Hybrid Tips Optimizing mileage
SylviaSylvia Member Posts: 1,636
edited March 2014 in Toyota
Driving tips for getting the most mileage out of each tank of gas.
«1345678
    motownusamotownusa Member Posts: 836
    I see complaint from some hybrid owners that they are not getting the advertised MPG from their cars. While others are getting better than the advertised MPG. How do you get the best possible MPG?
    Is not the highest, but the best in comparison.
    As anyone can plainly see the Prius hybrid design is not optimized for hwy MPG. The Prius design is optimized for city slow, stop and go driving.
    So the advantage of the design can be primarily shown by comparing city MPG figures with other cars of equivalent weight and loading capability.
    The only real advantage the Prius design has is gained via recharging the batteries during braking or coastdown.
    At a constant cruise speed on a level roadbed the batteries are not really used except to accelerate/(re-)gain speed and generally must be recharged using petro. Using petro to recharge the batteries results in an over-all net loss and therefore the cruise MPG advantage is non-existant.
    If one were willing to disconnect the batteries and forego the "SuperCharging" supplied by the batteries in hwy use I have no doubt the Prius hwy MPG would improve substantially.
    djasonwdjasonw Member Posts: 624
    I get 45-50 going 60-70 on the highway. Try doing that with a conventional 4 cyl car! What you say, makes absolutely no sense whatsoever!
    midnightcowboymidnightcowboy Member Posts: 1,978
    Djasonw,
    I think you are misreading what Wwest is saying. Wwest is saying that recharging the batteries while crusing is not really needed, because they are not being used normally during cruising. However in the current HSD design even during highway cruising the MG1 generator is contiually turing and contiunally charging batteries, that for the most part are probably alreay fully charge. What Wwest is saying and I very much agree that the continual charging is not needed and that the Prius would get even better highway mileage if it could be disabled. However because of the very nature of the CVT planetary differential transmission design, MG1 can not be disabled.
    I never got the impression that Wwest was criticizing the mileage the Prius obtained or was he comparing it to other cars.
    Let's say you could disable the MG1 and were able to then obtain an EPA rating of 60/55 wouldn't that 4 mpg gain on the highway be better ?
    YMMV,
    MidCow
    usbseawolf2000usbseawolf2000 Member Posts: 759
    "At a constant cruise speed on a level roadbed the batteries are not really used except to accelerate/(re-)gain speed and generally must be recharged using petro"
    Why does HSD need to recharge if it can route the electricity straight to MG2? The battery is recharged sometimes to power A/C, stereo, etc...
    "If one were willing to disconnect the batteries and forego the "SuperCharging" supplied by the batteries in hwy use I have no doubt the Prius hwy MPG would improve substantially."
    Incorrect premise comes to the wrong conclusion.
    Dennis
    "However because of the very nature of the CVT planetary differential transmission design, MG1 can not be disabled.
    The question is why would you want to? There is very little instances when MG1 should not be spinning. Most of the time MG1 needs to be spinning foward or backward to adjust optimal ICE output at a given speed. Stopping MG1 would mean ICE has to adjust RPM for a given speed, which would either reduce efficiency or power!
    Dennis
    tempusvntempusvn Member Posts: 119
    Exactly.
    The MG spinning is part of the CVT-Like function of the planetary gearset.
    The way this is used to manage engine RPM/Load is one of the most mis-understood nuances of the HSD Design.
    Let me try to give a generic example, with made up numbers.
    The key is that the Atkinson Cycle engine is VERY efficient when it's in the right speed/load band, and less efficient when it's not.
    One of the big reasons for normal ICE inefficiency is the need for the engine to work in a broad RPM band. Using a CVT you can keep the engine in it's sweet spot longer, which is a good thing.
    So, the planetary gearset, using the MG, tries to keep the engine at it's prime speed/load point. That's cool, just like any CVT.
    The real key to the added HSD efficiency is, when the MG is doing this, it can ALSO make use of the extra energy.
    Made Up Example.
    Let's say the ICE is at 27% efficiency at 3000 RPM and 37% efficiency at 4000RPM.
