Nissan 300ZX Care and Maintenance
Hi all!! im about to purchase a '92 or '93 300ZX. i absolutely love the car!! so im very excited. but im thinking what is the maintainance like? because the car wasnt made after '95.... are getting the spare parts hard? maintainance difficult? what kind of things should i check for before buying this car?
I'll appreciate all the help i can get!!!
I have a 94 and a shop that loves working on it..
Some things to watch for, if you got a convertible parts are almost impossible to get. The front end shock struts will cost you, I had mine replaced for about $700.
Check for engine noises, hard starts, and if the cars cuts off and stalls.
If you smell oil, or see oil coming out around the tailpipes beware!
Check to see if any lights come on, while you are inside the car with the gauges.
Check the clutch, steering, and the brakes well, to make sure they work properly.
Check to see if a maintenace schedule, has been done on the car aas well.
You can get cheaper car parts for them, at the autowharehouse.com.
They sell genuine parts at half the price, and they ship them out quickly.
I own a 1985 nissan 300zx non turbo coupe 2 plus 2.
I also own a 1994 twin turbo coupe with many upgrades.
They are really great cars to have.
That being said it's 23 years old with 156K miles and was treated less than great by it's prior owners. I figured I'd tell you all about an online store i used that had great parts availability and some of the best prices I've found yet - beats autowarehouse and those others I'd been using.
I got my front brake disc's, wheel bearings and grease seals - brand new shipped to my house in 3 days for about $100. The place is call (AUTOHAUSAZ.COM). It's a good place to get OEM parts.
I also just found an 86 2+2 5 speed for $700 that runs and drives - figure I'll pick that up and restore it.
1. Syphon out all the old gass I can.
2. Remove spark plugs.
3. Using an oil can, put some oil in the clyinders.
4. Using Jumper cables, turn the engine over a fiew revolutions to get oil into the cylinders.
5. Put in some new gas in the tank.
While the jumper cables are connected determine if the fuel pump is running. If it is, procede to #6
6. Change engine oil and filter.
7. Clean and or change intake filter and air box..
8. Check to see if there is spark. If so install new more modern and efficient spark plugs.
9. Install a new heavy duty battery.
10. Attempt to start the car and let idol, do not rev the engine. Let it run untill warm.
11. turn off engine.
12. Drain and replace engine coolent.
13. Replace tires. They are dry and have cracked side side walls where the tires had gone flat.
14. Change transmission fluid.
15. After a couple of hundred miles change oil again.
16. go through systems to determine if all systems are functional.
( Repair and or replace parts as needed as plan evolves.)
( Replace engine drive belts.)
Then off to the body shop for a paint job.
I had a newer Z than this some years ago. I tried using full synthetic engine oil and where it never used oil between changes it started using oil and I had to return to nonsynthetic oil to correct the problem.
I am looking for any usefull advise in this reencarnation. Thank you. The Beach Bum
I'm not sure if anyone's had a similar problem, but me and my Z have been through a lot together, after the car sat around for a fair time while I replaced the motor it fails to start. I've gotten my A/T rebuilt and i bought a motor that was in working condition, that matches, and put the both back in even though it did sit around for about a year during all this tuning and such. To the best of my knowledge there is either something not matching up with the computer that triggers the inhibitor switch, or the security system just doesn't want this new engine. If anyone knows a way to work with the computer that could be explained to me, or anyone who has had a similar problem tell me how they fixed it i would be overjoyed. I'm thinking of just working out the kinks in the wiring that let the security system work if i don't figure something out soon.
I look online and the injector are different but are the connectors from the wiring harness to the injector the same?
Its not a ticking sound like a hydraulic lifter makes but a dinging sound like a bell. Nothing like a warning light shows up so would like to know if anyone out there has
any ideas?
