I have a 2005 V6, AWD. I bought the car used with just 10000 miles on it. I have maintained it according to the owner's manual and have not abuse it in any shape or form. During an oil change at 62000 miles, the mechanic told me that there is a transmission fluid leak. I did some research on my own and found out that there is a TSB out for the transmission fluid leak on this model/vin. I can forward a copy of the TSB if anyone wishes to have it. If you read the bulletin, it becomes quite clear that the there is a faulty transmission seal that is prone to failure and Toyota has recently changed the seal in newer models. They are essentially hoping that no one will have this problem and even if they do, it would be outside the warranty period, as in my case! To make the long story short, took the car back to the dealer, they looked at it and sure enough is the seal that is mentioned in the TSB that has failed. The dealer quoted me a price of $1300 to have it fixed. The repair would have been covered under the 60K power train warranty but since my car now has 63K, I am basically SOL. I just called Toyota last night to ask for their assistance but not getting my hopes up. I think it is unfair for a company to know about a problem and not stand behind their product. I will keep you posted on what I hear back from Toyota.
In the mean time, if your 2004-2006 highlander is under 60K, please check for this leak problem. Make sure you document it and have stupid Toyota pay for this. Otherwise, get ready to fork up some dough soon as the warranty expires. Toyota should be ashamed of their business practices.
Just which seal are we talking about here..??
And what is the severity of the leak?
If you lose more than a quart between engine oil changes then maybe there is cause to worry, otherwise....
Looked up the TSB and the seal involved has to do with the right front axle/halfshaft bearing within the PTO, Power Take-Off, for the rear driveline.
With only 63,000 miles I would contact the Toyoat factory rep for a warranty repair.
The TSB calls for the entire engine, transaxle, and PTO/transfer to be pulled from the vehicle as a unit and then the PTO separated for work on the bench.
From looking at the TSB and then looking at the underside of my '01 AWD RX300 it's pretty obvious to me that this bearing seal can easily be replaced absent even removing the PTO.
Your dealer may be looking for an easy $1300.00 for $200 in labor and a $10 part.
My reading of the TSB leaves me with the implication that your leak is the result of improper assembly at the factory. In that case I would REALLY lean on the Toyota factory rep for full compensation.
I wrote a letter to Toyota corporate after my attempts to address the issue over the phone failed. Any suggestions about getting in touch with factory reps?
The only ones I find are at alldata.com and they charge a fee.
I have a 2006 Highlander but seem to be having the same problem. Thanks for the info. posted but if you have a full TSB, that would be helpful. I'm almost at 60,000 miles and want to be ready if Toyota gives me trouble.
Everyone have your transmission checked before 60K!!
Drivetrain - Fluid Leaks From Transfer Case Vent
TRANSMISSION & CLUTCH
TC008-07
Title:
TRANSMISSION FLUID OR GEAR OIL
LEAK FROM TRANSFER CASE VENT
Models:
'04 - '06 Highlander (AWD) & Sienna (AWD)
June 11, 2007
Introduction
Some 2004 - 2006 model year AWD (4WD) Highlander or Sienna vehicles may display a transmission fluid or gear oil leak from a vent on the right side of the transfer case. The leak is from the transfer RH (right-hand) bearing retainer No. 2 oil seal. Production improvements have been implemented to prevent this condition from occurring. Follow the repair procedure below to replace the RH bearing retainer No. 2 oil seal assembly.
Applicable Vehicles
^ 2004 - 2006 model year Highlander (AWD) and Sienna (AWD) vehicles produced BEFORE the Production Change Effective VINs shown below.
Production Change Information
Warranty Information
Applicable Warranty*:
This repair is covered under the Toyota Powertrain Warranty. This warranty is in effect for 60 months or 60,000 miles, whichever occurs first, from the vehicle's in-service date.
* Warranty application is limited to correction of a problem based upon a customer's specific complaint.
