4" vs 5" Exhaust
I am looking at changing the exhaust on my '99 F350 Super Duty with the 7.3 Powerstroke. I have seen and read about 4" exhausts and 5" exhausts. Does anyone have any experience with either or both. Is one better than the other?
My truck is primarily used for too and from work during the week (when I am not in Iraq). I do pull a steel three horse trailer on weekends....about 9,000lbs. So, when I get back, I am looking for the best exhaust to put on the truck and potentially an exhaust break. Recommendations anyone?
Thanks! I am still researching. I do understand that changing the exhaust also means I should change the intake as well.....a whole package deal. I will keep the thread going as I find out more information. I am trying to find every article I can to find an answer.
Thanks again and take care!
kcram - Pickups Host
let me Explain why we reccomend these three products the stock exhaust system is so restricted with the Tight bends muffler and cat,when you install a aftermarket exhaust there straight through, the muffler is the same. so with no restrictions your motor can get the hot gas out as fast as the turbo & motor is pumping it out.and the result is lower egts
better throttle response and more HP & torque. but first you got to get COOL Fresh air in the the motor,to really get the most out of your exhaust system. so with a free flow intake system. you will get more air in with out any restrictions at all,cooler air and as you know cooler air has more oxygen molecules so bigger and cleaner combustion adds up to more fuel mileage,cleaner burn and more POWER! so with more air going in more air going out. adds up to better,smoother running,more mpg,HP,torque
now this is where the tuner comes into play.now we got air to her and we can get it out.
it's time to custom tune the pcm to get the motor to run in the sweet spot.with alittle timing,fuel,pulse width,icp pressure and air to fuel mixture,with custom tuning we also tune the trans to hold the added hp and tq.so with these upgrades you should get 20 to 23 hwy and 16 to 18 city.more towing power,so you can get that big load up those hills with no problems and more performanced so you can play,4x4 driving,racing,sled pulling or what ever you what to do with your ford powerstroke.your truck will be a lot of fun to drive and not that old boring slug. the six postion chip is tuned only for you and the way you drive.
