Plymouth/Neon Stereo Issues
I have a few problems. 1 My front two speakers in my 1998 Plymouth Neon do not work. 2. I get shocked everytime I get out of my car. 3. my battery is being drained somehow. My thinking is that all the problems are in some way linked but I'm not a machanic or have no knowledge of how or what to fix. What do you think my problem is.
Can anyone help me?
Or prehaps tell me how i can find out which wire is which?
Thank you very much.
I've lost sound to both front speakers and the driver's side rear speaker, I also get a shock when I get out of the car, but I don't have the battery drain problem. Have you installed a new stereo recently? Almost sounds like a short somewhere that's running down the charge in the battery and building up in the body, possible the reason you've lost sound to the speakers and for the shocks. A charge in the metal body that doesn't ground properly may be discharging into other systems like the stereo or your hand. As a temp solution try purchasing one of those grounding strips. They're pretty cheap and it just bolts to the chasis under the rear bumper and lets any charge that may build up in the body ground out.
Any thoughts?
