GMC Jimmy transfer case encoder motor install 97
Greetings,Greetings,
I am about to replace the transfer case encoder motor on my 1998 GMC Jimmy NP1.
I have the typical engage 4x4 problem: I disconnect TCCM or unplug battery for a few minutes,
turn on/off the ignition 5 times and then works for a little while and then no more.
I have replaced the
vacuum actuator (new)
front axle coupler sensor (new)
TCCM (junk yard)
dash switch (junk yard)
in the above order; so now
I have acquired a new transfer case encoder motor and about to install it. I read a post in another
news group that says:
***HOW TO INSTALL THE NEW ENCODER MOTOR***
Lucky way - Only thing that needs to be removed is the encoder motor itself. Tools needed are a
10mm hand wrench and a 8mm and 10mm socket wrench. The 10mm socket will work on the
upper and lower bolts, while the regular wrench is needed for the middle bolt. (Tight squeeze).
The 8mm socket is for the electric plug.
Then, just pull out, and wiggle it out of the truck. Install in reverse order.
Unlucky way - This means the encoder motor did not just wiggle out. Now the front drive shaft
will have to be removed at the transfer case. Then, a yolk puller is needed in order to remove
the yolk from the transfer case. Once this is done, go to the directions in lucky way.
The above process was for a 1997; does it still apply to 1998?
Are there any secrets to this process?
Can I influence the lucky/un-lucky way?
Tanx in advance.
RC
I have replaced the
TCCM (junk yard)
Tanx in advance.
RC
Tanx for the reply. From the number of your posts sounds like you've done this before! So here's my question, how often does the encoder just "wiggle out"? Fifty/Fifty? Better, worse?
regards
RC
It has the pushbutton 2WD/4HI/4Low buttons on the dash, its a 6cyl with the 4 speed auto trans.
My problems is this:
Used the 4x4 in HI range this past weekend on my property to pull some old tree limbs to the dump and also at my friends place as well. No off roading or any of that stuff just used it to get up the lawn instead of tearing it all up.
Now I'm having issues with the 4x4 disengaging, it goes back into 2 HI but the transfer case is staying locked in. I can move/spin the front shafts but the shaft that goes to/into the transfer case doesn't move or spin at all. It used to move freely when in 2 HI but now it doesn't.
All my tests that I have done so far is with the truck sitting on the ground running and in park.
I know the 4x4 front shafts are disengaged because the wheels move freely across the pavement. When engaged they do the chopping and sliding event. THIS not my problem its to the transfer case is where its all happening.
I am having a lot of drag on the road to the point its eating my gas mileage, there is a slight vibration and I have to lean into it to get it moving.
One tranny shop told me it could be some plastic pins or bushings in the transfer case or possibly a fork or two that are going/have gone bad. Without opening it up they cannot tell me what it could be. The price could be a 100 or 200 up to a grand for a used rebuilt transfer case installed.
thanks in advance