    You could run it at 3000RPM, and get X mileage.
    But, with the MG in the equation, it can let the ICE run at 4000 RPM, and take off the extra energy in the form of generated electricity.
    The ICE can generate more energy than you need for immediate propulsion for the same fuel expenditure when it's running in the sweet spot, and the MG can recapture that extra efficiency for use later.
    If you couldn't do that, you would be forced to run the engine at a less efficient load.
    If need be, the MG can assist to 'spend' some of the energy it's accumulated then go back to generating.
    It's truely ingenious, and makes the best use of the Atkinson engine characteristics (extreme efficiency, but only in a narrow power band).
    That's one of the reasons it's also ideal for diesels, they have the same sort of power band tendencies that the Atkinson engines do.
    Why, because the Honda IMA design provides much better highway mileage. The HSD system while giving excellent city mpg, does not do as well as it could on the highway. Every design has it benefits and it determents.
    If the HSD were designed so that the MG1 could be disabled when not needed then highway mpg would improve.
    Think about how the solenoid on a convetional ICE start works. It would be a very easy modification to provide solenod engagement/diengagement of MG1 and get the highway mileage estimate up to 55 mpg A FOUR(4) MPG IMPROVEMENT ;
    But then you would add another failure component to the HSD transmission .
    YMMV,
    MidCow
    P.S. _ I find it very interesting that such statements as "especially for those that don't have engineering and/or automotive educations" come from those that obviously don't have engineering, mathematical or automotive educations.
    P.S.S. - I appreciate your true "engineering" viewpoint.
    Perhaps I am confused but the electric motor is constantly called on during highway driving. If the car was continually charging I'd have FULL green. The last time I got full green was when I had to descend a HUGE hill and had to ride the brake a bit in the sharp turns leading to the bottom. If as he says that the engine is creating a charge that is not needed, I certainly am not seeing that when I look at the display.
    "Why, because the Honda IMA design provides much better highway mileage."
    Based on what? Smaller and lighter HCH(1.3L) manual tranny has the same 51 MPG EPA highway as Prius(1.5L).
    Ever thought the other way around? Could it be that IMA is inefficient in the city? Could it be because Honda IMA(10kw) can only capture 1/5 regenerative energy of Prius(50KW)? Could it be that HCH does not take much advantage of electric superior efficiency at slow speed?
    "If the HSD were designed so that the MG1 could be disabled when not needed then highway mpg would improve."
    How can it be? What is your explanation? I'll give you a counter example. At 70mph, if you disable/stop MG1, the ICE has to spin 3,000 RPM instead of ICE 1,000 RPM with MG1 -6,500 RPM. You tell me if ICE 1,000 RPM is more efficient or at 3,000 RPM.
    Dennis
    "At 70mph, if you disable/stop MG1, the ICE has to spin 3,000 RPM instead of ICE 1,000 RPM with MG1 -6,500 RPM. You tell me if ICE 1,000 RPM is more efficient or at 3,000 RPM."
    I didn't mean to contradict Tempusvn's point. Another possible case at 70mph is ICE at 5,000 RPM with MG1 7500 RPM. The point is that, MG1 can adjust to whatever RPM that is the most suitable for the ICE at any given instance. MG1 at 0 RPM(disabled) is just one out of 20,000(-10,000 to +10,000) different possibilities.
    Dennis
    "Made Up Example.
    Let's say the ICE is at 27% efficiency at 3000 RPM and 37% efficiency at 4000RPM."
    In reality, Atkinson ICE efficient band is very wide, about 80% is near peak efficiency.
    "That's one of the reasons it's also ideal for diesels, they have the same sort of power band tendencies that the Atkinson engines do."
    Diesel engines do have narrow RPM range but their torque curves are not very flat. For Atkinson flat torque, see below. Also, because diesel engines do not have spark plug, shut down/restart of heavier cylinder diesel ICE would be far more difficult. Another reason gasoline and electric synergize more than diesel with electric.
    Dennis
    "However in the current HSD design even during highway cruising the MG1 generator is contiually turing and contiunally charging batteries, that for the most part are probably alreay fully charge."