Parts Information
Required Tools & Material
Required SSTs
Components
Copyright © 2008 ALLDATA LLC
Terms of Use
http://www.carsurvey.org/viewcomments_review_54210.html
steveray319@msn.com
I ended up paying 50%, $695.95 at the dealer to fix the issue. It was a poor fit of the sealer. I believe Toyota is well aware of the issue and applied the fix for a newer model. I have 70K miles on it, ad may be the one of the few got into the trouble earlier. Toyota flat denied to pay in full, nor process the recall. If you have 2004-2006 Highlander, please be aware. They will get you for $2000 price tag that should been a recall item.
Today I took a closer look and the fluid is transmission fluid, the leak only appears to be coming from the noted hose, but is most likely leaking onto that hose.
Anyway, it's a tight working area and impossible for me to see for sure where the leak is coming from, but it appears to be in the area of the cooler box (if that's what that is). This box I am referring to is about 1 foot or a little longer below the drivers side headlights.
A few questions:
1) Is anyone familiar with this area of the car and the problem?
2) Am I looking at major repair? I would attempt to do it, but I can't get to the area to see what I am doing. I did consider taking out the wheel well cover, but not sure if that will give me access.
3) Is there a free repair manual around here so I can see what exactly is this box?
I took the battery out and the battery tray to get a better look today and it's either coming from the tube/hose that connects the cooler to the transmission or coming from somewhere on the box.
After I reinstalled the battery and added some fluid I started up the car and ran it for a few minutes. When I turned it off there were large drops of fluid dripping down at a rate of a sizable drop every 3 to 5 seconds.
I'm puzzled.
Depending on your comfort level, replacing the hose may be simple. Or not.
I thought about removing the wheel well shield and accessing it from there, but I have to make sure that it actually can be seen and reached from that approach. It appears that two lines are going to this "mini cooler", one from the transmission and one from the radiator.
I would attempt to do it myself, but it is a timing thing since my wife needs the car for work. Tomorrow she will use my son's car, but I don't have the time to fix it. So now my concern is getting ripped off by a mechanic.
Anyway, thanks for your input. I wish I could locate a diagram of this part of the car, but I've come up empty.
Now I find out that you can't get the transmission fluid at any of the local stores, you have to buy it through Toyota. So it will have to sit until tomorrow.
Thanks for the help, it saved me a lot of money - I owe all of you a beer.
glad we can help. Pay it forward.
Straight to the point. My wife's 04 Highlander, 64,000 miles. Transfer case leak.
Dealer wanted full price to fix. I did my research just on a hunch, if you will, and found this forum on the subject. I took all the info and the ALL DATA post, wrote down and got on the phone. with my new ammo locked and loaded, I went to work on the dealer. A hour later got a call. We decided to pay for half the repair.
There is a obvious design problem here. To all Highlander owners. Don't settle with the dealer with out a fight. The forum saved me a bunch of money !
Thanks Guy's !
Now my question is if or more likely when it will happen again ????????
Pete
Tried not using overdrive, but problem persists. This is my first problem with the HL. I always get my HL serviced at Toyota dealer at 5000 miles intervals.
Dealer says the trans needs to be replaced. In California, the price is over $4500 for the "new" trans. Dealer will give me a 10% discount on parts and labor.
Any thoughts?
But new are having very serious heating problems on the AT.
It occurs only on highway. Since I live in a country with so many mountains the car get the AT over temp. alarm.
Yesterday I had to stop 4 times on the road in order to get it cold and remain driving, at only 2,000 rpm. Very slowly return to home.
I have sent the car to the Toyota shop al least 4 times in the last year to have them service the transmissión.
I´m planning to make the service in an independent shop using an equivalent ATF oil
Any help from the experience you have had? .
Oscar
The transmission was replaced with a "rebuilt trans". The transmission case is a used case, but all of the internal parts are new. I think that this is a better solution than using AAMCO, which only replaces the worn parts and the price is about the same.
