Toyota 4Runner Towing
Thinking about buying a 2006 4Runner, but want to make sure it can pull my 2000lbs pontoon boat. Any pros/cons to the towing capabilities of the 4Runner??
My question - I know the V8 is rated at 7000# but can the 4Runner really pull a travel trailer with a GVW of around 5000# well? What other vehicle should I consider?
I cringe at driving a Tahoe - don't like quality of American cars - especially paying that much money for a car with an interior STILL behind about 10 years - even though they recently re-designed the whole thing.
HELP!!!!!
here's there website: www.keystone-outback.com The model I am leaning toward is the 21RS. The 23RS is nice too but lacks the bike storage area - instead it has a double bed with a twin bunk on top in the same space.
check them out - might be something you like.
I've upgraded to a Denali as a tow vehicle and will end up with a lightweight travel trailer that will max out at 6440#.
For full control, best towing and safety you really only want to tow at 75% of your max. Being your max is 5000#'s you only should tow 3750#. Weight is weight - doesn't matter if it's a horse or a travel trailer. with your trailer and 2 horses you are 2000#'s OVER your tow weight. Not good for your car or for us on the road with you.
My opinion - buy a truck for towing the horse trailer and 2 horses. My friends tows her 2 horses and trailer with a Lincoln Navigator and it tows it with ease. They are actually looking into buying a smaller car for everyday use thus allowing to keep the trailer hooked up to the Navigator and they won't have to hook/unhook daily. Just load the horses and go.
You can do the opposite. Find a truck to tow the horses, keep the trailer hooked up and use your 4Runner for everyday driving. Also look into a good weight distributing hitch - such as the Reese dual cam, Equalizer or, if you have the money, a Hensley (though with the right truck that one could be overkill with just a horse trailer)
check out the following website to help you understand the whole towing/weight/safety issue. It deals with Travel Trailers but info would be the same for horse trailer:
www.rvtowingtips.com
http://www.rvtowingtips.com/how-long.htm
Please note the 4Runner comes standard with a hitch - but it is not weight distributing! The entire hitch weight rests on the rear axle. To overcome this you need to buy either an "equalizer" or "Hensley" hitch. You can do a search. These hitches put the weight of the trailer on all axles. That means both axles of the tow vehicle and both axles of the trailer. (Assuming a dual axle trailer). And the tow vehicle will stay level if installed correctly.
It's complicated... read up on it. But DO NOT consider the weight of the trailer alone! The length must be considered.
I have a '05 4Runner w/the XREAS suspension and tow a 21 foot trailer (about 5,000 lbs.) with an "Equalizer" brand weight distributing hitch. IT tows OK - still some sway due to the 109.5" wheelbase. A "Hensley" hitch is better.. but costs about 3K. It would allow a slightly longer trailer to be towed.
Good luck!
My concern is the gas mileage. Without the trailer it gets 18 - 20 mpg on the highway, but once I put the trailer on it immediatly drops to 9 - 10 mpg. Uphill, downhill, fast or slow does not matter; it is as if someone flipped a switch to low mpg mode. Once I remove the trailer, it takes about 30 miles of driving, and then the mileage goes back to normal. I even checked the computer when filling up and it is accurate.
I would expect some drop in mileage, but not this much, and not all the time. Any idea on what is going on and does this seem normal? Anyone else check their mileage when towing?
So, it seems that pulling about the same weight, our miles per gallon are the same.
It also seems that those who tow with Suburbans, get slightly less 8 to 9 miles per gallon.
I guess if you play...ya gotta pay!
I tow w/ an '05 Sport w/the V8 (2WD) (with the equalizer as well) and wouldn't want to tow anything longer than what I tow.
You will not find anything different in terms of safety until you get in a severe sway situation. The 25 foot plus length of your trailer will be the "tail" wagging the "dog".
Good luck!
But all this being said - the wheel base is SHORT at 109.5". The information I have learned (and I did extensive research) is that you can safely tow about 21 feet. Anything more than this and it is the "tail" wagging the "dog". And I have an "equalizer brand" WD hich!
Ran in to significant cross winds coming back from Palm Springs, Ca this weekend. Even in a full-size truck you would have been pushed around. In my 4Runner towing a 21 foot trailer it was downright scary!
That's a surface area effect; the greater the area, the greater the force of the wind! You do have to be careful.
I am interested in buying a V8 4WD 4Runner, but I am concerned about the rear suspension. I don't want the rear of the truck to sink when I hitch it up. Years ago I used to haul the same trailer with a GMC Yukon and it SANK when hitched up! I hated towing with the Yukon, so I bought the full sized truck.
