Thanks for the info, mike. I was using numbers shared on ScoobyMods, I think those are shop hours so I suppose you could ask a Subaru dealer to try to meet that estimate.
I've seen TV shows where they press and pack bearings and it's a bit beyond what I'd do myself at home.
Ed- That's the first instance I've heard of bearings going bad on a 2003 or newer Forester. And two at the same time? Yikes! My 04 recently passed the 60k mark so I guess I'll keep my fingers crossed that your's was an isolated incident.
1) I have a 2001 Forester S with 215-60-16 tires. I need to replace them and I am thinking about 215-65-16 for a taller tire. Anyone try this. I dont think the 215-60-16 fill the wheel wells very well.
2) I had a riped cv boot, had a local shop swap the front axle shaft with an aftermarket pos. Now I get a vibration. He swaped it again for the same aftermarket pos and I still get the vibration. ANy experience this with aftermarket shafts.
Of course it is possible that something else is wrong but the symptom appeared immediately after the CV shaft swap. The shudder or vibration is at low speed and typically tires show problems at higher speed. My tires are in poor condition and will swap them and see if it makes a difference.
You mention you swapped oy may CV shafts with aftermarket and had no issue. Was that on all wheel drives Subaru's or regular FWD cars.
Msera I work for an Automotive parts warehouse, and one of our customers, a repair facility ran into the same exact problem with a 99 Forester. The customer of mine blames it on the new axles that we get from China, that might be true in this circumstance, but I couldn't confirm it. Most parts stores now sell these axles and are getting away from rebuilts. He bought a new one from the dealer and the vibration went away. Most of these new axles are coming out of the same place in china, so you might want to find a supplier that can get you a rebuilt axle or go to the dealer and get a new one. For the most part these new Chinese axle have been good.
I bought a set of Kumho Ecsta ASX 235/45R17s several months ago. They fit but just barely. I got them from Discount Tires (who guaranteed they would fit). No complaints so far. They offer a firm ride (as you would expect) but not uncomfortably so.
Hi, your expert opinion needed. We are considering used Subaru Forester 2003 to 2005, how reliable it is? What are the common problems to expect? Head gasket? Bearings? - please be specific. Which one is better in terms of reliability turbo or non-turbo? Thank you for your help!
Wheel bearings were of a new design for 2003, and have been a lot better.
The revised head gaskets arrived in 2002, IIRC. You should be fine there, too.
Inspect the head and valve cover gaskets, plus the front and rear main seals for oil leaks, as you should for any used car you shop for, really. Drive in a figure 8 with the windows open and the radio off, listen for any strange driveline noises.
The good news is with AWD any problem will make itself obvious, you should hear or feel it.
"Side curtains weren't added until the current model but side impact protection for the front passengers was added as part of the 2003 update. "
Thanks - by 'side impact protection' do you mean side airbags in the seats? That's how the 2003-2007 models are listed in the MS CarPoint comparison chart.
"The curtains (new for 2009) added protection for the rear seats, though. "
Given that I may somehow permanently lower the rear seat to prevent my 16-year old from having more than one passenger, I don't mind the lack of curtains :P
I left my 2005 X parked in the airport for 5 weeks. The valet person brought it to the reception area and turned the engine off. It's a good thing he left the window down when he did this because all the doors all of a sudden locked. When I started the car, the cruise light was blinking and the check engine light stayed on. Since then, the cruise control does not work, the cruise light blinks and the check engine light stays on. Any ideas as to what may be wrong here? I am trying to save myself the diagnostic fee.
I wonder if the battery went too low, and that caused all this?
After a long drive, to be sure the battery is fully charged, I would reset the ECU, to give yourself a clean slate.
Just disconnect the negative battery terminal, wait 20 minutes. Have your key fob handy, reconnect the battery but be ready to lock/unlock with your keyless a couple of times to stop the flashing lights and beeping.
At least that gives you a clean slate to start with.
I had similar symptoms a few years ago when the alternator went bad on my 2001 Forester. All the warning lights went crazy. After the alternator was replaced, all was back to normal.
I tried it. However, when I reconnected the negative there were no flashing lights or beeping. The battery had a slight difficulty starting but it did. I was very pleased to see the blinking cruise and the check engine lights disappear and that the cruise control worked fine all day that day. The following day however (yesterday) the blinking cruise and the check engine lights came back on. Any guesses on this? Do I need a new battery?
We had exactly the same problem. Disconnected and reconnected the battery and filled the tank with premium fuel and made sure that the fuel cap clicked twice, as suggested in threads on-line and by Subaru. After about a week or so the light would always come back on. We finally took it into a mechanic who ran the CEL code and discovered that we had a really dirty spark plug. Has been running great the last 3 weeks.
A while back I recall that Kate used a bottle of HEET to remove water contamination from the fuel lines, and that helped. Maybe he just got a bum tank of gas.
I recently purchased a 2005 forester ll bean edition it is supposed to have a windshield deicer but I have no electric grids at the bottom only a black metal band at the top that appears to run around the entire windshield it this the deicer?
