Toyota Tacoma Suspension and Steering
I am considering buying another tacoma. Must be a double cab, 4x4, automatic, and want the Sport Fabric interior. I drove a short bed offroad version, but did not like the ride compared to some other brand of trucks. The dealer did not have any LB to test drive. Did anyone purhcase the LB or Sport version over the SB Offroad version, due to the ride? Will there be a noticable difference? I realize I can step up to the Tundra.
I've test driven the Taco 06 Sport TRD (short bed), Off Road TRD (short bed) and standard truck (long bed. I've read the earlier forum that debates which package rode smoothest and it seemed many had different opinions. My experience suggested they all rode on the rough side. Here's my question...for those of you that own this truck and felt it rode rough. Did you get used to it?
I'll beat some of you to the punch on a potential suggestion, yes, I am in fact a big [non-permissible content removed]. But this [non-permissible content removed] tends to own vehicles for 10 years+ and I'm trying to determine if I can live with the ride. I owned a 1978 Toyota 4x4 and can't seem to remember it riding quite this bumpy, but perhaps I did just get used to it?
Also, if any of you found any solutions in making your Taco ride smoother I'd be really interested to learn of your discoveries.
Here's where I could use some clarity...I'm not sure I understand the relationship with balancing the tires and a bouncy ride. It's not a vibration we were experiencing. Of the 3 trucks drove, mostly on smooth CA Freeways, they all were fine on super flat surfaces, but when we went over a bump of any nature I'd look in the review mirror and see my wife and 2 year old bouncing up and down in the second row seat. Given it's a pickup with lighter weight in the back I realize you are going to get some of this, but the hopping was taking just going over the separation cracks on the freeway. Maybe the lower air pressure could help wiht this?
Thanks again for your input!
So I’m not sure what you’re experiencing rough ride wise, but both I and my daughter (in the back seat) are very pleased with the ride of the new Taco. I have both front and back tires inflated to 30psi, for what that is worth.
Good luck with your search.
#7283 of 7360 Re: TRD O/R with 4x2? [] by demoncleaner Aug 30, 2006 (9:59 am)
Bookmark | Reply | E-mail Msg
Replying to: unknown (Aug 29, 2006 5:18 pm)
Wow this discussion got people heated.
I have a 4wd. Its great for those that need it. Its only used for off-road and snow traction. How many miles do you 4wd owners have IN 4wd? seriously. (I have just under 1000 miles in 21 months, I consider that alot)
Off-road, I'm surprised myself how far I can got without using 4wd. If your not mud bogging Prerunner is a great choice for light off-roading. You still have the clearance.
Snow, well I have 4wd and will be the first to tell you, its about the tires, not the drivetrain. I run snow tires in winter, and often find myself on packed roads still in 2wd. Braking and cornering are the same, only acclerating espeically up hills and tracking (back end not coming around) are better in 4wd.
If given the choice of going out in a snowstorm in a prerunner (with LSD rear) and snow tires, or a 4wd with stock tires, I'd take the prerunner.
In the end if you really don't need 4wd, then your saving $2500 bucks off the price, more maintence, 250 lbs, and gallon of gas every fill-up.
If I didn't live in a hilly lake-effect snow area, and find myself out before the plows, I'd have a prerunner.
Replies to this message:
• gandalf1 (Aug 30, 2006 3:16 pm)
• cactusone (Aug 30, 2006 3:56 pm)
• gandalf1 (Aug 31, 2006 1:25 pm)
• woof (Oct 09, 2006 4:31 pm)
What size tires do you have?
Marcus
http://www.TacomaWorld.com
kcram - Pickups Host
Is it an engine backfire, a loose motor / transmission mount, or a Torque convert shudder?
I took my truck to the dealership and they heard the backfire (noise) and they said the computer did not register anything wrong with the motor or transmission. I ask them to talk to the District Toyota Tech Rep. The dealership told me the Toyota Rep had not experienced the problem before and when they (meaning the dealership) diagnose the problem, to tell him the prognoses. The dealership then informed me that if they can not diagnose the problem then they want me to drive the truck until the problem gets worse. I then ask is Toyota going to fix the problem at their expense if it’s a drive train problem. They told me it depends if I am within 60k. My other question is this:
Is this Standard Operating Procedure (SOP) for Toyota on a problem they can not diagnose? Is this how a company that boast number one in customer service and satisfaction handles a problem?