Any advice from people who tow with their 4Runners is much appreciated!
You can search the net for The Equalizer, Reese, and Hensley hitches.
You can only safely tow a trailer that is nolonger than 21-23feet to be on the safe side. The 109.5" wheelbase of the 4Runner is a factor.
You can expect no more than 10mpg in normal conditons towing.
Personally, the Suburbans get the same mpg as the 4Runner V8. They even do better on the highway (when not towing) than the 4Runner due to cylinder deactivation.
I persoanlly would not buy another 4Runner for towing purposes. Even with a WD hitch, you get the "tail wagging the dog" when a semi truck passes or in a cross wind.
You must have a good weight-distributing hitch. Make sure you get one with your trailer. If you buy a V6 4Runner, make sure the factory hitch can handle a WD hitch. I heard they cannot.
I agree - I would be afraid that some of these "Ultra Lite" trailers would fall apart during off road use.
GOOD LUCK!!
I have a 2003 4Runner that I want to use for towing...will be towing boat and trailer which weighs about 3,200.
The 4Runner did not come with the transmission cooler installed. Is it okay to haul the boat without having a tranny cooler installed.
jbrew
I have recently purchased a 2007 2WD V8 to tow my ultra light travel trailer. Had the maiden voyage this week. It sure isn't the old F150, but overall, not bad. We did have a goofy experience, though. The VSC and TRAC lights came one when I accelerated to get on the highway. I am assuming this means these functions were shut down (probably due to the anti-sway hitch). Being a 2WD, there is no on/off switch for this. Once we turned off the car, the lights went out. No other problems unhitched. Anyone have an experience like this? This appears to be the only place on the internet talking about 4 runners and towing.
Peace, Dennis
They went off when I shut down the motor.
I believe it has something to do with the sensors located on the truck for the computer that controls these devices.
I think the WD hitch in certain situations puts more pressure on the SUV (perhaps) on one side causing them to come on.
Just my guess. I am not worried about it.
But verify that figure. My hitch weight is around 500 pounds. A little on the heavy side for 21 foot trailer I pull with my V8 4Runner.
Make sure you have a good weight-distributing hitch.(Hensley, pull-rite, or equalizer, etc.) And make sure it is most of all set up correctly.
Well, it isn't the F150, but overall, it did well. It was a bit windy here in MN, and I found it pays to keep your hands on the wheel on the 2 lanes when trucks are passing, but I never felt unsafe. The VSC/TRAC lights came on (see above) but went out as soon as we turned off the truck. Plenty of passing power, and the torque range is very good,with a minimum of shifting. I think this thing will pull all day long at 55-60, but the wind resistance will start to drag if you think you are going to tow at 70.
As noted elsewhere, have a good hitch and get someone experienced to set it up properly. The Voyager brake controller works much better than the old one we had on the pickup, so I never felt the trailer was pushing the 4R even on the off ramps.
This was a short trip, but first impression is good. I hope everyone will keep posting their experience here.
Peace, Dennis
Happy trails!
Peace, Dennis
So the controller can be moved a few inches either way, but that's really the only area for it.
I really can't figure out why arragements are not made to mount it closer to arms reach, after all if you get severe sway, you need to be able to reach the lever on the brake controller to correct it.
Have him move it a few inches away from your knee if it bothers you. Or, you can do it your self assuming there is enough loose wire.
Good luck!
I just bought a 4Runner (V6) and need to hall a 10ft flatbed trailer in a parade. I checked the reciever and but the ball on but I didnt see the wire connector for the trailer. Do I need to have it wired? Am I missing something?
I have never towed anything and honestly didnt buy this vehicle to do so but I got wrangled in...
Thanks for the help!
Good towing!
DQ
I guess if it was a real steep hill, I could down shift further.
I have a new 2007 SR5 4Runner and has a receiver socket for trailer. I was looking at the wiring harness and saw two of them, one is black and flat the other one is white and a little bit round. Both wirings are connected to the receiver socket. Is the harness you're talking the black one? Do I just have to disconnect it and use the (female) portion to connect my boat trailer? My trailer wiring has the typical, green, yellow, brown and white wires. I'm just a little bit afraid of disconnecting the harness in my 4R. Would appreciate your help. Thanks.
Raul
Travel trailers typically have a 7 pin round connector.
Apparently your 4 runner is equipped to handle either.
All you have to do is to Plug your trailer into whichever connector on your 4Runner matches the trailer connector.
Generally the 7 pin round connector will have a flap that swings opens to make the pins accessible. The 4 pin connector typically has a plastic cover that pulls off to expose the pins. They are both designed so that you can't make a mistake while plugging in.
Kip