    Just needed to address that. It will never happen in Prius or other HSD cars. Overcharging the battery will damage it and shorten the life. As stated before, the electricity can also be routed to another motor and put it to work, instead of the battery.
    Dennis
    quasar4quasar4 Member Posts: 110
    --Funny.....14 posts and not a single driving tip on maximizing fuel economy. Sorry to end the streak, but eh...
    --Tip #1: Anticipate!
    a) Redlights: I'll never understand people who race to the next stoplight only to sit there oblivious to the fact that the light has turned green. If you see a red light ahead, try coasting or timing it to keep up your momentum. The Prius coasts rather nicely.
    b) Heavy traffic: If I'm stuck crawling in heavy traffic, I prefer slow & steady as opposed to stop & go. People see a little daylight in the traffic and they punch the gas only to have to hit the brake again seconds later. Studies have shown that this only worsens the bottleneck by creating a lag effect that ripples down the line.
    c) Hills: If you see a hill coming up, accelerate before you get to the hill rather than when you're on the hill. I find this works for bicycles too :)
    d) Other Drivers: Don't tailgate. Otherwise you're letting the guy ahead of you dictate your driving style (not to mention your blood pressure). A buffer zone lets you speed up when it's most efficient for you to do so, or remain coasting at a constant speed while he slows down, makes a turn, fumbles with his cell phone, etc..
    Results...51 mpg on 5200 miles. Love that Prius!
    Great suggestions which I follow as well. What I find is that when allowing a gap (greater than a few car lengths) in between cars causes anger by folks who think you're leaving too much space. What happens? They fill the gap which causes you to have to slow down again. EVERY day I go to work (no kidding) there are three or four cars on the side of the road with a trooper because they had a minor pileup because they were EACH following too closely.
    Thanks for the suggestion. Do you do much highway driving with your Prius at say 55 to 75 mph? What kind of mileage do you get on the highway. Seems like a lot of the people's highway MPG is lower than the EPA's estimate of 50 mpg.
    ft1000ft1000 Member Posts: 4
    Maybee it's just my car but I do a fair amount of highway milage and I average between 52 and 55 MPG.
    I just got back from a trip to NYC, total round trip of 306 miles with 4 adults in the car. I set the cruise control at 65 and by the time I arrived at NY the display had 54.5 MPG.
    On the return I set the cruise control at 70 and the display at the end of the trip shows 53.2
    I have 8777 miles on the car and my mileage just gets better with every passing month.
    My record is from Harrisburg PA to Philadelphia where I got 57.8 MPG. My speed was between 65 and 70 but I did have some tail wind.
    It's my short trips that bring down my mileage. My average is 8777 miles and 180.9 gallons of gas for lifetime MPG of 48.518.
    I heard that cruise control helps a lot also. You can practice dead-band acceleration, which is pretty much a proven technique as discussed in yahoo groups. It basically means, when you accelerate, avoid the arrow to and from the battery on the display screen. You want to avoid engine horsepower going into the battery instead of the wheels, especially during acceleration. You would rather charge the battery with regen-braking. Battery in Prius is a good thing but you loose about 17% of the energy when you get it back(83% efficient).
    Using battery as little as possible will also prolong the life of the battery since you are saving the recharge cycles.
    Dennis
    --Yup it's hard to keep a gap without some bonehead squeezing in to jockey for position. It's ironic that the aggressive driver hell-bent on getting to his destination in the least amount of time, actually causes the very traffic jams that slow him and everyone else down.
    --Most of my 5200 miles (guessing about 80%) are at highway speeds. Half of the miles were on a trip from the East Coast to the Midwest. Not sure why other people can't duplicate the 50 mpg number. On that trip I just set the cruise control on 70 and the car got an average of 50.3 mpg over 2000 miles (and that included driving through the Appalachian Mountains of PA). Other than that trip, most of my miles come from short trips to work (8 miles with 6 of them on the interstate). I'm sure my mileage would be much higher if I had a longer commute and more sub-highway speed driving. In those situations, I usually get 55-60 mpg.