Note all service has been done per their guide, none missed. This problem started after the 40K service. Also my speedometer reads 5 mph fast and they said this is normal and within tolerance. Honda fixed the speedometer problems on their cars.
By the way, what might be your next vehicle?
I know it will affect the ride but will sacrifice that for a little less "squat".
I have the TRD Package w/ gas shocks.
Absolutely love the Truck, my only beef is wish it had rear discs, oh well - class leader in stopping distance w/o rear discs and w/ ABS, even better than some sports cars w/ 4whl ABS discs!
I went to Kaltire for an alignment, and they said they had to replace the steering rack because it wouldn't hold the alignment. That helped for a week or so.
I returned to Kaltire again and they said that they had to adjust the alignment again and asked me if I had hit a curb and I had not. Right after I drove it away it actually felt worse than before. So i took it back the next day and they switched the front two tires, which helped for about a week.
Fed up with Kaltire I took it to Toyota and they did a 4-wheel alignment and said that Kaltire missed adjusting a Tow-in. But even after that it still pulled to the right!
I talked to Toyota that day and they said it could be a bad batch of tires or there may be a frame problem. I did a carfax on the vehicle and it came out clean.
Any ideas/opinions of the problem?
I recently bought a 2008 Toyota Tacoma access cab TRD sport. Today on the Beltway 8 feater road a cop pulled right out in front of me and forced me off the road to avoid a collision (after breaking to about 15-20MPH). It was a pretty rough ride but after comming to a stop about 30 feet from the road the cop came over to make sure I was ok and to apologize. I was pretty mad but after getting back in the truck and driving I was amazed that nothing seemed to be off. Visual inspection showed not scuff or anything on either of the front 2 tires or rims. There was no sway left or right and no vibration (i even took it up to about 90mph to see). There is about a 1 degree left tilt in the steering wheel while it is going straight but i don't remember if it was like that previously. Am I being completely paranoid (brand new truck) or do I have reason to be worried?
I was under the impression that no vehicle was made to take curbs like this (hit curb at about a 30 degree run (from road parallel)) with left front first the right front after. I guess my question is "How rugged are the TRD sport suspensions?". Should I take this in for a suspension check just to be sure?
David
Like you, the steering wheel was just slightly off, so I took it to a suspension/alignment specialty shop. Just needed a minor correction and nothing was bent or out of spec. Was just fine after that. I say get the front end checked just so you're sure nothing was bent.
What else should I try? It's using almost double the amount of fuel it takes in winter yet runs fine and has normal amount of power.
i have a question about my tacoma 4 door 2001 truck.
it seems that it recently developed a very strange problem, and i am worried
that the transmission is going out (scary thought). there are some events
that happened that caused the problem. i went driving up the mountain with
5 kids and another adult, car was loaded. it worked all good, but going down the breaks overheated and smoked... pretty badly. i stopped and waited for them to cool off, but when i started driving again i realized the
breaks are not working too wel, i guess the break fluid boiled and created
a bubble. desperately trying to stop i pulled on the hand break ( going about
5 mph on somewhat level road ) and that didnt work so i pushed the tranny to park out of panic, it clicked a few times but didnt help, eventually i shifted
down to 2nd and low gear and managed to stop the car. i didnt have a problem described below for q few days...but i been noticing the problem gotten worse... going uphill, especially, the car starts to jerk around as if something is slipping inside. yet, when on low gear this problem isnt so bad or even noticible. i also notcied that if i turn off the overdrive it helps the
problem going uphill. anyone here may have a clue what this might be? i'd grately appreciate since i dont have a lot of funds to take it to dealer or expensive mechanic.
one of my friends recommended to try to plug the vacuum tube that gives power breaks the juice, and see if problem goes away then its the vacuum chamber got screwed up with this break incidence. another friend recommended flushing transmission fluid and replacing filter. but i did look into the transmission fluid color looks red, and not burned.
i will be checking this forum to see if anyone replied.
