Toyota 4Runner: Ignition Systems
Hey guys,
I have a '01 4runner,I put 31" all-terrains on,
and my mileage went down the crapper! (not that it was that good to begin with) But can anyone tell me of a ignition system thats out there? I've done some serching and found nothing. Ive already maxed out my air intake, and I'm gonna eventually get the exauhst but I'd like to focus on the ignition
First of all I'd suggest cleaning the MAS. (Mass Air Flow Sensor) This is a sensor located in the flex air intake hose.
Now a word of CAUTION! This is a delicate sensor. It has fine wires inside, picture a screen on your house windows and 1 or 2 fine wire sensors. DO NOT clean these sensors with brake cleaner, carb cleaner or alcohol!
You can pick up some electrical contact cleaner which is suitable for this job at a local auto parts store. Spray the wire area well and allow it to air dry before you re-assemble it. Air dry is another important thing to remember, you really don't want to touch the inside of the sensor!
While you have the air intake hose off, take some carb cleaner and soak the throttle plate. Let it sit a bit and then open the throttle plate and wipe out the disolved residue with a clean shop rag. Using the rag, spray some carb cleaner on it and finish wiping the throttle plate and adjoining area till it's clean. Of course you do the above with the engine off!
These are some very inexpensive fixes that should be done every couple years depending on the mileage you put on. They will cure a lot of drivability problems...and possibly the problems you have except for the ignition signal. You'll have to see if that code clears itself after you do the above.
Good luck to you!
Thanks, rcob
Any ideas?
SUVs and Smart Shopper
