Volvo XC70 Electrical/Lighting Issues
use this discussion to dDiagnose and solve any electrical or lighting issues you may be having with your XC70
5 mins later it happens again, this time the heat seats stop working. Another few mins pass it happens again and the dash map, radio, clock, trip odometer and other components stop. Within 20 mins of this I was down to only headlights working no turn signals, no highbeams, no fog lights, no interior lights when I opened the door. I turned the car off, restarted it immediately and all was normal - for 4 months.
Yesterday it happened again. 3 hours into highway driving with everything on - boom. "What did you hit?" asked my husband. Nothing the car's electrical failures started again. I got to the nearest exit as it learched again - and turned it off. It is like everything just stops for a split second even the engine. I waited 10 mins to stop shaking - and all is fine again. Drove 8 hours straight with no issues.
The Dealer found a faulty "rear module" and a low battery the first time based on some codes. This last time they said there were no codes and could see no sign of any "issue". Any thoughts?
While I had been instructed after the first time to shut it off immediately to let the computer "reset", I did not on this third time until it had down about a dozen failures over a 30 min period to the point where nothing electrical worked inside, and there were 3 warnings: ABS Failure, Check Engine, and Airbag Servicing. Then I parked it for an hour. Started it up, the warnings were still there but all the electric was back on.
The dealer said: "Brake control module was fried and the battery needed to be replaced."
I can't help but think its another symptom and the real problem has not been found. Does it make sense for a faulty brake module to only act up when your hours into a highway drive?
got to my friends house, came back out to leave (30 min later) and when i turned the key - nothing - as if the battery was dead. waited, turned it again, slowly turned over, turned again and all was fine.
stopped & started the car 2-3 more times with no problem the rest of the evening.
has this happeend to anyone else ?
After I threatened them with Lemon Law and called Volvo Customer Service, the mechanic was finally given permission by corporate to driving the car to and from work (50 miles each way). His quote was, " I was cruising along with the nav up listening to the radio, this XC is a really nice drive. Then, WHAM out of no where the car instantanously cut off and then came back up in a split second. It scared the beejesus out of me."
They are searching for wire diagrams, maybe now they will find the root cause or get me a new car in exchange.
Engine fan goes on automatically up to 2-3 hours (observed) despite Volvo service alleging should only happen within 1/2 hour if engine remains hot?
Could this be cause of battery run down?
Any suggested fix?
2001 70XC 3500 miles
Jack_MendhamNJ
47500 miles V70XC 2001
Sorry for the incorrect info.
Local repair shop researched Volvo bulletins and website after checking battery and alternator. Cannot establish link between engine fan running after key turned off and removed and compartment fan blowing at full blast.
When discovered both fans are retired by ignition key ON, then OFF.
When not discovered may have caused dead battery several times recently/
I just observed the same thing, all the interior fans at full blast on without a key in.
I am also having troubles with my battery. I am about to put the third battery in. I am not sure whether it is caused by the lift-gate not completely latched (does not close that well) draining the battery.
--KK
Please note that I have had similar issues on long drives, but never as severe as the one listed.
My big questions are did Volvo ever repair your XC70 and what dealership performed the work?
Whenever the voltage drops below the minimum bias level, the behavior of the computer system in totally unpredictable. Low voltages will reset the computers preventing any errors codes from being stored (a concept that many dealers refused to accept!). This phenomena accounted for my original breakdown, and even after the CEM and battery were replaced, the vehicle still behaved oddly. The alarm sounded without reason, the door locks would behave erratically etc. Finally, I found a dealer that understood my cars issues, and thanks to a new alternator/voltage regulator, my car is again driveable.
Please be aware that the S80, and I assume the XC70, have an automatic feature that cycles air through the cabin when the car is parked to keep temperatures to a minimal level.
What happened: Was driving on highway and slammed on breaks to avoid accident ahead. First, the radio turned itself on-off, lost turn-signal (bulb was burned out). When arriving home, radio would not shutoff. Next day was driving 2-3 miles from home and all electrical went out...except radio! Drove home and had car towed to Volvo. Appeared that when hitting bump in the road everything flickered and went out.
Message center displayed initially that a bulb was out (proven true) and the second time that the ABS was bad.
Volvo initially has said that the computer is bad, but diagnostics shows no errors.
Noticed that there have been other electrical issues posted here. Did anyone ever have the problem resolved?
I have a 2004 XC70 wagon, 80,000 miles
It has the same electrical problems described.
The car will suddenly ‘buck' for a second as if it stalled or is trying to downshift. I'm pretty sure it is trying to shift. The inside lights will go on, and a ‘left door open' message will appear. Sometimes the dashboard lights and indicators will go out as well.
The transmission was flushed by the dealer for the first time at about 70,000 miles. It was dirty at that point according to them. 75,000 mile service was performed, and the software upgrades were done.This was about 6 months ago
The problem continued after the service, once the weather got hotter (in New Jersey) One volvo dealer had no idea, another said it was a $ 1,200 + problem:
‘Fault trace to internal fault in DIM P/N 8602763, 8633289' The first item is the dashboard assembly for $900, I can't find any info on the second part.
From browsing I have picked up the idea it is the ECU. From other posts, it sounds like I should have the transmission flushed and check for software upgrades. I am not planning to attack this myself. I'm looking for clues to discuss with a mechanic.
Has anyone successfully fixed this ??
This may be a chicken or egg thing with the voltage. A computer chip should not 'wear out' like a moving part, although a defect may take time to appear. I suppose a voltage swing could burn it out or weaken it.
For now, I am glad the CEM was replaced. The first dealer said nothing was wrong, the second wanted over $1,200 to replace the instrument panel, but couldn't explain how that would cause the problem. (i declined)
I agree Volvo should be more helpful
Keep me posted.
Once the problem starts, it'll continue and usually worsen. The latest time I would completely lose power to the dashboard (lights off, gauges at zero) and get an error message that my brakes and airbags had failed.
We've taken it to a couple of dealers and independent mechanics, but no one has had a solution (or even experienced the problem). I'm not sure it's worth $1000ish to fix, though, if ti really requires a new CEM.
Frank