    Beginning from a stop
    Accelerate as gradually as practically possible.
    --This would seem to make sense, but the efficiency of the engine varies with load (or so I'm told). With this said, it might actually be better to accelerate smoothly and briskly up to cruising speed --kind of a happy medium between a snail's pace and a jackrabbits.
    --Well it sure looks like you put a lot of thought into it. I would suggest, however, that most people would not consider 0-50 in 31 seconds to be brisk acceleration. You'll need a few more data points on the curve like 0-50 in 15 seconds and 0-50 in 20 seconds, etc., to convince me that you have an accurate picture of where the sweet spot is.
    --Also, I noticed you didn't reach 50 mph over the 1/2 mile course with your slow acceleration test. A car traveling at 50 mph vs. one traveling at 42 mph has more momentum. To be fair, your tests should all have reached the 1/2 mile mark at the same speed, say 40 mph.
    --Furthermore, I'm not sure that what's good for the Civic in terms of acceleration is necessarily good for the Prius given their different propulsion systems. A Prius accelerating briskly to 40 mph and then holding that speed over a flat half mile may very well run on battery alone without engine assist to pull the vehicle forward. In that case, the consumption monitor would max out at 99.9 mpg for the better part of the test course.
    --I suppose you'll have to let your gas tank do the voting as to which technique is better.
    --Here's a simple idea to save fuel: instead of filling the tank to the brim, fill it up 1/2 way to reduce the weight of the vehicle by about 40 lbs (assuming a 12 gallon tank). Not that 40 lbs is going to make or break one's fuel economy, but eh, every little bit helps.
    bobbrown1bobbrown1 Member Posts: 22
    Filling only half way to save weight? Why not a quarter way, or less, to save more weight? It seems like this would be wasteful, as you would have to go out of your way to refill more often. How about unscrewing the antenna to save on drag? This economizing can be obsessive, where does it end?
    The key effect on milage is air resistance:
    Even though in jest, every thing that can be done to lower the CD ( Coefficient of Drag) will imporve the mileage. The jest was someone recommneded removing the antenna ; actually this would help but only ever so slightly. Some hybrids such as the Prius already have a low CD ; the Prius is only 0.26
    (1) Keep your car washed and waxed. This will help a lot more.
    (2) Use rain-x on your windshield.
    (3) Keep you speed a low as you can stand. Air resistance goes up squared compared to you speed. That means if you double( 2 times) your speed , your wind resistance will quadruple (4 times).
    (4) buy a manual shift car if you have a choice: you will get better economy and better acceleration. For best economy up-shift to the next gear at the lowest RPM that does not tax or lug the engine, usually around 1,500-2,000 rpm.
    (4) Is the most dramtic improvement. But only 10% of the people shift and some cars don't come with a manual transmission.
    (3) Is probably the most Controllable, dramatic improvement. If you can keep you miles per hour at 55 you will save a lot of gas; remember when 55 mph was the national speed limit and all car speedometers had 55 mph highlighted in a different color ?
    YMMV,
    MidCow
    --Big whoop: so you fill up once every 250+ miles rather than once every 500 miles. Where do you live that you have to go out of your way to find a gas station? If you have trouble getting to one of those elusive oases, then by all means fill 'er up. It's not a mandate --simply a suggestion for those eager to eke out every last drop of fuel efficiency.
    --Go ahead, knock yourself out. It's a free country.
    This economizing can be obsessive where does it end?
    --It ends where you want it to end. That's called freedom of choice. If someone wants to save a gallon (or an eye-dropper) of gas/year by reducing vehicle weight, by removing the antenna, by washing off the wind resistive bird doo-doo, etc., what do I care? Doesn't hurt me. Doesn't upset me. In fact, if everyone saved just a little, the world would save hundreds of millions of gallons a year. And that's good for everybody ('cept maybe OPEC).
    how about removing the seats that ar enot being used?
    --Ahhh, so that's where the Honda Insight designers got the idea of removing the rear seats. :)
    Great idea! Here's another: If possible, choose to register your car in a state that only requires a rear license plate.