Regarding your extender warranty, doesn't that end after 100,000 miles?
I sent an e-mail to the local Toyota dealer to thank the service manager for customer service. I also asked them to forward the note about the transmission problem to the regional Toyota service representative.
I have not received any logical explanation fro toyota. This week I will try by repalcing the oil with a Mobil oil compatible with the ATF Type IV. I hope tihis works because I am not in the mood to spend too much money on that car.
The used ones have a 90 day warranty, and apparently 90% of them work just fine.
I went with the used.
http://www-odi.nhtsa.dot.gov/cars/problems/recalls/
I don't know if it will help, but maybe Toyota will read the complaint.
If there is a mechanic out there please reply.I have the transmission down in parts looking for torn parts, unit has less than 65000 miles.Mechanic is replacing parts but will not say exactly what is the problem. :lemon
I filed a complaint with the Department of Transportation at:
I am sure that Toyota will read the complaint or if there are enough problems with the Toyota transmission, the Feds will force them to correct the problem. The complaints could also lead to class action law suits. This is a safety hazard that could lead to numerous car accidents due to slipping and poorly shifting automatic transmission.
So don't get :mad:
And you think Toyota might pay attention when..??
Well, sacto, i'm not sure, but since I only have about 50,000 miles now, that won't be a problem!! The only problem is that I might have bought another Highlander, in a year or two, but now I'm not so sure. Is this tran problem continuing in recent and current models??
What we found inside tranny was and burnt out oil, no viscosity and all blackened.
I used Valvoline synthetic blend ATF which comlies with Type IV.
Unit now no problem with tranny.
I´m having VSC fault but that is related to ABS after replacing timing belt.
Best regards and good luck.
Oscar
I wonder if Toyota has a similar problem with the transmission oil on HL? I've always had my HL served at a Toyota dealer, based upon the recommended maintenance schedules. Does anyone know when newer (than 2003) HL are supposed to have their transmission oil changed?
I have heard that this was later revised to say that the ATF condition should be checked at every oil change and only drained and flushed if required.
The HL uses the same transaxle.
As always now I have a VSC light on on the dashboard. It´s suppose to be a calibration procedure what is missing.
I´ll let you all know when we perform it.
Best regards
OScar
I have a 2002 V6 Highlander, 3.0L and for the last 6 months I have a strange problem with my SUV.
When decelerating from over 60Km\h to ~10Km\h, around 20Km\h I feel a shift shock. It seems to happen when it tries to downshift from 2nd gear to the first one. But this happens only when driving over 60Km\h and it's not all the time.
We checked the brakes, calipers, but it wasn't that.
Reading this thread someone was mentioning about a TSB mentioning a re-programing of the ECM.
Before taking my Highlander to the nearest dealer I test drove it again and came up with these conclusions:
- it happens only when I am over 60Km\h, in the 4th gear;
- it does not happen every single time I decelerate;
- if am in the 4th gear and I kill the over-drive before or when starting to slow down, so I manually force the transmission into the 3rd gear it won't give me this shift shock when reaching 20Km\h (when downshifting from 2nd to 1st gear);
- it does not happen if I put in Neutral any time before reaching 20Km\h.
Yesterday I took the car to Toyota dealer and I told them about the issue and that re-programing the ECM might fix the problem. They could not reproduce the noise and at the end they scanned the Engine Control Module and the Transmission Control Module.
They reprogrammed the ECM only and, weird, the service manager told me "it takes one week for the computer to relearn what it has to do". If I program a computer, I teach the computer what to do.
I did not understand his explanation. Can anyone confirm these words to me, please?
Since yesterday I had 4 milder shift shocks so I am not sure if reprogramming the ECM helped or not.
Any previous experience?
I replaced the ATF with Valvoline semi sinth ATF and the over heating and all their simptoms dissapeared.
Now I have a VSC alarm and is what I´m working on. As soon as I have the solution, I will share with you all.
Oscar
