the tire pull change at all? Even just a little bit?
my wife filled up her gas tank 3 days ago and today she realized she didn't tighten up the gas cap completely. today when she came home the "check engine" light symbol that looks like a little transmission came on. could this be because she didn't tighten the gas cap? how long should we wait usually to turn the car back on after tightening the gas cap to check to see if this fixed the problem?
we bought the car brand new, it has 17,000 miles on it now after 3 years of driving and she never had 1 problem with ti so far.
any help would be appreciated!
As long as your car is not shuttering, or performing differently, just sit back and enjoy the pretty orange glow for a day or two. (The following advice was given from a former Mazda 626 owner who's CEL came on a million times over the course of 7 years, and who's fellow Mazda owners often covered up their CEL with electrical tape.)
1. When reversing there is a grinding noise coming from the front left wheel well.
2. When reversing and shifting to drive the car pauses then jumps into drive runs fine briefly and then has problems shifting.
3. When the car starts the speedometer and tach go right up and fall and dashboard lights flash and car stops. This also happened when driving today. Car was driving fine all of sudden the car kind of paused above symptoms happened and the air bag light stayed on for a while then shut off.
Anybody have any ideas on these problems?
In the past I have replaced the brakes more than 5 times, have had issues with the A/C, all off the lights, turn signals, washer fluid line broke on the driver side, the trunk is not aligned properly, the trunk liner has come loose, the cassette player hasn't worked after the first year (which is a bummer as I listen to audio books), CD's get stuck in the player even after cleaning and gives a constant error message, takes forever to heat up in the winter, feels like a roller coaster ride in the back seat, shakes badly in the front area and has even stopped while driving over a bump in the road, ABS light comes on often, passenger side window control has come out of the door armrest, and the air registers stick in warm weather. The small price tag just wasn't worth the trouble. The car has 75,000 miles, I had better luck with my 1975 Malibu in 1988. :mad:
Bad grounding can cause all kinds of silly symptoms. For problem # 1, I would suggest that you look at your front rotors and pads.
So far...24 hours... and the car hasn't stuttered once.
well it is now almost 1 week and the constant check engine light is still on. i have filled up the gas tank once more and made sure the cap is tight. should i keep driving it because someone told me the light will go out, but it needs time. you had mentioned 5 starts and a 1-2 days, but i'm way over that.
let me know, thanks!
Bob
The one by Actron is called the PocketScan model CP9125. Even though you may not be able to repair the fault, you will at least know the direction in which the problem lies and be better informed when you take it in for repairs to a qualified person. You can order it directly from the Actron website.
I would be very leery of driving a car with a constant check engine light on and, it is bad advice to tell somebody to just keep on driving it.
have 40K on mine now...and no problems with the car at all....less this cover...and the rear window shades.....
As for "dealer fabric protection", they asked $500 for a package that wasn't guaranteed to resist any of the common stains. Noooo thanks.
From their home site just select the "Is your vehicle OnStar Equipped" topic.
Then select the "What kind of hardware does my OnStar-equipped vehicle have?" sidebar topic
From there the link to FAQ on the subject is pretty straightforward.
Sorry I didn't want to provide a direct link, not sure if we are supposed to do that.
Dianne in FL
2005 Chevy Malibu LS
Last 6 numbers on VIN 339653
You were a very early purchaser of the previous Malibu - that was first year for model.
I have worked on design for both that one and new model and am pleased you are a repeat customer
Date for your new vehicle is July 26, 2005. That is a very recent build because later that month was model changeover when they started building 2006 models.
Yours is the newest vehicle I have looked up for anyone here
There were many things I liked about my 1997 Malibu (including the color - dark cherry metallic aka PURPLE - LOL), but the fact that was it was the first model year was a bit of a headache. Overall, though, I was really happy with it and very comfortable driving it. So when it was time for a new car, I focused on another Malibu.
At the dealership I panicked a little over the price of the Malibu (not having bought a new car in 8 years) and ended up test driving a Cobalt as well. That sealed the deal for me on the Malibu! The Cobalt was poky (4 cylinder), and IMO the interior looked cheap with all that molded plastic.
Thanks again for looking up my new Malibu! FYI - it is Galaxy Silver Metallic.
Dianne in FL
If it is not installed in your vehicle at present, you are out of luck.
GPS Antenna, Cell Phone Antenna, Microphone, 3 OnStar Buttons in Mirror and the OnStar electronic module. These are located in various places in vehicle. Plus all the wiring that goes to each.