    I forgot to mention, above suggestion would save both on weight and drag.
    spdracrspdracr Member Posts: 3
    1) if you are traveling over 40 mph for a sustained period of time, and it is quite hot outside, don't open up all the windows to cool down the car, because it creates too much wind drag. you're better off using the a/c at that point.
    2) if you are driving a honda civic hybrid, pay attention as to how the auto stop works. you must first exceed 20 mph for it to be ready to work, and then go through a slew of requirements before it actually activates. when you are at a stop, the rev counter drops to 0, and auto stop flashes a green dot, don't push the brake down all the way to the floor or anywhere close to it, because sufficient brake vacuum pressure is one of the requirements for the auto stop feature to work. stay in gear and don't take your foot off the brake - once you do, the engine will start back up again.
    3) when braking, start braking much much earlier than when you are in a normal gasoline car. just tap the brake down, barely holding it down, and the regenerative braking should kick in, giving the full charging status. this way, you maximize how much power you can recover from excess kinetic energy.
    4) when accelerating on a non or low incline, don't floor it. try to keep the gas pedal reasonably down - you might even want to hold the car at the "between" point where the electric motor is neither assisting, nor the batteries are charging either - only the gas engine is working.
    5) if you have time to spare, don't speed. what i usually do is leave earlier. if i have to travel on the highway, then i'll take my time, reaching 65 on the uphills, and coasting down them to around 55, then accelerating to 65 again - this way i cycle the battery's charge. some may argue that holding the car at a constant 65 with the cruise control will yield better mileage - but whatever works with you. i find that cruise control drains the battery more than it recharges(i.e. assists during uphills, but doesn't charge much during downhills), but whatever floats your boat.
    6) this only applies to the civic hybrid. if its hot and you're sitting in traffic, or stop and go, don't use the a/c because..that just uses more gas. open the windows, or the fan or both and you'll save some gas.
    7) unload your car. don't carry unnecessary things, because extra weight, although not much of a factor in gas mileage unless you carry reaLLY heavy things, can compromise handling, stopping time/distance, acceleration, etc as well.
    8) if there are multiple routes to a place where you go to often (i.e. highway or local roads), use your trip computer to record the mpg of each route (3x each route if you want to be really sure). then, factor in the distance of each route - is the mpg difference make a difference if it is actually a longer distance? decide, and then stick to that route.
    rfruthrfruth Member Posts: 630
    Good tips expect you say auto stop requires a slew of requirements. I wouldn't call it a slew, also mentioned is to not push the brake down all the way to the floor - think I know what you mean (don't use up all the vacuum pressure) but if anyone hybrid or not thinks they can don't try to drive the car as there is a serious problem.
    blueiedgodblueiedgod Member Posts: 2,798
    How about not taking highways at all? Hybrids are at its best on local roads, and almost all highways have back roads that can be taken to avoid highways.
    mirthmirth Member Posts: 1,212
    Do you get a lot of road rage from other drivers when you vary your speed between 65 and 55? Don't know about your area, but in Detroit 65 MPH is considered little old lady speed, much less 55. Plus, most people want to cruise at a steady speed and would become very annoyed with having someone in front of them constantly slowing down and then speeding up. Honestly, this is not a knock on you but I'd be pretty apprehensive driving like that on the highway.
    I hope they are staying in the right lane, and drive in the off hours, lol.
    mistermemisterme Member Posts: 407
    Regarding speed and other drivers, this is my daily commute:
    Leave the house at 4:30PM and begin my 45mile drive into the city of Atlanta. 90% of the traffic is headed out of the city.
    I travel an extremely hilly 45 & 50MPH limit country road for 20 miles to the interstate.
    Speed on this road is between 43 and about 60.
    If there is someone behind me at a good distance nicely driving along then fine. If an aggressive driver gets behind then I find a place to let pass without wrecking my MPG such as hilltop or extended turning lane. I know where all these places are.
    I could jump right onto the same freeway 2 miles from my house and gain 10 minutes but loose 10MPG.
    If I MUST use this the limit is 70. I travel in the right lane going 62-75, about the same as large trucks.