Well, I found out that Autozone scans codes for free. Their scanner generated three reports which, in sum, they are: Report 1) the catalyst system efficiency for bank 1 (which I guess is cylinder 1) is below threshold for the current engine operating conditions. As one of the probable causes, the report says that it could be a defective catalytic converter. Reports 2) and 3) are the same: that a misfire has occurred in cylinders #3 and #4, for which a probable cause is faulty spark plugs.
I plan to replace all four spark plugs and hope that this will do it. Is there anything else that you think I should be doing? Many thanks for all your help with this.
Sounds familiar, I had a misfire that turned out to be a hungry chipmunk chewing up my spark plug wires! :surprise:
Try the plugs first. Next in line would be the wires. Lastly, the ignition coil. Don't worry, the coil is just $80 and there is only one, plus it's very, very easy to replace.
My '09 has AWP and my wipers don't rest on the heating element thing; they sit above it...don't seem to be able to move them either. Wondering if it's something I should mention at the next service?
Assuming the wiper blades rest somewhere close to the heating elements, I wouldn't worry about it. The heating elements will warm a fairly large area of glass.
That photo is just a sample, I don't think it's a Subaru.
They will melt the whole area around them. Also, if you're pushing slush beneath the wipers, that's just where you want them - to melt the stuff that piles up there.
The problem was not fixed in post-2002 Foresters. My 2003 2.5X has 119,000 miles on it, and I was told today the burning oil smell is due to the dreaded head gasket issue.
I had the 'coolant conditioner" added every time coolant was changed. Obviously this didn't do the trick.
I understand SOA has a warranty but just for pre-2003 models and under 100,000 miles.
Despite that, would it still be worth calling SOA to see if they would help pay the $1,400 expense for a known defect?
Also, is this an inherent problem with boxer engines, where fuel/oil and other corrosives are in longer contact with the head gasket, eventually leading to the problem?
That plus there are 2 heads, while most 4 cylinders have only 1. That makes the problem twice as likely.
At 119k, though, all bets are off. You're at double the powertrain warranty's mileage. I'd be surprised if they helped, but call 800-SUBARU3 and ask, can't hurt I suppose. Be friendly, you get more flies with honey.
Just traded in my 03 Forester X with 187,000 miles on it. I felt it would go for another 100,000 but the check engine light came on about 27,000 miles ago and I ran it till it needed inspection in Oct. I did not want to put $1300.00 into a catalytic converter. I felt the car was a true work horse but did nothing exceptionally well. It was very reliable. My one big complaint about the car was its handling in snow. I felt the car would never get stuck from a dead stop, but would slide off the road in the snow. The more gas I gave it the more it would slide to the side with the road banking. It was annoying watching small civics and corrolas blow by me in bad weather. The car was a great hauler and I am going to miss it.
When my Geolanders were worn down pretty low with 35K on my xt, I definitely noticed a side to side loss in traction and a pronounced plow in snow or low traction conditions. I soon after put on some Kumho all season tires and my Subie was back in action with superior traction. I don't think it had anything to do with the Brand of tire, they were just new with plenty of tread. Also, Rotating your tires is a must.
I am sure we all know the little trick of applying the e-brake to help your car rotate around the corner if you start to plow. I do it occassionaly but can't recommend it, seeing that it depends on speed, conditions, experience, Etc...
Wondering if 2005 was a good or bad year for the forester? I am seriously considering buying the 05 LL Bean edition with 62K miles - should i go for it?
I think it depends more on the individual vehicle, and the care it has received, but we have had 2 01s, an 02, and currently have an 05 Bean and an 06 Premium. The Bean is my wife's and she loves it. The only problem she had was with the moonroof track, and everything but the glass got replaced under warranty.
We haven't had a bad Forester yet. My wife's cousin has an 02, and my brother has an 08. Both of those have been very good vehicles too. There have also been a couple of Legacys around the family. Our extended family has never had a bad Subaru.
We've gone and bought a 2007 base Forester. It appears to be in good shape. What might you recommend (besides what's in the manual) to make sure it stays that way? It's our first Subaru.
-mike
Hopefully these new wheel bearings fix this issue.
-Frank
-mike
Thanks...
-mike
Funny thing was Tire Rack said they would not fit. Discount Tire Direct said they would, so they sold me the tires.
They never rubbed, but it was very close.
I had aftermarket rims with a different offset, though.
If you do this, just measure it closely. The tightest clearance is at the rear strut base. Make sure there is room there for a taller tire.
It works out to about 11mm taller tire, so a tad less than half an inch taller.
Check there, and also check the front tire through full lock steering, left and right. That's also close.
There's not much room, but 65 series tires aren't that much taller, either.
-Frank
The difference is the S' bumper is painted body color, the L's was unpainted.
You can attach it with 3M two-side tape.
-Frank
Yes, sorry I didn't clarify that. The front seat mounted airbags also provide head protection.
-Frank
Len
Those can read and clear the codes, so we know more.
My guess is the original windshield broke and they replaced it with a cheap one, instead of one with the heater element.
If you bought it from a dealer I would take it back and complain.
That should fix it, let's hope.
-Frank
Thanks for that. It's pretty nice having knowledgeable people to ask advice for advice! Especially when you're not a car guy...
I had snow tires on a 98 Forester and it was virtually unstoppable.
On worn touring tires, well, let's just say it was easy to coerce it to drift on demand.
