Subaru Forester (up to 2005)
Basically it's just cold and different metals expand at different rates. The block is aluminum, while most reciprocating parts are steel.
They keep tuning the idle speed to minimize fuel use. They could probably smooth it out but you'd give up some MPGs, and nowadays you don't want to do that.
-juice
At 1000 miles I drained the factory fill and added the required 4.2 quarts of of replacement oil (Pennzoil Platinum synthetic 5-30 wt.) Also replaced the filter with a Subaru oil filter. Checked the level after two weeks everything fine. Did not check the level again until 900 miles. There was no oil showing on the dip stick!! Added 3/4 quart. Decided to drain the oil again that weekend and start over. Drained the Pennzoil and decided to now try Mobil 1 5-30wt synthetic to see if maybe it was the Pennzoil. At this point car had a total of 2000 miles. Waited until I got 300 miles on the Mobil 1 and then checked the level again to find there was no oil showing on the dip stick again!! Talked it over with the dealer they said it may be the synthetic oil not allowing the engine cylinders to seat properly??? Where is the oil going??? I now am going to change back to regular non-synthetic oil. Does anybody have any thoughts on this subject??
Another tip - fill up the new oil filter with fresh oil. By priming it like that it also helps the initial flow. You might end up using closer to 5 quarts by the time all is said and done.
-juice
I've seen oil reports of STi's shearing down 10W30 to a 20 weight in less than 2,500 miles and a Forester XT shearing down the factory fill oil to a 20 weight in 1,100 miles! 5W30 is "preferred" for fuel economy, but not necessarily the best choice for all applications.
Also, when you switch between different brands you will have oil consumption. M1 5W30 is a thin 30 weight so I would not go past 3,750 miles on the oil until you reach 10,000 miles. The Pennzoil is slightly thicker and has slightly higher high temp high shear viscosity (Product Data sheets from M1.com and pennzoil.com).
I thought Subaru would've fixed this "4.2 quarts" error by now. It's 4.8. Shoot SoA an email. So yeah, 5 quarts like juice said.
-Dennis
The dealer told you the design of the horizontally-opposed engine makes it vibrate more? People here claim it is a smoother design.
If it feels like too much vibration, it probably is. A well-engineered, properly assembled car should not do that.
I know some folks have said these engines have some type of "perfect second order balance", or something along those lines, but I have no clue what that means. I know it's not evident in the smoothess at idle. However, like I said, I just regard it as normal for these engines.
Len
Queene
However, 2.5l is rather huge for a 4 banger, and large 4 cylinders tend to shake a lot at low rpm. The 2.0l engines are better, and the 3.0l H6 is butter-smooth.
The '06 model with AVLS should tame that somewhat, because it can vary valve lift depending upon rpm. Every car in the lineup minus the Baja has that.
Boxer engines have a characteristic growl that more than makes up for that, i.e. they have character.
-juice
If anything, this problem will become worse, not better, as car makers learn to tune their cars for max economy. Customers will demand it.
-juice
My Miata is side-mounted and you can't help but spill oil. In fact the aftermarket sells oil filter relocator kits, it was placed so poorly.
On the Forester, I poke the bottom and even drain the oil in the filter before removing it. No mess, period.
-juice
Excuse the naive question-- but is it possible to store reserve gas in the Forester's cargo area, if one had the right container? (Obviously, only in an emergency situation.) Would this be a fire hazard? Is it legal? Will gas stations let people fill up containers, assuming one did it before a crisis and the rush on gas started? How long would it 'keep'?
Not that Boston is likely to get hit by a hurricane or other natural disaster anytime soon, but who knows?
Gas ought to keep for about a season, if you add fuel stabilizer. I'm not sure I'd want 3 month old gas with StaBil in my Forester, to be honest, but who knows?
Fire hazard? Definitely. There is a company that sells one gallon containers that are supposedly not, though it works as fuel if you add it to the tank. Again, who knows what long-term effects that would have to your engine.
A bigger hazard might be the fumes themselves, plus the fact that the container will expand and contract, and the inside of a car varies from freezing temps up to maybe 120 degrees or more, so there's another issue to overcome.
So I don't think there's a practical way to store much gas beyond maybe a gas can with a couple of gallons. And that amount might not even be enough in case you were evacuating. I'd keep that on the exterior of the vehicle somehow, not inside. Maybe secured to the roof rack?
-juice
The Champagne, Red, and Black XT's come with the tan leather, while the White, Blue, and Grays come with black leather. The champagne color is too blah for my tastes, I've never liked red cars, and while I like black cars I'd never own one again because they're so difficult to keep looking clean, and eventually the paint will noticeably fade.
So there are options out there if you don't want black leather, but none of them were for me. Besides, I love the way the steel gray looks on the XT (I believe it's the color featured heavily in marketing photos and the MY06 brochure).
It's odd that Subaru offers tint on the Baja and Tribeca, but not the Outback or Forester. And guess which 2 do the most volume?
-juice
To help with the heat, I tinted my windows (did so on my last Forester too). The tint really does help.
Michael
-Frank
Is it film? Must be if it's installed at the port.
You sure it wasn't a dealer add-on?
-juice
-Frank
Michael
I can't imagine they replace the glass at the port, that's why I ask.
-juice
Also looking for a 70mm torx bit so i can change my front diff oil. Checked the net with no luck. They want to sell a set but only want the one bit. Also checked Ebay with no luck. Pert
PS Ck with several parts stores. No luck
Just a swag--is there one in the tire change "tool" kit?
John
As to how someone could get the Front diff plug out w/o the T70 bit, it must have required some imagination. The rear diff is just a 1/2 drive. Front plug on the Forester XT torques @32.5 lbs and from the looks of the threads over torquing would be very bad. You should replace the metal washer at the same time.
The reason that this is so fresh in my mind is that I did it this week, on 9/27.
For snow tires I bought the $49 (now $62) Winterforce tires. Have run them for 3 winters. They are noisy, but work well.
HTH
Larry
You must have an automatic?
John
-juice
Took me a while to locate one. Single 70mm Torx 1/2 drive socket was over $20/us. Now I see them in kits for just a little more. So if you do your own service, something to look out for.
The Saab 9-2 will continue, but the planned Saabaru crossover vehicle is canceled.
-Dennis
My Forester just seems to get more efficient with time. 43k 5speed '03 XS.
John