    So 20 miles from my house I jump on the 65 limit freeway for 7 miles.
    MPG at this point is typically about 53MPG.
    The rest of the trip is variable down hill.
    On the freeway I'm always in the right lane except on occasion to pass a slow driver. Speed is 60-70MPH.
    After about 7 miles the limit changes to 55.
    At this point my average MPG is about 56.
    I reduce speed to 53-60, still occasionally passing slow drivers. (They usually have cruise control set to speed limit)
    43 miles from my home I exit into one of the worst Atlanta side traffic at 5:10PM.
    I park in my space just after 5:30 and the trip typically averages 61 to 65MPG.
    I leave work at 2AM and take the same route home.
    MPG typically averages 59-63MPG upon arrival.
    Since I've been maximizing my MPG I've only encountered 3 pushy drivers which I let by. But it also seemed that anybody who got in their way was victim as well.
    Given these results, is my MPG typical? NO. Is it possible and duplicatable? Yes, by some.
    I think if you drove a regular Civic HX the same way, you would have achieved the same MPG's
    I don't beleive so.
    The fantastic MPG I acheive is not due to one or two things but a series. Driving style is a major player but the combo of fuel saving designs in the car play the other part.
    Remember I have a CVT, so the HX would also have to be an AT.
    HX auto is also CVT. It has very similar VTEC-E engine, with a little more displacement. I think the auto version is rated a 48 mpg. It is only available as coupe, and is quite cheap, it is priced between the DX coupe and LX coupe.
    "The Civic HX Coupe is an excellent combination of performance and efficiency. Its 1.7-liter, 117-hp VTEC® lean-burn engine is one of the most fuel-efficient around. With its standard manual transmission, the HX Coupe gets an incredible 36 mpg city/44 mpg highway. You also get power mirrors and door locks, an AM/FM/CD audio system with 4 speakers, cruise control and a tachometer. There's an available continuously variable transmission (CVT) and, like all Civics, the HX is rated as an Ultra-Low-Emission Vehicle (ULEV).
    Manual Transmission: $13,710.00
    Manual Transmission with Front Side Airbags: $13,960.00
    Continuously Variable Transmission (CVT): $14,710.00
    Continuously Variable Transmission (CVT) with Front Side Airbags: $14,960.00"
    Sounds like a great car!
    I'm sure with careful driving you can get well past the 44MPG but not better than 60.
    It still lacks an electric assist among other MPG devices and only seats 2. If my needs were a coup I'd go for an Insight.
    I know how much more expensive the Insight is but I'm not talking a cheap ride here: mainly fuel consumption.
    Many Insight owners drive carefully and get better than 90MPG.
    BTW I made a funny HCH/Prius animation, Crank the volume! Don't miss it:
    http://www.steve-dez.us/3d/content/hybrid/movie/pj2.wmv
    (Windows Media 3.6MB)
    http://www.steve-dez.us/3d/content/hybrid/movie/pj2.mpg
    (MPEG 6mb)
    Actually, the HX is a 4 seater, and comfortable one too for 4 average (read not overwight) adults. There is almost no difference in leg/head room from the 4 door civic and 2 door civic. While Insight is a coupe as well, it is strictly a 2 seater as it lacks rear seats completely.
    Don't forget that HX weighs less than HCH.
    Don't take me wrong, I embrace the technology. But, I think Hybrid technology is still the wrong way to go. If we insist on having internal combustion engines, I think running a diesel on used corn oil or biodiesel is a better alternative. Either of the fuels are renewable. Hybrids only relocate the pollution to other areas. To make the NiMH batteries you have to use some sort of energy, as well as they are a recycling nightmare. To charge the batteries you have to use up energy as well. It is not like the battiries charge them selves.
    Yes, raising corn to make corn oil and ethanol requires energy as well, but these are renewable sources. This is in effect solar energy, CO2 in the air is converted into strach by the plants while releasing O2 with help of solar energy, and use water. Then we harvest the corn or soy or cotton or whatever Crisco is made of, use the product for consumtion or animal feed, and then take the by product, oil, and use it to run cars. Same with ethanol, starch source is processed by smiple bacteria and then refined into ethanol. Once again, it is renewable and uses free energy of the sun.
    Can you imagine how well off farmers will be if we switched to renewable sources of energy. And how uncomfortable oil tycoons will be.
    john1701ajohn1701a Member Posts: 1,897
    How is that any different from the lead-acid battery recycling that takes place everyday... except for the fact that the NiMH modules are smaller and easier to handle?
    NON-ISSUE! That energy is already accounted for in the gas.
    Ethanol programs are already in place in some of the Midwest and people are already using that ethanol in their vehicles. Imagination is not necessary.
    JOHN
    Lead can be melted and acid recovered, but the point is that we will be adding to the problem.
    The energy is not free, yes, regenerative energy is "cheaper", but it is not the major portion of the recharging cycle. Here is the scenario, you get the new hybrid, and lets say it is not charged. The car will run in "gasoline only" mode to charge the batteries. So, you have the gas engine lugging the car and dead batteries around and you are telling me that this energy is free? No, it is not.
    The benefit of Hybrid comes from higher efficiency of electric motor (about 80%), as oppposed to Internal combustion engine's efficiency (30-45%). So, theoretically, pure elctric cars would benefit the world more, but problem is that you still have to charge the batteries, which requires energy. Electricity has to be produced at the power plant. Hydroelectric is probably the most environmentally safe way. But, unfortunatley alot of electricity is still produced by burning coal or tar. By charging batteries at home, you are just relocating the pollution to where the power plant is.
    JOHN
    I think you are referring to the 10% ethanol Gasahol used in some states. I am not aware of vehicles running on pure ethanol at this point.
    ron1ron1 Member Posts: 4
    Since the compressor is electrically run, I was surprised to see how much a difference it makes in the displays calculation of MPG. Trying to run a test on a level stretch of road, turning the AC alone (just the compressor, leaving the other settings of climate alone) the compressor accounts for about 4-5 MPG!!
    Now I am often riding without the compressor on and the venting is still cool. Seems to be cooler air than other cars venting- my imagination or is this because, perhaps a smaller engine, less heat, vents are further away from engine compartment, etc?
    Ron
    Ah, that explains it. You are under a MISCONCEPTION.
    The forced type of charging only applies to mild hybrids.
    There is NO SUCH THING as "gasoline only" mode in a full hybrid. 100% of the time the engine is providing thrust to the wheels it is also creating electricity. So there is ALWAYS a benefit from the greater efficiency of electric, enough to provide an overall reduced loss. In other words, it is still more efficient than a gas engine alone.
    JOHN
    Also, don't forget that the engine uses an "Atkinson-Miller" cycle rather than "Otto" plus it has an artifically low redline. So naturally it is more efficient.
    JOHN
    "So naturally it is more efficient"
    If HSD is vastly more efficient than IMA then why are a large number of actual hybrid owners of all types reporting that Prius is about the same MPG given it's more complex than IMA, and pushing about the same size and weight vehicle?
    http://www.greenhybrid.com/compare/mileage/index.php
    "more" doesn't translate to "vastly" no matter how you want to look at it. Try again.
    And since the comparison I contributed to was between HSD and traditional, you're interjection with IMA requires some explanation...
    Nonetheless, I find the combining Manual & CVT data (the link you provided) very very misleading for your discussion of IMA verses HSD, since IMA-Manual verses IMA-CVT is an extreme in itself.
    Choose a topic.
    JOHN
    "And since the comparison I contributed to was between HSD and traditional, you're interjection with IMA requires some explanation"
    Sorry John, I miss-spoke there.
    What I meant was that I don't think there is great differences in actual MPG efficiency between the two.....given that IMA and HSD uses the different cycles indicated.
    And you are right, the database mentioned gives a diversified comparison.
    Not according to my energy display. Sometimes I see the ICE just powering the wheels, no arrow to the battery.
    Ron
    Did I mention battery? No.
    I said "creating electricity".
    Notice that other arrow. It's the one I keep pointing out as the a key difference between mild & full hybrids. Shocking, eh?
    JOHN
